The ones I assume u speak of are unprotected , plus I’m sort of loyal , this ebayer is great and always fast compared to most Chinese , just my experience
Yep, same cell doesn't necessarily mean same performance, if any of the other components are different. If nothing else, it would be good to know the specification of the protection circuit - it was after all the PCB that let down the first batch of intl-outdoor cells. Does the PCB allow a 2C (or more) discharge rate, or is it limited to only 1C?
Same trip, means same number and probably same model of mos. The only difference is that one of Redilast cell displays a very good curve compared to the other NCR18650A cells, at least that is the case with one cell, the the other doesn't match it. But that is normal. How knows, Jason picks them better.
Redilast 5A 2728mAH
IOS 5A 2723mAh
Theses highest two results on 5A discharge from all the protected tested by HKJ.
I did contact him and the $2.96 credit is really not a good decision as far as I am concerned. The batteries should have been replaced with the proper " as advertised" batteries. No questions asked. As it stands right now, I am really not happy with the current "solution" to the problem. I don't expect anyone to deal with the "bad battery" except me. You took it upon yourself to post this thread and post the solution to the original issue, so it appeared that you were promoting int-outdoors. No problem. No harm, no foul.
Any news if the first buyers will get a better price?
I need four of them, but for this price I would rather buy them somewhere else with a better price without discount, but to be fair they have not been tested yet.
