I can’t get a decent picture but a measured 1.500 mm diameter Trit in a 1.385 deep slot should only stick up .115 mm or .0045 inches, but it seems the Trits are sticking up between .33 and .47 mm, (that particular kind of measurement is very difficult to do consistently with verniers, even decent resolution electronic ones). It doesn’t sound like much, but is quite noticeable when you run your thumb across them. One sticks up a little farther than the rest, maybe that slot was even shallower, as I only measured the depth of a couple of them and it’s too late to re-check that one now. It could be that the Trits rose up as the adhesive shrank while it cured as I only held them down for the first minute, until I thought things had firmed up enough. Again I’ve done more than a few Trits, and if there was a tendency for them to raise up .3 or .4 mm as the adhesive cured I wold probably never have noticed it before as all my other Trit slots were way deep and the installed vials are still more than.4mm below their surrounding surfaces.
The SC26 Trits do NOT contact anything if you put the light down on its side on a smooth flat surface because the front of the light kicks up a bit, but any objects/clutter on the same surface could give them a bump, as could an adjacent light in a bezel down vertical storage scenario.
I used a Norland UV curing adhesive, NOA 61, and cured it with a 365 nm Nitecore GEM8UV. Norland claims a “Linear Shrinkage” of 1.5% with that adhesive, which I never considered excessive.
Thanks, I use the same adhesive and will probably add some ice blue trits that I have left over to my light but my UV light is dead so I have not tried to mount them. A little disappointing that they stick out above the surface because if they can be broken I usually find a way to manage it
Received my blue with XHP35 HD CW today. Somewhat disappointed in the blue color of my example as it’s a deep navy blue, (almost black in certain light), as opposed to the beautiful bright blue freeme showed with his example.
Other than that, the light is flawless. No flaws at all in the body, lens or reflector and a beautiful pure white beam with no hints of blue or green. Just the way I like it in my lights. It’s as beautiful a beam as in my D1 and that’s saying something.
It came in a box with cutouts for another light but no big deal. I agree with another poster about the ramping being kind of slow, slower than my D1 but again, no big deal.
The switch is a little “rubbery” or “squishy” feeling but I can live with it.
I have a Butler Creek Blizzard flip open scope cover for this on the way that I’ll apply the diffusion flim to like I did with my D1 which will make the light even handier.
Al in all, this light and my D1 are true BUDGET LIGHTS! With all you get for under $40.00 make these true bargains!
I noticed that about the depth of the trit slots right off.
I took my SC26 that arrived earlier today out to play this evening and and was surprised at how tight the beam was, considering I ordered a HD. Looked closer at the LED with a magnifier, NO DOME. Checked the box XHP35 HI. My invoice clearly states “Design: XHP35 HD NW” (at least they got the NW right). My bad for not checking everything out thoroughly before I installed the Trits, lesson learned (yeah, sure.)
I want to try something different… nw is actually not that bad… i use these lights for the short range between 50 feet to 200 feet… nw is more easy on eyes and doesnt bounce back bright white light like a cw.
I just found out nw is good for indoor lighting such as warehouse, rooms, and even trees…
Honestly, there is not much difference between the two beam profiles. My HD has a more pronounced corona around the hot spot, my HI has a bright hot spot that fades to the spill with no pronounced ring. My personal thought is the reflector style/design with the domeless HI emitter produces a better beam.
Here you go. The trit sits .55mm proud. Which means, the slots are only about 1mm deep. I didn’t install the other 5 because of this. However, the single trit above the button, makes finding the button at night easy. Used Norland UV adhesive, cured for 3 minutes.
One trit is probably the best idea for someone like me, if it can be broken I will find a way. Will have to wait till my new UV light gets here. I killed the last one :person_facepalming:
I like the color on the SC26 NW alot too. It looks about 4700k with no green. I think most people hate NW/WW due to the yellow, which is really because of tint being above the BBL resulting in greenish/lime/yellow. I am a WW/NW fan but I can’t stand yellow or green so the tint is as important as CCT. I think 4000k to 4500k works best for outdoor wilderness use as it simulates daylight colors the most to my eyes. I compared side by side with CW inside a dense forest and CW makes colors washed out and pale whereas NW with HI-CRI gives the forest life and colors are much more vibrant and saturated like it appears in daytime. However, with the Skylumen Delta, I’m kinda starting to like CW (with little to no blue) for throwers. It looks freaking intense.
