That helped. Thank you.
So nice! thx
There are still a few bits here and there which aren’t re-styled correctly, but it mostly works. Some of the table border lines, in particular, haven’t responded easily to overrides, and I haven’t tracked down the reason why.
I also have a few little extras locally, like to remove the search box. I had kinda forgotten it’s even there, since I’d rather type a bit more during a search than have the widget always taking up space.
Le sigh.
New Drupal, gotta redo the theme again.
Maybe in a few days. That blood moon eclipse was exhausting, so I’m taking some extra time off.
Stylish became malware/spyware, and was removed from Chrome’s extension library. Use Stylus instead.
Hmm, it may just be that. I forgot to update to Stylus on this computer, and it appears to have finally disabled itself.
Last night BLF was really really slow and it seems magically better today, and the style override stopped working, so I thought it was a server-side update… but it may just be an outdated client.
Screen…
… so
………bright!
Aaaaaggghhhhhhh!!!
Okay, confirmed. BLF’s stylesheet didn’t change… it’s just that Chrome-based browsers started disabling Stylish because it was bought and became spyware.
So, to get things working, uninstall Stylish, install Stylus instead, and do everything else the same as before.
Thanks TK, screen looks SO much better!
Sorry my CTE is acting up :weary: but I am unable to get this to work. I have Stylus installed and enabled. I am still using FF56 cause anything later breaks 90% of my addons. I had Stylish working before FF disabled it … I tried to read the whole thread but it only confused me. Can you point me to a post that specifically explains what I need to do or maybe provide a CSS file that I can import? Thx TK
FYI, I use FF56 as well.
If you already have Stylus installed and enabled, then go here:
And then click “Install Style”.
IIRC, that’s all there is to it.
At this point you can further tweak it to your liking. For example, I made some of the colors slightly brighter as I was having a hard time seeing certain text.
Thanks Pete…. I was playing around with it before I read your post and I got it to work although I am not sure if it is safe.
I re-enabled Stylish and exported the BLF info, then imported that into Stylus and disabled Stylish again …. I checked and it is working like it used to BUT is that okay or is some of that code vulnerable?
Edit: After doing the above and reading your post I went to the http://budgetlightforum.com/comment/1358466/edit link you provided and clicked the link ‘Install style as userscript’ ………. would that have overwritten the other script? Sorry for the confusion…. CTE makes my brain disfunctional! :weary: :weary: :weary:
Thanks for the help
Being awake makes my brain dysfunctional… :confounded:
I have PC using chrome….I went to here and clicked install (that was it). Works and is much nicer.
right mkdive, get used to it and then lose it and you’ll find the normal screen kills ya! lol
Here is the page with extension links for installing Stylus for Chrome, Firefox, and Something Else (icons, upper right)
When I go to get the “after dark” script, for some reason all I get at
https://userstyles.org/styles/124240/blf-after-dark
is a spinning beachball “wait” cursor, right now.
TK, is userstyles.org having collywobbles lately? I can’t get in, haven’t gotten a password reset, and get a beachball cursor trying to search for “BLF”
There’s recent interest in this from people who saw me mention using it to eschew tedious signatures, and I’m just as confused as the next user about how to revive my old Stylish script. I did see mention of how to convert, I”ve got to go read that.
I did get Stylus extension to install in my Firefox (Mac, 10.12.6)
Ive installed Stylus on Firefox Mac (thanks hank!) and have used code from ToyKeeper (thanks!) to hide all signatures on BLF
the app is here
the code is this:
.forum-post-content > div.clear { display: none; }
and figured out how to Completely Hide posts by any member, with the following code:
/* Someone */
div.posted-by-54321,
div.posted-by-54321 { display: none !important; }
to get the user ID you want to block, hover over their handle and read their number
then replace the 54321 placeholder
I’m not really sure what’s up with userstyles.org lately. I checked it just now though, and it appears to be working normally. I did a search for “blf” and it returned several results including both of mine.
About hiding posts, it only needs one line per user. There’s no need to repeat the same UID more than once and if it’s only one person then only the last line is needed. The lines before that, ending in a comma, are optional in case people want to hide more than one person.
Or, instead of hiding people, it can be used to style posts on a per-person basis. For example, sb’s posts are usually important so I have those styled with a green banner and a bigger brighter font to make sure I’ll notice.
