[Review] YLP Panda 3. [upd.31.08 #16]
59 posts / 0 new
AEDe
AEDe's picture
Last seen: 1 hour 51 min ago
I want to tell about interesting headlamp designed by Russian company Яркий Луч (Yarkiy Luch). This company has “profesional series” with subbrend YLP.
It is clear from the name that this headlamp is third version, but it is very different from previous ones.
The main feature is independent spot beam and flood one. without separate battery case.
SPECIFICATION
LED : XPG3 NW(4000K) for flood beam , XPL HI NW(4000K) for spot beam.
Max Lumens: 1100lm (2 × 550lm)
Weight: 58g (fhashlight only)
Dimensions: 79*32*26 mm
Battery: protected\unprotected 18650
Water Resistance Rating: IPx8
Max Beam Distance: 115m
PACKAGE
APPEARANCE
Headband. Top strap is too long and main strap maybe a bit short for big heads.
Thread
Magnet in a tailcap
Spring on “+”
Indication LED in buttons always on when light is on.
Weight and dimensions
Headlamp only – 58г
Main strap – 26.7г
Top strap – 12.7г
Magnet – 4г
18650(e.g. 35E) – 48г Dimensions 79*32*26 мм
OPERATION
I would not say that operation is intuitively clear, but after reading the instructions one can understand its logic and convenience.
Gray button
Short press from off – turns the flashlight on in memorized mode.
Short press from on – turns off the flashlight with memorization of the mode and the type of light (Flood / Spot / combined), the minimum mode is not memorized.
Long press from off – turns on the flashlight in the minimum mode of the stored type of light.
Long pressing from on – scrolling modes in a circle. (The minimum mode is not included in the circle.)
Triple press – charge indication. from 1 to 5 flashing main diodes. The beginning of the indication immediately at the moment of pressing the third time and blinking is very fast.
Black button
Short press from on – changes the type of light in a circle flood / spot / combined.
Long press – turns on the maximum of the spot beam, the second short press returns to the initial state.
Double tap – turns on the maximum of both diodes, then short press returns to the initial state.
It should be noted that the brightness of each diode is memorized. For example, turn on third mode of flood, then turn on second spot mode , if you now turn on the combined mode, then the 3 mode of flood and 2 modes of spot will be turned. If you change modes from the combined, then the brightness is equalized
MODES
Accorging specification modes for each led are 10-35-120-240-550lm.
And runtimes are 150-36-10-5-?(Temperature control)
My measurements:
Flood : 18-70-240-460-1500mА , 7-28-90-180-530lm
Spot : 26-86-280-540-1700mА, 10-33-100-190-570lm
Combined: 40-160-600-1250-4100mА , 15-65-218-420-1300lm
Off current <0.01mA
In turbo mode headlamp heat up very quickly. From 25C to 60C during 4min.
There is stepdown at 60C to 40%.
But it is not enought so heat up is going on to 70C eaven at 40% of brightness.
Turbo mode with water cooling.(It is also IPx8 test)
Maximum mode of flood beam. There is also stepdown ot 60C.
Spot+Flood 2×240lm. There is no stepdown but temperture is 64C
As you can see headlamp has no stabilisation.
LIGHT
Flood beam
CCT = 4141K (Duv -0.0046)
Color Rendering Index (Ra) = 74.1
R1 = 73.5 R2 = 79.3 R3 = 82.4 R4 = 74.1 R5 = 72.6 R6 = 70.1 R7 = 81.1
R8 = 59.5 R9 = -11.5 R10 = 50.0 R11 = 70.2 R12 = 46.2 R13 = 73.6 R14 = 90.3
Spot beam
CCT = 4101K (Duv 0.0005)
Color Rendering Index (Ra) = 72.9 [ R9 = -19.1 ]
R1 = 71.1 R2 = 77.8 R3 = 82.9 R4 = 73.1 R5 = 70.6 R6 = 68.8 R7 = 81.3
R8 = 57.3 R9 = -19.1 R10 = 47.7 R11 = 69.2 R12 = 44.4 R13 = 71.3 R14 = 90.7
PWM 15kHz
According luxmeter Spot: – 2400cd ANSI 100m, 4.2cd/lm
Flood: 900cd ANSI 60m, 1.7cd/lm
Beamshots
H03 , Panda 3 , H600w mkII
DISASSEMBLING
Disassembling of Panda 3 is easy. 2 x T6 screw only.
Tir optics with glass lens.
Electronics with linear driver.
Copper MCPCB
LEDs
CONCLUSION
In my opinion Panda 3 is very interesting headlamp, becouse it is the only unibody headlamp with real spot/flood light.
There are some fenix models like HP25 , HP25R, but they are large and not convinient for EDC. Nitecore HC65 has auxiliary flood with 11lm only.
pros
- Build quality
- Good operation
- Compact size
- IPx8
- Thermal control
- TIR optics.
