I recommend custom rings if you will use driver with components on both sides.
just so i’m clear, for $3.00 i get a retaining ring that will hold the 17mm driver in the adapter, is that correct ?
Yes. Custom ring is not cheap.
$3.00 for a custom machined brass ring sounds reasonable to me, certainly better than soldering one in
C8 copper pill with threads measure like fasttech brass pill are available?
Not available and never will be.
You can use this one: http://kaidomain.com/DIY-26mm-D-x-13_5mm-H-Copper-Driver-Pillar-Set-for-C8-LED-Flashlights?search=c8
thanks,This one doesn’t copper as declared but brass
right?
Wieselflinkpro: Alen:C8 copper pill with threads measure like fasttech brass pill are available?
right?
brass looks different: https://www.fasttech.com/p/1208600
I think someone wrote that he has bought it an it was realy copper.
As some of you know, near a year ago Ive started to provide cnc made parts. This improved quality and abilities, but I couldnt provide rare parts anymore so I had to refuse when got pm with custom request.
I dont like to leave somebody dissapointed, I would like to give the last chance so anyone could make any pill Ive ever made.
List, from big to small:
Courui D01
Small Sun ZY-T08
HD-2010
Brynite B158 (2pcs reserved)
P60 single led stock reflector (7/10 pcs reserved, will be machined next week)
Ultrafire or another brand SK68 clone
Surefire type E?I can make any of them last time (MOQ=5pcs, GB open) $25/20/15/10/10/10/10, or
sell any die (tool that I used to make good quality calibrated threads) just for $10.
Whats the price for the Courui D01 Pill? And whats the material?
$25, copper
Hi Kiriba
can you please PM me for 2 (Copper spacer+brass centering ring set for quad mod Convoy M2)
$25, copper
Ok, I let my custom aluminium Pill inside.
If somebody will be able to supply 17mm boost drivers, I would make S2+ pills for single led.
∅20mm H1-A driver can be used soldering it to the pill with a hot air gun. H1-As maximum Vout can be modded for triples, see Jensen567's work.
This is a little job I've done with a genuine UltraFire SK98 flashlight's pill.
Inner cylinder is ∅11.1mm approximately, made of two 1mm thick copper discs. Under it is soldered to a ∅18mm 1mm thick disc, and thermal glued to the pill's balcony.
This model would thank a nice and beefy copper pill, it is very easy to mount an H1-A driver in, fits snugly.
Originally posted on Sun, 07/29/2018 - 19:38. Added comments. Further edit to remove wrong white balance pics.
kiriba-ru:If somebody will be able to supply 17mm boost drivers, I would make S2+ pills for single led.
Those would run XHP Leds? I would buy driver and pill :smiling_imp:
mtnelectronics is supposed to have something in the works, available at the beginning of August! I suspect a copper pill will be quite necessary when running an XHP in an S2+
MascaratumB: kiriba-ru:If somebody will be able to supply 17mm boost drivers, I would make S2+ pills for single led.
Thanks for the info mate! I’ve been reading RMM’s thread and noticed that recently
I’ll be looking for it on both thread and in MTN site! Thanks for sharing :+1:
$10
Last time I had them was more than a year ago. Dont remember weight. Defenetly under 50gr.
Thanks kiriba-ru. Could you please put me down for two B158 pills?
kiriba-ru:$25, copper
Im sorry, it requires as much as 20x S2+ spacers in material and as much as 10x S2+ spacers machining time.
Money is not target, I left the message to finish as much custom (small quantity) orders as it is possible ATM.
If you think parts are overprices, you are welcome, just $10 for any die (I will help with tips and drawings), it would be great if another BLF member would provide this pills could keep prices at better level.
Wieselflinkpro: kiriba-ru:$25, copper
I do not have a the possibility to make something like this and I do not say, it is overpriced. But its not worth for me for this flashligt.
