LD-B4 driver has holes for up to 18AWG wires max., this is good enough for 30+Amps, there is plenty of space for wires in spacers. You don’t have to worry about switch
Soldered all variations(Luxeon V 4000K, LH351D 4000K 90CRI) just to check how everything fits, also tested them with bench power supply.
6x variants definitely put a lot of light at just ~10A, beam looks good with all optics, clear optics have some tint separation like usual, frosted cute versions bled light completely.
now we just need those spacers. :innocent: I plan to mix one of the frosted Cute4’s with 4000K and 5000K 90CRI LEDs if they blend well like you mention.
Demo build1 -C8 6xLH351D 4000K 90CRI (still not 100% finished):
This is how spacer will look like,a little unconventional and more complicated, but it has several advantages - build is easier once spacer is fixed and can't move, spacer is compressed with high pressure, and all wires can be soldered on driver first which is usually much easier. Hole in C8 should be ~8-8.5mm.
Driver LD-B4 18Amp for this build:
Those FR4 0.6mm thermal insulating boards are working as expected, soldering thick wires on them is very easy.
Moon mode:
I used common 1288 Omten switch and 30Q cell,so I didn't test light under full potential yet, but it's damn bright for 90CRI and it's size. Brightest 90CRI C8? Hm maybe even brightest single cell 90CRI light?
Of course big die dome led and relatively small TIR size (but much bigger than carlco optics) makes this light flooder, but it still can burn paper:)
And relatively big ALU spacer definitely works well as thermal storage because light didn't get crazy hot very fast, but it also took more time to cool down. If you are going to use this kind of light in <1min pulses with >1min pause,it is beneficial.
Please explain the switch part ;). I don’t want to needlessy spend money on this if you are already developing a more suitable solution compared to what I have in mind.
I just want a FET-clicky switch with a coin cell battery or a capacitor.
I do not care about the weight. My point is that copper can be soldered. Then the led board does not move and it’s perfectly centered. And that’s always very important for me when I make multi-led.
I would think the switch could be a simple momentary FET Driver with only one mode to place in every Flashlight instead of the clicky-board.
Perhaps it has LEDs for iluminated tailcap and a bleeder resistor on the main Driver is needed. And this switch can be used as upgrade in each clicky Flashlight.
Perhaps short klick for mode Change, as reverse clickies behaves and Long click for power off.
1.mosX board are aluminum with ceramic insulation, so you can't solder them.
2.Soldering copper MCPCB on such big spacer would be very difficult and there would be great risk of frying/damaging LEDs from excessive heat.
3.It's not good if pcb doesn't move in this case, all parts have their tolerances, so it's better if pcb can move a little bit, optics have 3-4 legs, so centering is always perfect. For example ANNA optics fits very tightly into C8, if you solder hypothetical copper pcb on copper spacer and make just 0.5mm error, optics wouldn't fit into head.
