Interesting. I tried both cells on both lights (before I removed the top cover) and neither of them worked. When I switched to the smaller 26350 with the bigger contact area, neither light had any issues. With the cover removed on the 26650, both of them also work. I think I’m only going to mess with one of those batteries and clean up the top a bit so there is nothing that is near the contact space. I’ll just use the other battery for the upcoming Emisar D4S.
Sitting outside last night, enjoying a bourbon and a cigar, I noticed my SC26 has a different anodizing on the body. It seems to be less glossy than the rest of the light. Anyone else notice this on theirs?
XHP-35 HI NW. Put it through the paces all weekend. Really enjoying this flashlight. The HI emitter with the OP reflector is near perfect amount of throw and flood. Great amount of runtime with a 4200mAh cell.
I don’t know if it has LVP or whether or not protected cells fit. I use an iJoy 4200 unprotected cell, and used it all weekend, including as a table lamp one evening. Today the battery was at 3.62. Just check your battery once in a while, and you’ll be fine
While I don’t have any protected cells, it’ll hold two 26350 cells in series which is longer than a single 26650 and the tail spring has a lot of travel so your chances are good.
Thanks guys.Mine is on it’s way . I always worry about my wife using it or it accidentally getting turned on . Have to order a cell now before it gets here.
I dont think using unprotected cells in this light is a big deal, i been using double unprotected in my l6 for almost a year and never any issues. as long as using a good quality cell it will work just fine.
Yes, you are right, not just anodizing but also different color.
My bezel ring and body are both darker than the head and the tailcap. (The two latter is much more shiny.)
BTW: I did not need a bourbon nor a cigar to see that…
Thank you very much. Very helpful information. Now I have to choose a 26650 cell . Shockli seems to be the highest capacity. Not many American sources though.
NKON (nkon.nl) is going to have the Keeppower 6000mAh (same cells as Shockli uses) back in stock as of August 23, 2018. I‘m not sure how much shipping (plus customs) will be to the US.
