Emisar D4S review
Ever notice how, when a manufacturer picks up the gauntlet and offers something new everyone screams MORE, you shoulda, you coulda, you oughta…… ?
Thank you Hank, well done! :slight_smile:
Red backlight looks sweet, I’m going to hold until new color shows up.
Personally I would’ve preferred a green mimicking tritium but brighter, but blue is pretty too.
I think the cyan will compliment the smooth green perfectly! :sunglasses:
Owner of this specific D4S said Hank custom made for him. However, when I e-mail Hank about the custom aux LEDs D4s, he replies “I’m afraid we are not able to offer such option.”
May it is just for China customer or for Hank’s group members only.
The aux LED board uses some common cheap LEDs and they shouldn’t be incredibly difficult to swap out. It’ll be useful to have hot air or a wide solder tip for unsoldering the stock LEDs though.
It looks like it uses the same type of LEDs as several of the clock kits floating around lately. I don’t know what type they are, but they can put out a lot more light than what the D4S does with them.
Sorry, are we still talking about lady toys?
Easiest way is to use two solder irons. Hold them on both ends and lift the led.
On the other hand it’s an excuse to get an hot air station :wink:
These LEDs don’t have much metal to grab onto, so I’m not sure the 2-iron method would work unless you have a third hand to grab the LED from the sides at the same time. That method works with resistors and capacitors, which typically have a metal surface to press the iron against, but I haven’t found these to work that way.
Putting them on the board is easy, but getting them off without destroying them is difficult.
This pic, when zoomed in, might show enough to explain why:
Solder wick might work!
The great thing about this design is that the secondaries are all on their own little separate board. So you pull the board out of the light, toss it on a hot plate/stovetop/frying pan/whatever, heat gently, then when the solder flows you just flick every one of those things right off. They look like 0805’s to me, same ones many of us use to build lighted tailcaps, so pretty easy to find in lots of colors to drop back on.
Obviously you’ll have to work kinda quick and watch your heat or you’ll be burning the mask off of the board, but I don’t expect it to be a very hard mod at all.
they are 0403 LEDs a lot smaller than 0805 (roughly 1/4 area)
but handable compared to 0201
Looks like Outdoor refunded the 26650 i purchased with the light, i know low stock was mentioned, but any one else or something to do with shipping to Australia. i noticed they are still selling instore.
LiitoKala store charges $27 shipping.
[quote=Lexel]
Then you need nothing special, a single soldering Iron + a blob of solder will unsolder these without any problems.
But if I look at this board - one resistor, 16 tiny LEDs and a very thin PCB - buying those in different colours should be very cheap
Ah, thank you for the correction. I’ve only got 0805 and 0604 on hand, so guess I need to place a parts order before my light gets here.
0403 as if I dont need more stress
[quote=L4M4]
I like the way you think! Just get it done.
Now to track down some 0403s.
Regarding color, it seems like I read somewhere on one of millions of threads that the color green is the best for signalling or seeing in a busy environment because something to do with how we see colors. Does that sound like BS?
I intend to use the secondary emitters for location purposes only. Other people may be handling it or it may get jumbled into the mess while camping or something. Wanted to put a color on that is most conspicuous to our eyes.
Also, if anyone hasn’t had the luxury of using a battery with this capacity yet: if you don’t try to light up the night it will last for an amazing length of time. Unbelievable.
Finally, for size reference, if anyone has a Convoy BD06 this is very similar in size if you were to cut the head off the BD06 at the groove directly above the switch.
I am a novice but I would like to replace led to red.
I have some 0805 led they measure 3.21mm x 1.5mm.
That leads me to believe that the 0403 led is less than a millimeter,that seems too small??
Where do you get the 0403 LED’s at Lexel?
