[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
The magnet does look a bit small to me, I really like the robust magnet of the Manker E02. But if it works, it works.
Derived from your design: you can do the same with a trit hole instead of a magnet hole, a trit hole fits easier even.
So stealing your idea :innocent: I wil make a drawing in a moment (after I put my son into bed)
I checked the retention forces with the help of a couple of (German) online shops which sell high quality magnets. It could of course be that some random cheap magnet of the same size is weaker. And of course this is all just "in theory" one would need to actually try it out to see if such a small (and off center) magnet is really strong enough.
A trit slot is of course also possible, I hadn't even thought of that, but it gives me another idea .
If we move the magnet to the other side we could have both a magnet and a trit slot, win-win .
It is a bit of a tight squeeze (4 x 3 mm magnet and 6 x 1,5 mm trit), but should be doable. I have measured everything with the help of my i3E (which has a 4000K high CRI Luxeon TX in it BTW ).
my 5 cents
  1. No to magnets. If you want to stick your light to a magnet, just put the magnet on the surface you want the light to stick to… the battery in AAA lights is very attracted to magnets and will hold the light easily, without having a magnet in your pocket, which will stick to all sorts of things, including keyrings… Just say No to magnets permanently attached to a cheap light.
2. Yes to center hanging a light that is going to live on a keychain, even if that means no tailstanding. imo tailstanding is overrated. I used to prioritize lights that can do tailstands, but I usually prefer to lay a light on its side, because when I tailstand it usually means the glare of the LED will be in my line of sight, which I hate
sooo
3. Tailstanding… nah
build a light with a center hanger, and no magnet, even if it has no tailstanding ability… thats my opinion… otoh, I know people consider tailstanding important, so if you have to have it, then put the keyring on the side of the tail.
4. regarding trits, NO!
definitely not on a 6 dollar light
I dislike trits, they are not stealthy, there is no way to turn them off, except that they die with time
5. Reversible pocket clip YES YES YES!
the ability to stop a light from rolling off my nightstand is a high priority (I do not keep lights on my keys).
I OFTEN clip a light to my hat for hands free use… the Fenix has NO pocket clip… if the Sofirn has a reversible clip option that will make it Significantly Superior, for the way I use my lights.
now back to your regularly scheduled dreaming
and btw, I applaud the progress Sofirn has made
regarding the “reflector”, KISS, there is no need for fancy angles on a 5mmLED light, it wont make any difference, and takes extra work
remember, this is a Cheap Light… fancy trits and fancy reflectors are completely out of character, and imo add nothing except extra machine work
regardless, I look forward to everyone getting their Yuji single mode AAA light
these are just my opinions, please dont argue with me about them… Im sure you each have opinions of your own… post them, and good luck
In for a couple. These leds are awesome. I mod my Photon Freedom lights with these.
I won’t argue Jon but you do have rigid ideas :smiley:
I made my drawing, I took the maximum possible 14.3mm tail diameter 2mm hole right in the middle, for fitting I took an existing and appropiate looking ring that I had, it was 10mm inner diameter. The grid is 1.25mm/square.
project looking good.
Still like the trit slot idea, personally if the light is nice enough I would put one in and it still looks nice without a trit, and the front end will collect debris just as well.
But the poll may get us a ‘BLF-preference’, and after all that, I would not be surprised if Sofirn has ideas of their own as well.
So some preliminary results on the survey (for those who haven’t taken it yet, it’s here: Free Online Survey Software by SurveyMonkey: Closed Survey ):
1. Magnet seems to be very popular so far- far overwhelming those who don’t want one. My concerns when it comes to a magnet or attachment point for one is that it will add to the overall length of the light, which is detrimental for carrying on a keychain, or that the extra material/machining will add to the cost of the light (even if the magnet is not included).
2. The number of people who absolutely want a trit slot is about equal to the number of people who don’t want one. Really, that vote is overall a dead heat and could go either way at this point.
3. The Manker E02 tailcap leads the ranking despite its late entry. The i3s type tailcap and Lumintop Ant are #2 and #3 in the current rankings. Everything else trails off significantly.
I’d wait for more data to make any definite conclusions, but I don’t think central mounting is a strict priority. Personally I wouldn’t use a magnet, and I’d prefer it be optional or not come with the light at all. I’ve had better luck sourcing my own magnets for projects anyway. What do other members think of this?
