Im sure I wont make more than 3pcs I have after lathe, and even they will take some time.
I think BLFers should contact Simon with this idea.
Yes all parts from convoy except head, glass and bezel.
Any regular 20mm triple board with any (one-side?) 17mm driver.
Honestly, I haven’t given it much thought. I just wanted a floody hiking light that is hands free and lightweight. My wife pointed out the the H03 might be too heavy for her head. It is nice to have other hands free light source other than a headlamp. Right now I just tie the H03 to her backpack strap.
Would be cool to have with 2*26650 or 2*21700 battery pack. Light but still has loads of juice. Those L-shape lamps are not for me. With so small mass can not get enough punch out of them.
Range 350m - high mode 2000lm+ continous.
There is many nice headlamps out but they all have something too little or too much For the same money you can get a much nicer flash light than a headlamp.
I think the closest to my liking is the Lupine Blika - 2 xgp and a xpl hi - range plus some flood for close work. Not too heavy or too big. But the price tag is wild wild…
I said plenty of good headlamps out there, you only want so much heat going to your forehead. The BLF lights produced so far are hot rodded, one of a kind(GT) as in size, or similar. The only headlamp I could think of is something like titanium with a copper heat sink but you have to keep weight in mind, nothing too heavy.
Not as many people use headlamps compared to regular flashlights.
Unless you can get a few hundred or thousand people interested, nobody is going to bother putting in hundreds of hours of unpaid work to design a custom headlamp for you just because you don’t want to buy something that’s already available.
The easiest option is to either make a custom one yourself, or slap a BLF sticker on a headlamp you can already purchase.
The problem is that most of people on BLF not need a headlamp. For example on Russian flashlight forum fonarevka.ru obout 20% of discussions are about headlams(here I see 2-3% at the best), and I know about 7 custom made headlamps at small-scale production and only 3 such flashlights. There are a lot of people who use headlamps in work,outdoor , fishing, sking, caving and so on. On BLF I see only lumens fans(some of them are Hicri fans too and I like it). 100500lm and 2km FET controlled hot rod with stepdown after 10s on ones head are absolutely useless in real world.
Nevertheless I would be interested to see as BLF headlamp for example something based upon H03 with hi efficient buck or boost driver with one of BLF UI , hicri led and maybe good build in charger, or maybe something in more exotic form factor like Panda 3 . Magnetic control ring also is very interesting element which can be very convinient, but almost non existing headlamp use it.
jon_slider has shown the existing passion for compact lights producing hobby/craft/camping illumination.
A HiCri hall effect convertible cap-brim edc headlamp in an E21a Quad with custom mixed/matched CCT, or the new colored (under 5000k.) Nichias soon to appear with matching specs sounds like a project Jon and Clemence were born for….and have already been working on.
It’s a WIP. Will post a build thread when it’s finished.
I don’t see why there will be SO much less takers for a headlamp. I mean the blf lantern has 900 listed. Lanterns and headlamps are king for camping. Headlamps can also be used for other nocturnal outdoor activities such as shooting, cycling, fishing. Anything where it’s good to have both hands free.
We do have a lot of Lumen Freaks and CRI Babies around here, but we also have a lot of members that just want the best possible mix of usability, carry-ability, nice UI, and run-time. It would be a worthy challenge to make a BLF headlamp that can pull in the best of every headlamp feature (not necessarily flashlight features).
A few days ago, AEDe posted this thread about the YLP Panda 3 which is a great looking headlamp. I even said in that thread that it’s the first headlamp I’ve ever liked. I wanted to buy one. But it’s only been sold in Russia (so far). Maybe we can take some inspiration from that one and make it even more BLF-ey! I really like kiriba-ru’s idea to make it out of common, moddable components. :smiling_imp:
For me the #1 reason to own and use a headlamp would be general work around the house (fixing, DIY, cleaning) but most importantly in the garage (almost any car related work would require a hands-free light, somehow). There is the workaround to own/use a light with a magnet but that is something I don’t have.
Finally, the easiest solution would probably be to get a headband/mounting solution that works for any light.
Yes. Emisar should make a right-angle Nichia triple, with an option for the elliptical Carclos so the beam is wider than it is tall when used as a headlamp. Until then, Acebeam, Imalent and Thrunite have options for those of us who don’t fear exploding death, with the upcoming TH30 having a claimed output of 3300 lumens.
But on a serious note, I’ve never heard of an 18650 exploding in a single-cell flashlight, nor any 18650 that wasn’t one of the Chinese YourhouseisonFire brands exploding in any flashlight. Obviously, these should be handled with due care, but FET triples aren’t pipe bombs as long as appropriate batteries are used.
My thoughts exactly, I think if BLF made a headlamp a lot more people would suddenly need one.
There aren’t too many 1x AA/14500 headlamps out there with a decent buck/boost driver and high cri LED that are light weight and mod-able. Plenty 18650 though.
It is matter of time.
The load in usual flashlight is not very hi, but people wants more and more. If we take a look at e cigarettes we will see what happens with 18650 at heavy loads
