(prototype) the GT Mini
1637 posts / 0 new
DeusLight
Last seen: 10 months 1 week ago
Just received my GT mini a few minutes ago! It looks great.
thijsco19
Last seen: 1 week 4 days ago
Received it today. Very good looking light. Really love it how much it looks like the GT!
h5550
Last seen: 23 hours 23 min ago
received my GT mini Thumbs Up Big Smile
Nicolaas
Last seen: 1 year 1 month ago
Got mine today and I love it!
Finish is great
Threads are great
Reflector is great
AR coating is great
NW – bordering WW – is great, same as on Big Brother.
Short tube is great
Throw is great – especially for its size.
Packaging was also great: light in foam in a Lumintop box, that box wrapped with bubblefoam put in a plain box, with plastic over it to protect against moisture!!
Cheers,
Nico
severide
DB Custom wrote:
Bezel glued on with Blue Loctite on my production sample. Gonna be a bear getting off it you don’t have significant tools to attack it with.
That is unfortunate… whyyyyyyyyyy
thijsco19
So, DB you’re saying that I’m as strong as the hulk?
I just opened my GT mini with my bare hands! Big Smile
Fortunately, though I do see some signs of loctite on the bezel, it was not enough to glue the bezel!
Unfortunately, while putting the bezel back on something weird happened.
The led separated itself from the mcpcb!
JasonWW
JasonWW's picture
Last seen: 4 hours 32 min ago
Very odd. Maybe the plastic centering ring is gripping the reflector too tightly?
Is there an o-ring preventing the reflector from spinning against the glass?
thijsco19
Looks like the centering ring and reflector are indeed tightly together. Same as the led in the centering ring.
Also, even if there was an o-ring it wouldn’t prevent it from spinning against the glass. Rubber will have much more ‘grip’.
Normally the glass will spin against the reflector or the reflector will spin against the centering ring to prevents this from happening.
Nicolaas
Well, the bezel isn’t glued in my light, maybe just luck?
Anyhow, I did some tests today, using a 3 year old Efest purple INR2500 (I think the 2500 LG cell is in there).
So, not the latest and greatest cell there is but still!
Measured at 10m for easy calculations using my cheap LX1330B luxmeter I got:
At start @ turbo (double click) 135Kcd
After approx. 30 seconds 130Kcd
After 30 seconds at maximum ramping 78Kcd.
Mind you, using what is certainly not the best cell and my light is “NW”, but I would rather say it’s WW (same as with my GT).
It could very well be that using a truly CW led it does better.
The light gets quite hot very quickly so it looks like the heat transfer is good as well.
Cheers
Nico
mortuus
mortuus's picture
Last seen: 7 hours 9 min ago
NW its using 4000k tint ? how yellow is that ? also when its hot does it burn your hands like d4 can?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Nicolaas
It’s not “yellow” at all, just very NW Smile
The nice thing about Cree’s “flat dome / HI” leds is that you have no awfully discolored corona and the tint difference between
spot, corona and spill is much less apparent then with the normal cree leds.
My guess is that the XPL HI use is a bit below 4000K but maybe member Maukka can do a real color/CRI test?
It gets quite hot quickly but (luckily) the build in temperature step down steps in, in time.
The comprehensive manual lets you program the step down as well but I like it the way it is.
The only thing I turned of is the green light under the switch constantly glowing.
Cheers
Nico
teacher
teacher's picture
http://budgetlightforum.com/comment/1347077#comment-1347077
M4D M4X wrote:
GT MINI is 4000K and 6500K
Yep.. it seems 4000K was the plan anyway.
Glad I went with CW on this one. Wink
mortuus
mortuus's picture
Cheers
Nico
ok thanks for info, looking forward getting my nw.
