I have been rushing to the mailbox everyday after work, nothing yet. I usually don’t to get excited about new lights but these, I feel like a 10 year old at Christmas.
Got mine via USPS today. Thanks! Can’t wait to get calibrating. Thanks maukka!
For those who are antsy (I was), it wasn’t in my informed delivery app, just showed up.
Thanks, that tells me I don't need to check the front of my house for packages after USPS has delivered the regular mail.
It fit in the mailbox easily. And I’ve got a regular sized mailbox.
Those who received calibrate lights should post lumen. Thanks
Why?
It’s only relevant for that particular light.
The S2+ sample light in post #1 (1301) was 270 lm @ 30s.
My S2+ (1303) is 267.5 lm @ 30s
I think he means maukka lumens vs TA test tube lumems
I’ll post the difference once I get my light. I’m not expecting any big surprise, though. I’m just hoping to dial my lumen tube in to a tighter tolerance.
I can increase/decrease the lumens by tweaking the 2 discs by the sensor. Or I can add some transparent tape to decrease it a little more. We shall see.
I’m super happy so far. I plan to test with fresh off the charger batteries over a few days to make sure i’m getting the same readings. Used an eneloop fresh out of the package with a 17-10 stamped on it, and a 30q that’s been rested for a few weeks.
Originally, I calibrated my sphere using a few lights I thought were pretty good to go. A GE led nighthawk floodlight (residential ac model), and a few off the shelf lights from olight and nitecore.
I ended up with a rounded multiplier for my 17”, BaSO4 coated, paper mache and fiberglass sphere of 0.20, using a Dr Meter LX1330B.
Initial tests using the newly received calibrated lights gave me 0.1965 for the NW BLF348 and 0.2085 for the CW s2+.
I will likely extrapolate the new variable multiplier, using a formula, based on color temp for all my other lights. With fixed points at the 6420k and 4862k my test lights read.
This is super exciting.
Here’s what i’m using:
I ended up with a rounded multiplier of 0.20, using a Dr Meter LX1330B.
I’m surprised those off the shelf lights got you so close. It seems for most people their calibrations end up reading too high.
The olight s10riii and m2r warrior are pretty close to spec. nitecore p12 was all over the place, based on the light’s setting.
I also measured and logged the blf a6, klarus mi7, a few streamlights, and a bunch of s2s, s2+s, c8s, l6s, l2s, q8s at all levels of modding, emisar d4, and a dozen or so others.
I weeded out the outliers and the ones that didn’t measure consistently, then averaged and averaged again. Then compared to all the reviews I could find on each light (some good (with fairly accurate lumens) and some not so good).
Luckily, I saved all my spreadsheets with raw lux numbers measured at start and at 30s, so now I can apply the appropriate new multiplier and have good data from this sphere.
Until the calibration lights, I was always pretty let-down by my numbers, since they were pretty low compared to others’. TBH, the TA sphere reality-check (once calibrated) was a relief. It made the hours I put into it a lot more worthwhile, since my numbers were pretty close.
I analyzed raw data for a number of years at work. I was an analyst by title and job description. Finding outliers and determining trends keeps me up at night if I can’t quite figure it out. A few years ago, I moved into a position using the data (from other people now, although I check it often) to drive people’s workload, and it’s more of a hobby now in this form.
Now that’s a cool DIY sphere! Getting +–3% was pretty remarkable.
But isn’t it nice to have some confirmation on your numbers? I know the uncertainty killed me before.
I know it sure caused me issues before I had these.
Having these lights a few years ago would of literally saved me 6+ months of tinkering with my sphere.
Finnish lights finnish their journey. Got mine today. Thanks again Maukka. Can’t wait to play with these guys.
My long anticipated package from Finland came today. Time to go dial in the tube.
Thanks Maukka for offering these great tools. :+1:
Maukka sorry for bailing on my order the other week. Sign me up again, my wife bought me a prepaid gift card to use since we don’t use credit cards in my household. I should not have an issue with waiting to pay. My apologies again.
My lights arrived maukka. Thank you again!!
Looking forward to using them……
35.6 (calibration sheet)
diff = 1.7% (note the meter doesn't read tenths at this light level, so this is an approx)
My other calibrated lights:
Nice results, Vresto and Terry.
I’m not a great fan of the tube design light measuring things, getting results truly independent of beam pattern of the light source does require a (well-built) sphere design, but I must confess that getting the TA tubes around the forum, and combined with maukka’s calibration lights, that seems to have helped hugely getting the calibrations on the same page.
Good enough for almost any BLF discussion, and the last few percent is too much pain to achieve anyway.
Thanks a lot for sharing your results! Getting results even within 10% between different setups is very beneficial to the community. Next step: bare emitters and aspheric zoomies for calibration