As far as Noir’s design, I’d think the magnet would have to be pretty strong considering the small size and off center nature. I really don’t want that in my pocket with my USB drive/keys/credit cards/etc, thus having the magnet be optional would be important. Assuming this design doesn’t add much length, I do like the idea as a middle ground.
Edit: Looking at Djozz’s drawing, why not have the trit side curve out a bit more following the split ring? That should help a bit with tailstanding.
Edit #2: Come to think of it, Noir’s design is a lot like a blend of the current top three tailcaps in the rankings.
That is not possible, because of the hole in the middle (the drill goes vertically).
Edit:
Yes, my design (the second one with magnet and trit) has (at least in theory) everything: standard split ring, tailstand, central hang, magnet & trit slot. The only thing that needs to be verified/tested is if a magnet of that size (4 x 3 mm) is really strong enough.
D’oh! :person_facepalming:
Maybe Sofrin can consider a removable magnet like the one in the Skilhunt H03.
In our scenario, the magnet would not occupy the whole circle. Just the the area underneath the non tritium slot.
This would not increase the length since it is dead space.
I never want magnets on my stuff, it’s too easy to damage things.
Anything from a demagnetised credit card in your pocket to a damaged computer hard disk because you put your light in the wrong place for a moment whilst working inside the computer.
I’m fine with a hole or an internal spring clip for people to add an optional magnet, I just don’t want the light to come with a permanently-attached magnet as standard.
Same here. Optional magnet. I don’t care if there is a slot, but will not use it.
I would probably use a magnet if it had one, but for a keychain light with only ~8lm output, it’s not a big deal if it doesn’t include one. I like the idea of putting it inside the tail-cap instead of outside. Then, those who don’t want their light to be magnetic can remove the magnet (if it’s clipped in and not glued) and not have a huge hole in the back of their tail-cap where the “missing” magnet would be.
I added a 5mm magnet hole in my drawing. A bit of a mess now but focus on the red area, as you can see, 5mm fits.
You can youtube niteize upgrade for mini maglite. It is a 5mm led upgrade kit with a reflector.
Here is one video with the beam shot timestamp.
Nite Ize Upgrade Maglite Mini
The issue is the twisting action will move the led to different focal points in the parabolic reflector. This will cause all sorts of artifacts to show in the beam. Everyone remembers their old maglites and the various focusing beam patterns. I really hate those patterns.
There are a few solutions if Sofirn wants to use a parabolic reflector and address the beam pattern issue:
  1. diffuse lens
  2. really orange peal reflector
  3. smooth reflector with a flat white paint to diffuse.
A 5 mm magnet does indeed fit (just). I rechecked the dimensions with the help of a drawing. A 5 x 3 mm magnet should most definitely be strong enough.
Some notes on my drawing:
  • I've been cautious and used 14 mm diameter, if it is actually 14,3 mm all the better.
  • The magnet circle is a touch too far to the left (to the outside).
  • The trit slot is probably a bit too big.
  • The split ring is the same size you'll find on medium sized Swiss Army knives.
  • The total height of all this is 3 mm, the hole is 2 mm plus 1 mm of material on top of that (this is the same as on an Olight i3E, the central lug of that has a total height of 3 mm and a 2 mm hole). Or in other words: non of this adds length to the light, the 3 mm are needed either way.
There is a slight concern that there might not be enough material left either side of the 5 mm magnet, but I'm sure Sofirn is able to figure out if that is the case or not (not forgetting the chamfered edges of course).
I just realize that this light must be a 3 piece host in order to accommodate a removable magnet. I hope sofirn can test the structural integrity of the tailcap since we wanted a robust flashlight.
Count me in the group that for sure does NOT want a magnet in this light.
In fact, count me out of my 2 piece request if this DOES have a magnet.
I think it is best if the light does not come with a pre-installed magnet (to make the most amount of people happy).
There are two sensible options:
A: The light does not come with a magnet at all (but with a cavity for one). If the user wants a magnet they need to buy and install one themselves (same as with the trit).
B: The light does come with a magnet, but the magnet is not pre-installed into the light. If the user wants a magnet they just need to install the one that is in the package.
I prefer option B, because it is easier for the user.