- Neutral light
- Easy to assemble / disassemble.
cons
- Linear driver (PWM and no real stabilization)
- Wrong lengths of strap
- Difficult to read charge indication
- Low color rendering index.
- Color artifacts on the “spot” (I see only on a white wall)
- Absence of moonlights.
- Dumb temperature control fixed
Edited by: AEDe on 03/25/2019 - 10:21
travis
Last seen: 1 month 1 day ago
60C (140 F) is hot to be near your precious head.
I’m wondering what the perceived heat is to the wearer while using the head strap ?
“"A free people ought not only be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government.””
-George Washington
AlexGT
AlexGT's picture
Last seen: 1 day 17 hours ago
IMHO, the button solder points to the board might be the failing part due to wear from use, since apparently they are the only thing holding them in place…
EasyB
Last seen: 5 min 45 sec ago
I like the idea of two beams and that the light is compact, but it looks like the two beams might not be that different in width. If you are going to go to the trouble of making an additional spot beam, I would make it more intense than 2400cd.
For example make the spot TIR bigger. The ~17mm TIR that fits in the convoy S2 makes a great beam with an XPL HI; wide enough to be useful at intermediate distances but with some good intensity. Mine does 20Kcd with a FET driver so it would do at least 10Kcd driven at more moderate levels.
AEDe
AEDe's picture
60C it is appropriate temperature, I always set 55-60 on headlamps with adjustable temperature control. No discomfort at all.
AEDe
AEDe's picture
There are shelfs for button bords.You can see it on front photo of mcpcb and under mcpcb.
It was Panda 1/2 issue, so YL pay attention to buttons.
AEDe
AEDe's picture
Panda 3 is headlamp , a work tool , not WOW thing.
10-20kcd it is useless laser on ones head.
With the slightest hint of fog ones would see only “white wall”.
For real headlamp application as run, ski, bike, outdoor, caving 2400cd is enough . It is almost the same cd/lm as H600.
In med regime flood beam for work with hands. And spot beam for medium distance 10-20m.
EasyB
I disagree. If you are going fast or want to see farther for another reason, you are going to want more than 2400cd.
AEDe
AEDe's picture
Then you can use large throwers like blf gt. It is not headlamp’s work.
DavidEF
DavidEF's picture
Last seen: 6 days 16 hours ago
I haven’t ever found a headlamp that I liked. This is the first one. I may have to get one now, if I can. Are they available internationally? If so, what is the shop that sells them?
- The YKK Philosophy
AEDe
AEDe's picture
Panda 3 is out of stock right now, but I hope it would be restocked soon. First small batch was sold on russian flashlight forum fonarevka.ru
There is official shop
ylplight.com it has english version, international shipping and accept PP.
But panda 3 page still exist only in Russian.
ylplight.com/katalog/1/nalobnye-fonari/panda-30/
mrheosuper
Last seen: 3 weeks 4 days ago
change the XP-G3 to nichia 219C or samsung lh351D and it would be perfect
Forgot my pen
DavidEF
DavidEF's picture
According to one website, the 2990 Rubles price is about $47.47 US dollars. That seems like a reasonable price, but do you think there could be a group buy here to bring it down a little? I don’t know how to run a group buy, so somebody would have to take up that responsibility. But I would really like to own one of those lights!
AEDe
AEDe's picture
It is the first thing I made after review. Smile
With 351D , flood beam has 450lm ,and 1.25cd/lm and light is the way better than with xpg3.
AEDe
AEDe's picture
Unfortunately international shipping is expensive.
I think GB or some coupon code is possible. YL sometimes provide good coupons for russian forum. Also they recently launch international shop so they maybe interested in promotion.
I ask them when panda3 will be in stock.
AEDe
AEDe's picture
A little bit more about real tests. The traditional expedition of the  speleo club Perovo in the area of the Arabica massif(Abkhazia) to the Verevkina cave has just ended. Verevkina cave is the deepest(2212 meters.) cave of the world for almost a year.
In this expedition I used Panda 3 as the main light on the helmet. Just before expedition I replaced  stock xpg3 by 351D 4000K 90cri it makes light much more pleasant, and  much wider.
My task in this expedition was the topography of the so-called bottom labyrinth - an extensive network of subhorizontal courses beginning at a depth of 2100 m.
The path to this depth takes 3-4 days for 10-12 running hours ( with a load of ~ 30kg) along the vertical part of the cave. Characteristic forms of relief are vertical pit (up to 150 m deep with and without waterfalls) and short meanders between them of different widths.
Work on the rope takes most of ascend\descend time
Stops for overnight taces place in underground camps at  depth 600m, 1300m, 2100m.
The most interesting part of cave starts at 2100m, where the modern cave, apparently, cuts a branched network of ancient siphon pipes. Now the known length is approx. 7-8km. This part consists of "pipes" with diameters of up to 16 m, siphons, half-siphons, halls, small vertical pit.
Work in the cave lasted 14 days, 7 for way down and up and 7 for topography.
