Just installed 3x LH351Ds in my C8F from the last batch and shipments. They look too cold, I knew it at first sight. I've compared the beam against a 30° TIR equipped S2+ using a known good LH351D 4000K CRI90+ from the first set of shipments, I must have received 5000K CRI70+ emitters.
Could you please confirm if possible, AEDe? Thanks.
After a quick glance at 'em they look pretty similar. Will take a shot or two out of their strip packages later. Optics from the above flashlights are completely different, thus the comparison isn't fair. Colors look good but I don't have a known low CRI emitter flashlight :-D at hand now. Got me alarmed, though.
No need for photos, they're definitively orange. In fact just noticed the only unused and not orange looking emitter I have in my cardboard :-D cache emitter box is one of those 5000K CRI90+ XP-G3s (1 out of 46).
The second batch is an L6 chromaticity bin, ≈125K cooler than the first (L7). I am impressed by how much a reflector can influence the final perceived tint, beam corona looks yellowish while hotspot and spill are a noticeably cooler white.
Yeah, I got a bunch of lights where the corona is lemon-yellow while the hotspot is also yellowish but not nearly as much, and the spill is blue-white.
Anyone have an idea or guess how the Vf of the 351D 4000K 90CRI emitter compares to the Vf of the 219CT 5000K 90CRI emitter? I put 2 of the Samsung and 2 of the Nichias (from a D4) in a Q8 and visa versa. My impression is that output decreased a little in the D4, but tint, CRI, and throw improved. I don't want to push the Q8 too hard due to the 3 additional cells. I did turbo a bit and detected on no blue tint warning of overheating. I'm not a good judge of output, tint, and CRI by eye though. I'm assuming the CRI didn't actually increase, but it appeared like it did to my eye.
I really like the combo tint and CRI wise, but I don't want to fry one set of emitters due to significantly lower Vf. I really need to setup a heat sink with light tube and test each emitter, but I'm hoping someone in the know already knows.
EDIT: Clarified wording.
EDIT2: Caught typo (strike out above). Sorry for all the edit's folks.
I put 4 of the new batch in my D4…and I don’t like them
I see a green hue in the color. It’s a shame because the beam is way smoother than with 219C, there’s no artifact.
What’s strange is, I put another one in my Sofirn SP32A and the color is as nice as the old batch…
Could it be the AR glass ? Or the TIR ?
I keep meaning to order one of those kits but never seem to have the money when I am thinking about it and don’t think about it when I have some money lol
Depending on the severity of the green tint, which isn’t horrible with the LH351D, I’d say a Lee Zircon 804 is probably a good bet. If you want to make sure it lands on the rosy side, pick the 803 which usually fixes the XP-G3+d-c-fix combo very well. 802 is probably overkill.
That’s what I got. The 805 is very subtle though. I wouldn’t probably even fix something that only requires so little shifting. I’d probably go for the 802 instead for the extreme cases of green.