              つ ◕_◕ ༽つ
djozz
djozz's picture
Last seen: 9 min 55 sec ago
On my way home, tracking says it is delivered to the neighbour. If I can retrieve it I will measure colour temp.
djozz
djozz's picture
Got my GT-mini (NW) and it is a really nice well done light, even nice for actual use! Shocked
The beam is great, as perfect as can be achieved by a medium size smooth reflector and a XP-L Hi, perfect centering and focus, very nice distinct small hotspot with useful corona, no apparent tint shifts. Just the center of the hotspot shows some yellow, a common flaw of the XP-L Hi, has nothing to do with the quality of reflector or host (some leds cause it, other leds don’t, never got it explained by anyone)
The colour temperature I measured 3950K for both hotspot and spill, the hotspot a littlebit above the BBL, the spill on top of the BBL. So at least my copy is pretty exact 4000K.
If I could change anything, I would improve the feel of the switch, it is ok enough but a bit mushy. And a flat bezel from SS of course.
DB Custom
DB Custom's picture
Last seen: 1 week 16 hours ago
Wow, I wonder if there are different switch boots… I find mine dang near perfect!
M4D M4X
M4D M4X's picture
Last seen: 27 min 34 sec ago
great Beer
 all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
djozz
djozz's picture
Stock on a 30Q@30seconds:
129 kcd (measured @7m)
1330 djozz-lumen, =~1240 real lumen
So it pretty much lives up to the specs Thumbs Up
djozz
djozz's picture
Hmm, fiddling with the light a bit more, and now I have switching problems, it seems that the switch does not make good contact, have to press several times to get the light on and off, and same for ramping. So possibly a mechanical thing. But it could be software too.
Me and GT lights seem an unlucky combination Sad
DB Custom
DB Custom's picture
Maybe they didn’t get the press fit retaining ring pushed in all the way? Mine really works nicely, very reliable. The switch is mounted on the driver itself, the rubber boot is or should be in a fixed position relative to the switch, so if it’s acting weird it’s going to either be a loose press fit retaining ring or a loose switch on the driver. If your bezel isn’t glued that’s easy enough to find out and if you can get inside then you should be able to tell if the switch is mounted solidly on the driver.
djozz
djozz's picture
My bezel is not glued so I will do some digging. I’m not very happy though, it is way nicer if a light works and feels reliable out of the box.
DB Custom
DB Custom's picture
Really odd how some are glued hard, some glued lightly, and some not glued at all. VEry strange. Mine had great gobs of Blue Loctite in the bezel, had to mount it in the 5” chuck on my lathe and use a pair of 16” channel locks to break it apart, even then it did not want to let go.
JasonWW
JasonWW's picture
Maybe the driver is turned a little bit too much. It seems the two ears allow for a little rotational play.
Looking at the driver, are the 2 black dots perfectly lined up with the exterior switch?
Maybe your driver needs to be rotated just a tiny bit?
djozz
djozz's picture
The dots line up fine. And the switch clicks fine as well, you feel a good click and you hear it too, the response to the click (or hold) is just not there, as if the contact surfaces inside the switch are very dirty or something. But I’m not going to solve this tonight, tomorrow there is another day!
DB Custom
DB Custom's picture
Even after being removed the driver presses back into a snug fitting position, even after a few removals. So it at least doesn’t get all loose and floppy after the glue is broken at the driver shelf. And yes, there is that bit of like Elmer’s glue holding the driver in place, ears/tabs or not, the driver isn’t shifting around not even after being removed.
G’Luck Jos….
MRsDNF
MRsDNF's picture
It sounds like the switch itself has dirty contacts. Maybe a tiny squirt of contact cleaner may help.
DrDevil
DrDevil's picture
Last seen: 47 sec ago
I would say, as mentioned elsewhere here, Beam and output from the BLF GT mini and the Emisar D1S is nearly the same
(BLF GT mini on the right on the third picture)
mortuus
mortuus's picture
but the mini gt is smaller and more compact, seems like a better choice Smile
              つ ◕_◕ ༽つ
DrDevil
DrDevil's picture
O.K. you got me Smile
It was an attempt Innocent
JasonWW
JasonWW's picture
About the only difference I see is that the GT Mini has a bit tighter corona.
DrDevil, do you have a lux meter? Have you done a side by side candela measurement?
Seperate reports have shown they should be about 130kcd to 135kcd. It’s not like anyone could see that difference, but I was just curious to see both measured with the same meter and under the same conditions.
