Yeah, been running it at (1 amp which is around what the lantern draws) for a while and it’s not very hot. But does get hot at 2 A. If it’s a constant current driver, the current is higher on low battery. Has anyone done runtime graphs yet?
edit: maybe the heat path of the whole thing is directly connected there, since it looks like the whole bottom piece is part of the same aluminum block. The tailcap is just the only place without plastic molding.
edit: maybe the heat path of the whole thing is directly connected there, since it looks like the whole bottom cap is part of the same aluminum block. The tailcap is just the only place without plastic molding.
I let the light run a couple of minutes with just the usb power connected (no battery) and the tailcap got warm (hot after 10 min). It’s the led and driver heat flowing there. Combined with the battery and spring heat, it’s no wonder then. The whole battery compartment seems to be the led heatsink as well.
I already showed my interest before but since I changed my user name I want to be double-safe to get on the list for the next batch Thanks for your efforts Freeme!
Standby current is 170 µA. Two years two drain a 3000 mAh battery.
The tailcap spring resistance is huge, 74 mOhm. No wonder it heats up. Definitely recommended to bypass it.
For reference, that’s 4 times as much as the similarly long spring of the Acebeam EC65.
My guess would be that this stock spring would activate the low voltage protection earlier than necessary giving less running time.
Click this to go to signature links. I'm still around, just not reading many new threads.
Current is pretty low. I suspect the tailcap gets warm because it’s the only place via the metal battery tube to dissipate heat.
here: http://budgetlightforum.com/node/61110
If it’s not too late, I’m interested in 2 lanterns once this GB starts up again.
7/18
7/22
Any updates from them this past week …..
Im not a Pessimist …. just an Optimist with a lot of experience
A little John Prine
T1 is in stock again.
Hey freeme, is there a new coupon for this? The old one doesn’t work anymore for me (I’ve already ordered one T1 using the old coupon code)
Let a flooder be my wife and a thrower be my mistress
wait for a new codes.thank you
I would’ve gotten another one as well, but the $5 shipping and the coupon not working kills it for me.
Seem like T1 has stocked up.
@1theDeals
code?
Nico -.-
I requested for another 100pcs today. Hope it gets approved from their boss.
@1theDeals
Please send new code if they become available
Thanks Freeme
A little John Prine
jumping on the wagon, 2 pls.
2 please.
Thanks for the work
Very happy with the couple I bought from the first batch. Would like to purchase a few more if the code becomes available again.
Thanks Freeme
Should’ve bought more than 1. I just got mine today and it’s pretty cool lantern. Thanks!
Group buy will resume today!
@1theDeals
Missed the first round but already asked for code.
So please do not forget me! Thx!
Interested in 1pc.
In please
عُمَانْ
Need 1 more thanks.
I’m in for 1. Thanks.
I am in for at least another one
Interested!
