TrustFire F22 Stainless Steel Cree XP-ER2-WC 5-Mode 220-Lumen Memory LED Flashlight
Overall Rating: ★★★★★
Summary:
Battery: | AA, NiMH, 14500 |
Switch: | Reverse Clicky |
Modes: | 5 |
LED Type: | XP-E R2 |
Lens: | Coated Glass (Says DX) - Feels like plastic |
Tailstands: | Yes |
Price Paid: | $22.85 |
Pros:
- Bright
- Neutral colour of beam
- Tight hotspot
- Well made
- Plenty of O rings (GITD!)
- Lubed threads
- Not a hand burner unlike some other stainless steel lights
Cons:
- Switch needs to be hit dead centre or can stick
- Enormous for a single AA light
- Heavy (It is made of steel after all)
- Thermal performance, stainless steel is a less good conductor of heat than the usual aluminium
Features / Value: ★★★★★
A nice 5 mode setup. Sequence is high, medium, low, strobe, SOS. I like stainless steel lights a lot so that's an automatic bonus mark. Comes with a much nicer lanyard than is usual. I can almost get it over my head. It is made of some sort of elasticated material.
Comes with a silly "Assault Crown". Some may regard this as a bonus. I don't. Fortunately it also comes with a more sensible bezel and now that I've photographed it, the silly bezel can go in the bin.
Lettering looks a little odd at this magnification though I'd never noticed this before. It helps having a better camera for doing closeups.
Build Quality: ★★★★★
The threads are rather nice.
The O rings are, as you can see, made from Glow In The Dark (GITD) material. I really wonder why. These probably cost a bit more than non-GITD ones and are never going to be exposed to light, so why bother? The light came lubed as you can see by the grime on the front O ring.
This has been bashed around in my pockets for a while and still looks good. The centre brass (at least I assume it's brass) ring is also to be found in its stable mate the Trustfire F23
Note the cutout for the split ring so that the light will tailstand. Simple idea but all too many manufacturers don't think it through.
It is on the big side though, here it is with some other lights.
Aurora SH-032, Trustfire F22, Akoray K-106, Tank007 E07. All but the first are AA lights.
Battery Life: ★★★
Like most such lights (i.e., lights capable of being used with a 14500) this one really isn't alkaline friendly. Runtime to 50% on high is 27 minutes and 45 seconds though it gives usable light for about an hour. Not really regulated, which is not unusual for alkalines. The output is roughly 85 lumens on high with an alkaline.
Alkaline Medium. Starts at about 45 lumens on medium with an alkaline. Usable light for about 2hr 15 min.
Alkaline Low. Around ten lumens. 12 hours to 50%, usable light for around 16 hours.
NiMH runtimes. All done with a 2000mAh Eneloop freshly charged.
NiMH High - 64 minutes to 50%. More than twice as long as an alkaline on high. Initial brightness is much the same as on alkalines, around 85 lumens.
NiMH Medium 120 lux on lightbox at start - somewhere in the area of 30 lumens. Now rising to 200 lux / 45 lumens or so. Need to clean some contacts before next run. 2 hours and 25 minutes to 50%. Usable light till about 2:45. Some light still being emitted at 3.5 hours, i.e., I could see that it was still emitting light.
NiMH Low -- a bit disappointing this one 9hr 13 min. By 9:30 no light at all. Initial brightness around 9.5 lumens. It did occasionally muster enough current to produce a dim flash - too little light to register on the solar cell. About once every 20 seconds. These runtimes are usually done unattended, often while I'm asleep so the light may flicker or flash for low battery
14500 high. Approximately 220 lumens at switch on, approximately 160 lumens after 30 minutes. I think the cell protection is cutting in early, it was still producing over 150 lumens when the cell shut down.
14500 Medium - 490 lux or about 110 lumens at switch on. 96 minutes run time and still at 67% of initial output when the cell protection cut in.
14500 low. Cell protection appears to cut in at about 2.95V - may be lower as you have to give it a blip of charge to switch off the protection circuit. 7hr 39 min to cut out- pretty much as expected from the current draw.
Light Output: ★★★★
Quite a lot - will run the meters and get numbers. Here are some beamshots I took a while ago. The test range has become rather more reflective again and more snow is forecast.
Control
Low. At last I have found the measuring tape. The apple tree is 15.5 metres (Just shy of 51 feet) from the light and camera.
Medium
High
Summary: ★★★★★
I like this a lot. Despite its rather large size. Here it is with an 18650 and an AA
The switch is the only real irritant - it can stick when hit off-centre.
Overall definitely worth five stars. the only drawbacks are size and switch.
