I'm working on upgrading my black M8 with a TA NarsilM driver - will keep the stock NW XPL HI in that one. Had to rotary tool/sand down the driver to fit. Just got in a green one, and same as above - definite cooler tint, hold to toggle thru modes, 2X click to turbo. Single click to lo from off. Single clicks are frustratingly slow to respond, least for me. I'd be dead all the time in COD if my gun responded this slow...
The LED in my green one is definitely not a 6500. The UV light does not lie - it shows a fair amount of glow, so I'm guessing about 5700.
Here's what I measured, using my PVC lightbox somewhat calibrated against high end rated flashlight.
Black M8, stock, on EFEST 4200 @4.16V, lumens: 945 @start, 880 @30 secs, 101 kcd (636 meters) taken at 5 meters
Green M8, stock, on blue LK 5000 @4.20V, lumens: 1160 @start, 1100 @30 secs, 120 kcd (693 meters) taken at 5 meters
This sort of makes sense now. The 1200 lumens and 800 meter rating is inflated of course, as usual, but the CW version seems to do wayyy better than the NW version in output and throw.
For the black M8 modding, the switch on the black M8 is given me problems - it's not your standard 4 wire wiring for 2 color LED's. Normally: Grnd, switch, red LED, blue LED, but this switch uses 3 wires:
switch, 1 wire on grnd side of LED's with LED's wired in series (???), and 1 wire than feeds the LED's and also has a 10K resistor to the other side of the switch
I dunno exactly what it's doing, but seems like it's pumping voltage across the LED's in series, where the blue one engages over a certain voltage, and the RED engages under that voltage. Might just punt on supporting the LED's, and jump the resistor to get straight simple access to the switch.
Hhhmmm. Might have to re-think keeping with the stock XPL HI. I got XPL HI V2 5D's in from Hank which are probably a higher bin and better or equal tint.
Finished the mod - does about 1450 lumens, 145 kcd or so, with stock LED/Noctigon. 20 AWG LED wires that are long enough to re-flash the driver without de-soldering wires, bypassed both springs, TA 30 mm driver sanded down to ~28 mm.
Newer Green M8:
The new green M8 is different in a few respects:
no more clunky snap ring driver retainer - glued/press fit ring that must be poked loose from the top thru the wiring holes. Mine came off fairly easy though. Driver is glued in this ring (ring appears to be brass plated??), but again, not too difficult to hammer it out with couple light taps on a nail set type tool.
driver is totally different, not just firmware modes. Now of course it's USB-C, but other parts changes. Driver size is still bout 28 mm, still do-able with a TA 30 mm driver sanded down, then press fit into the brass plated ring.
No longer using a nice Noctigon, now it's the cheap copper no-name, usually these are not DTP - didn't check yet.
battery tube is very slightly wider in the interior so standard LK's fit, as well as old protected TrustFires and KeepPowers fit fine now
uses a black LED centering piece, while I think the old M8 used a white one (not 100% sure though, might have mis-placed it)
looks like the same 3-wire weird switch/LED wiring... ugh!
The new green M8 tube and tail cap LEGO with the black M8, so seems like no changes there. Please note the driver spring appears to be Hank's (IOS) high quality Beryllium copper ones -- match exactly as best as I can tell, but the tail spring is different, probably typical gold plated steel.
I modded NarsilM to work on TA's triple channel driver without the bank of 7135's so it behaves exactly like a FET+1 driver (Q8, Emisar, etc.).
This light reminds me so much of the ol XinTD X3 which I really like, but improved in many ways -- not as heavy, smaller, and of course the e-switch which I always prefer. Almost seems like Hank was passively involved in this light, like the XinTD's.
Just got my green Maeerxu in. Same as yours. No ramping, mushy button. Most of the modes don’t work anymore like the 6 click lockout. It has no lockout mode anymore. Ugly 7000k 6000k+ cool blueish white now.
I actually like the low, med, high, turbo cycling by holding the button down. It has no memory, and neither does the original black one. But at least the original ramps quickly to a usable level. (for my use).
It has a USB-C port instead of the micro USB. I don’t know if it includes the fast charging circuitry or that it’s just the connector. The older version worked fine and was plenty fast charging.
Nothing seems glued, so an emitter swap should be easy.
Original Black Maeerxu on the left, New Green Maeerxu on the right.
Emitter swap looks straight forward. Standard 20mm MCPCB
Can you ask them how they got 1200 lumens and 800 meters (160 kcd) for throw? The new version is closer, but not there, specially for throw.
Good upgrades
more lumens and throw
wayyy better battery tube that accommodates most/all 26650's
USB-C
Bad upgrades
mushy button
LED tint got cooler
looks like they downgraded the MCPCB, Noctigon to no name, possible non-DTP
The change in driver mounting could go either way, as well as the UI changes...
I'm using the old head on the new battery tube - works great, but a little pricey... Please, if we could get a replacement (new) battery tube for the old lights...
Thanks Freeme. I don’t know why it wouldn’t be in focus. Just a xpl-hi LED sitting on a flat surface on both.
I figured out the features, but good to know about the long press from off to go to last mode. Still no button lockout, but not a big deal. Just switched it out to a 5000k xpl-hi on a noctigon. Looks great now. (focus is fine)
Yep, got an old black, new green M8, one each. The new tube fits every 26650 I got, so the black LK's shouldn't be a problem at all, though i don't have one to try.
Mods:
TA 30 mm driver sanded down to 28 mm, configured as FET+1, good Hyperion FET. Modified NarsilM to add compile option to use FET+1 on a TA triple driver -- I did this to save on my good 7135's because I don't know of any source selling them. Also the FET+1 firmware ramps smoother then the 3 channel setups.
20 AWG LED wires, long enough to re-flash the ATtiny85
bypasses on springs
re-used the stock LED (great tint) on a nice Noctigon (stock)
USB charging is gone, and switch LED's are not sued because of the funky weird factory wiring of the switch PCB
Results: pulls 5.9 to 6.0 amps at the tail on a blue LK 5000, lumens: 1580 @start, 1510 @30 secs, 148 kcd taken at 5m
Right now I'm using the green tube on the black head, til I mod the green head. Probably go with a domed LH351D though - not emphasizing max throw on this one.
I got the LK blacks on order now from that Ali store, but like I said, all my other LK's, Shockli's, and re-labeled LK's fit fine in the new green tube.
Thanks for info Tom. BTW, did any of you an damaged box with the cracked optical lens? I got mine flashlight that way. No way for me to post since photobucket no longer exists.
My lights arrived fine, no cracked lens, but I have ton of spares. Boxes always seem to come beat up - can't keep track. not sure I kept originals.
Ahh, my photobucket account is still in tact - no probs, but I do pay $$$ for it. Have you checked out other photo hosting sites? I know others here use other hosting services.
Tom, My box came shipped inside a air bubble envelope. Hence the cracked lens. As far as photobucket my account was canceled because lack of use. Now you have to pay for it. No thanks. The service was not that great anyway to begin with.
