The first XM-L T6 bin flashlights and P60 modules. This is the beginning
LOL! I just read it again and still believe the dedomed (say that 3 times fast) was stable at 3A but got killed at 4A. Yeah I know... it needs much more testing on the bench, and over a much longer duration. For the price of XM-L's, a few shortened hours of life wouldnt matter much to me. Besides, im beginning to love my soldering iron! I have a MRV that I popped the dome off of (XR-E) and it has lived many hours of continuous use at 1.6A. Maybe its the luck of the draw, and also how well sinked the emitter is. Either way, this new emitter seems to be putting some of the anticipation back into our hopeless sick disease.
You got it!
Hopeless disease is about it....
I think the more immediate risk to de-doming is that the gelatenous stuff that's the under dome becomes unprotected and also host to the phosphor. I de-domed a cree and even after immediately putting it back on, it wasn't quite the same as before.
Like you, I removed my dome by accident and tried to stick it back on. The beam was so ugly that I just removed it completely. I took a toothpick to the gelatinous stuff and it was easily removed.
I will see about ordering from Ebay , [ bare emitter ]
The P60 pill is $20 now ... So you may want to buy a 502B for $25
the 16mm base will be ok for P60 builds , but for smaller EDC lights ?? , 14mm would be better ... Just waiting to hear back from the ebay seller ....
let us know!
i want 14mm!!!
ill buy a crap load!
The ebay seller only has them on 16mm basses , I have ordered 2 to play with ...
Now which lights will become XML ? hmmmm [ Solarforce L2X @ Ultrafire A20 ?? ]
Another one just popped up and its in one of my favorite P60 hosts.
RQ 07 Cree XML T6 1000 Lumen 5-Mode LED Flashlight (1*18650) SKU: S009851
Cree XML T6 1000 Lumen 5-Mode White LED Flashlight (2*18650) SKU: S009850
What kind of beam pattern is that? Just a big hotspot with no spill? Or all spill with no hotspot? Or just a bad picture? I'm not sure what you get with a flat-bottomed reflector like that and a big LED like this.
Bad picture. It's the same type of reflector as any other. The flat base does nothing. The hotspot will be small because the apparent area is large, if the emitter is well focused.
I can't wait for reviews on some of these lights!!
Well, I guess this will take longer. I'm waiting for a DX package. It left HK today, after it was sitting there for five weeks. Horrible!
Know the problem. A DX order on October 11th left HK on 2nd December and will now be in a PO truck somewhere here. But an order from Australia arrived in under a week.
As of now, XML is much more expensive than XPG.
To all of you much more experienced: I do not want a new flashlight now, but will probably buy one in the not so distant future. Will the price go down in the next 6 months?
Also, is there any hope for a well driven XML 14500? Or the 14550 is simply not powerful enought?
with 14500 you will not have the full power of the XML. With 14500 you will have to use IMR cells... and the runtime will be poor.
However, a 14500 flahslight, with a driver limiting current at 2A with 14500 and XML is possible, More than 2A on an standard 14500 cell .... possible but not recommended
I will put a XML into my A20 [ 16340 ] , for a pocket rocket .. @ 2A ?? Hopefully 1.5A as it does 1.5 with the Q5 ATM , so if I can get 2A with my better 16340's .. It will rock for a EDC ..
I think the price will come down some in a few months as these become more widely available. Because the LED die area is larger, I don't know if they will ever come down as much as a XP-G.
It's a higher bin at 350mA, so at any current, the XML will put out more light. But I imagine the hotspot won't be as bright as the XP-G, which wasn't as bright as the XR-E or XP-E. But if the current isn't regulated, it would be like runnning a XP-G from a 10440 and suck the life out of a 14500 in no time.
Cutters prices have gone up !!! Used to be $7 for a XP-G now almost $10 .. With the Ozzi banana going up in value the price should have come down , but not so ..
First XM-L mod beamshots I've seen
In an RQ thrower. Direct drive.
Since I have a defunct HS-802 this looks interesting....
http://www.light-reviews.com/forum/viewtopic.php?f=8&t=927