Now about the flashlight.
The first question was fixing of the headlamp on the helmet. The rubberized strap was well held and did not slip over the plastic helmets.
This, along with the standard rubber band is enough for fastening, for 2 weeks did not fall down at all.
After 2 week in undergroung the only headlamp damage is scratches on anodisation.
Buttons are too small , sometimes it is hard to find them into gloves.
PWM at 15kHz is almost invisible, it can be seen on falling water..
Ipx8 is fine.  Panda3 holds pressure drop ,100% humidity, dripping water.
The second mode of the flood light was enough for comfortable work with a rope at ascend\descend.
Quick access to the maximum mode of spot allows to view the rope far away. Vertical pit with depth about 40-50m can be enlighted by spot light.
During  ascend(descend) I used only one 18650.
Situation in the topography of the bottom parts, was different. One need to inspect everything for good topography. The sizes of the pipes are different, according to this, the modes of headlamp were often switched. I  mostly uses  2nd and 3rd modes in all possible combinations, and the maximum of spot.
(Siphon pipe. Depth is 2150m from the entrance)
In this case I change 18650 every day. In total I spend 8x 18650 for expedition (new GA).
I very like this headlam, during 99% of the time I did not recall about its existence)
Ford Prefect
Ford Prefect's picture
WOW
Thanks for sharing those pictures from your trip! What an experience to spend that much time that deep underground.
djozz
djozz's picture
Last seen: 8 hours 54 min ago
That is a major adventure! Thanks for writing it down, and the wonderful pictures. I’m sure that the Samsung leds made everything look better down there.
What is the purpose of mapping that cave?, is it just hobby/tough sport or is there a serious background to it?
DavidEF
DavidEF's picture
Looks like the Panda 3 headlamp was a champ! Now I need to find a real use for mine other than just playing around!
nvanlaar
nvanlaar's picture
Last seen: 3 months 4 weeks ago
That is very cool! What an awesome glimpse into real use.
“Facts don’t care about your feelings.”
~Ben Shapiro
AEDe
AEDe's picture
djozz wrote:
I’m sure that the Samsung leds made everything look better down there. What is the purpose of mapping that cave?, is it just hobby/tough sport or is there a serious background to it?
You are right) There are many abjects with warm colors in caves. Thay looks amazing in hicri and hi r9 light, and donot impress at all under low r9 and cri. It even almost not depends on tint below BBL or above BBL.
I am sure all works in caves are hobby)But often its have serious background too.
Our map has several purpose
1) Cave depth specification.
2) Help to navigation for future expedition.
3) Search of new directions for research.
4) Understanding internal structure massif, it history.
You can see 2D projection here
djozz
djozz's picture
5)making sure that your cave remains the deepest in the world Big Smile
Already found the Wikipedia page of the cave, and I really enjoyed a film of the 2017 expedition on youtube. Very impressive!
AEDe
AEDe's picture
The big secret is that accuracy of map about 1% in case of Verevkina cave and much worse than 1% in the the case of Krubera cave. So “one of the two deepest cave” is more correct words)
MRsDNF
MRsDNF's picture
What an adventure and real world test on the headlamp and body. Loved the pictures and the story AEDe. Thumbs Up
maukka
maukka's picture
Last seen: 1 day 7 hours ago
Wow, thanks a lot for the report! That’s so cool and scary at the same time Smile
Scientist
Scientist's picture
Last seen: 51 min 53 sec ago
Such a totally awesome adventure AED. Thank you for sharing. I think YLP should share some of their profit with you for your great advertisement of their light.
Please illuminate responsibly
Part time fragmented conciousness technician
UV triple using Sofirn C8F
395nm High Power LED in Sofirn SC31b
Lightbringer
Lightbringer's picture
Last seen: 10 hours 13 min ago
Wow, that’s at least not too claustrophobic. Impressive formations, I actually wouldn’t mind poking around there, ‘though not for 2wks! I like indoor plumbing… Big Smile
When I think “spelunking”, I usually think of narrow claustrophobic caves where you can so easily get hung up in there, stuck, not be able to turn around, and pretty much die. Go’n‘goggle “john jones nutty putty cave”. You couldn’t even force me at gunpoint to go into one of those caves.
But yeah, moar pix if you got ‘em!
Lightbringer
“Scooly”? LOL
YuvalS
YuvalS's picture
Last seen: 3 days 19 hours ago
Seems like it is almost the PERFECT caving light, maybe not as a main light but definitely as a backup light.
The only problems I can see is the magnet which is really bad for survey and also too many modes IMHO.
sesgum
sesgum's picture
Last seen: 15 hours 6 min ago
Thanks for sharing your amazing adventure AEDe! So jealous that you can put your lights in real use…
AEDe
AEDe's picture
The magnet is removable.
Not perfect but I think the best for caving in <100$ price range.
Btw I made small mod
Now it is most compact 18650 headlamp)
https://gifyu.com/image/NK8h
