WTS: Calibration lights for DIY integrating spheres / lumen tubes - 67 € -
Not if it’s calibrated correct right now. Don’t touch anything, just enjoy :beer:
I disagree. Plus I don’t think it’s calibrated. If keeping the leaking light in the tube makes the readings go up, then it’s reading high.
In my opinion, the fit around the light should be a bit tighter (although it doesn’t always seem to make that big of a change) and the lux meter needs to be pushed all the way in. This is how you will get consistent results with other lights.
First test:LuminTop ODF30
moon: 11
Low:191
Med:682
High:2140
Turbo:4270
ODF30 Now
moon: 4
Low:124
Med:447
High:1423
Turbo:2850
Standard flashlight test light escaping too much?
Light escaping is not a problem by itself, consistency is when the escaping light is the same fraction for all lights.
Exactly my point.
I just tested with my own BLF348 and it read 1 lumen higher with a custom centering ring vs the smallest normal ring.
And what about with your lux meter slightly pulled out?
The meter position will be relative, it will effect all the readings by a fixed percentage. It basically becomes part of the calibration.
That said I do not recommend using the meter position as part of the calibration as it is too hard to keep it consistent over the long term.
Adding a little electrical tape to the inside of the 1st bend would be a better way to fine tune the readings since that will not be effected by bumping the sphere.
That was the point I was trying to make earlier. It’s best to put the meter all the way in so that it’s consistent and then find some other way to adjust the output up or down to get the correct Lumen reading straight from the meter.
Also, the vast majority of my lights have a fairly decent fit through the centering ring holes. If I were going to be using those extra small diameter lights to do the calibration, I would probably rig up something simple to prevent that extra light from getting out.
Sorry if I sounded grumpy.
Thats about right… i got 3150 lumen @ turn on… and 3090 lumen… odf30 is a joke… sometimes turbo mode doesnt want to work… lumintop should have use spring tailcap… oh well…
I think it’s a pretty good light.
The tail cap lacks springyness. Just pull the tab up a little so the battery gets compressed. Then you should get turbo for about 1m30s or more. I might replace that tab for a regular spring and bypass it.
I got about 3050 lumen at 30s.
I don’t use it because it lacks a mode around 1000 lm and has the weird one click on and press/hold off. Also, I don’t like glued lights.
I can’t seem to find any 26650 boost driver light that meets my needs. I’m just waiting for Lexel to start selling his drivers.
My lights came today. I will give a report once I have some time to play. Thanks again Maukka
More lights arrived today. All the people on the list will have their sets sent out this week.
I also got my lights - very happy, thanks Maukka!
PPal sent! Thank you very much!
What carrier is delivering these in the U.S. ?
Not that it matters but VoB got his his really quick. Probably paid extra for the shipping. As far as who is delivering them in the states I have no clue. I would think usps will eventually end up delivering them.
They will get here when they get here.
I have been rushing to the mailbox everyday after work, nothing yet. I usually don’t to get excited about new lights but these, I feel like a 10 year old at Christmas. :smiley:
Got mine via USPS today. Thanks! Can’t wait to get calibrating. Thanks maukka!
For those who are antsy (I was), it wasn’t in my informed delivery app, just showed up.
Thanks, that tells me I don't need to check the front of my house for packages after USPS has delivered the regular mail.
