Do we know the size of Emisar’s aux LEDs for sure?
Edit: I don’t have good tools for measuring things that small, but I think Emisar might be using 0603-sized LEDs. I’m seeing about 1.7mm x 0.8mm. They appear to be smaller than the clock kit LEDs, which I think are 0805.
It’d be nice if these things all used metric units, instead of inches.
Not in that context eas, but when they hold off buying til the impending next revision, already sure at announcement that there will be changes, then things get a bit wonky.
My sense is that, at least among likely buyers of Emisar lights, the % of people who will wait for an anticipated update is relatively small compared to the % who will buy one now, and one later.
You can usually reflow a 0603 on a bigger 0402 footprint like I am using
this is what I did on my new Generation 3 tail board a dual footprint, I changed the wideness of 0402 a bit
on the D4 I had to use normal 0402 footprint as its very limited space
I found this info on the WWW.
SMD LEDs are available in four sizes, which are designated 1206, 0805, 0603 and 0402 . 0402 is the smallest, with overall package size of 1.0 mm x 0.5 mm x 0.45 mm (L x W x H). Then 0603 at 1.6 mm x 0.8 mm x 0.6 mm. 0805 are slightly larger, at 2.0 mm x 1.25 mm x 0.8 mm.
I measured the 0805 at 3.21 x 1.5,I measured from flange to flange on the bottom.
Looks like they are all available for reasonable price.
There’s probably a thousand components that size in my cell phone or other consumer electronics, but I’ve never come across those tiny things in stuff I’m building myself, and I hope I never have to. No thank you.
So did we arrive at a consensus on size? That comparison photo with the ruler only shows tab flanges on 0603 and larger sizes, and I’m pretty sure TK’s pics in the very first post of this thread shows flanges on the LEDs. So I’m thinking they’re probably not 0402s…which is good. But I’m not sure that’s definitive either. I’m prepared to wait and see when my light arrives, I’ve got both 0603 and 0804 on hand already, but I don’t have any 0402s here to try if that winds up being the right answer.
I’m going to buy & im going to wait then I’m gonna buy another color then wait then buy one last one then wait and probably get a titanium version then wait then get one off of someone that doesn’t like theirs then wait…
Hi guys has anyone got an email confirmation that there D4S has been shipped? as mines been saying it’s processing since I ordered it 6 days ago. I was under the impression that they were going to be shipped before the 10th August is this still the case?
Sometimes when you order from Intl-Outdoor it seems to be sitting in processing forever and all of a sudden it’s in your mailbox. Don’t know why that is…
Very excited about this light. Held off on the Emisar D4 because of the quick thermal step down. Looking forward to see user reports and first impressions.
Several questions for you guys.
Which one (Nichia, XPL Hi, etc) have you been ordering?
The Nichia runs hotter and is less bright than the XP-L HI. But what about when the battery is at half capacity, with less voltage? In this circumstance, since the Nichia has a lower Vf, does this not mean the Nichia will have a better “regulated” output compared to the XPL - HI without significant drop in output?
In other words, other than CRI and TINT, does the lower Vf of the Nichia have any advantages over the other emitter options? Do the lower Vf LED’s have advantages with certain drivers only (ie, Boost, Buck, Linear, PWM/DD)?
