Question 1: 2 people definitely want a trit slot. 4 people would like one. 15 do not care. 13 said no, they would never use it. 8 said they would prefer it without a trit slot.
Question 2: 18 said tailstanding is vital, 13 said it would be useful. No respondents said they prefer a non-tailstanding tail design.
Question 3: No magnet is leading 21 to 19. That is not a wide margin.
Question 4: The Lumintop Ant tailcap is in the lead by a narrow margin, followed by the Olight i3s then the Manker E02. The rest are still far behind. The mini pineapple tailcap is the most divisive, with a significant number of both higher rank finishes (think 2-5) but also has the second highest number of 9/10 rank finishes.
Question 5: The concern was raised that magnets/trits may become large sticking points for a small number of vocal members while not being of consequence to the goal people signed up for: a cheap and robust light. Also another vote for the Noir/Djozz tailcap design.
I like the Djozz tail/Sofirn Render quite a lot. It allows for tailstanding and the ability to have the keychain ring without having any sharp edges. I can’t stand lights that have sharp edges around the slots for the lanyard/key ring.
The slit trot and magnet hole I could care less for, but if the added machining/designing only accounts for like 1 dollar more on the price I won’t mind.
It has received a little bit of discussion because a user who has modded an E01, I think it was ma tumba, said in his experience it made the beam profile less smooth. It didn't sound drastic, but still like there was room for improvement.
So hopefully Sofirn does cut a few test pieces to try with these emitters to make sure the resulting beam is nice and smooth. I suspect parabolic isn't actually ideal in this case like it is for a thrower, so maybe conical or spherical is better. I know the Maglite Mini I stuck a Yuji in shows a slight dark spot in the middle of the beam at certain focus settings. The larger, deeper reflector creates enough of a hotspot for this to be more noticeable than I'd expect from a 14mm OD light.
The Noir/Djozz tail was created after and the renders only arrived last night.
With the number of responses already received it would have skewed the data already collected for Question 4.
I’d really like more data on opinions of that tail, but all I can do at this point is extrapolate from the data on the currently listed tails and other questions, including question 5 where people can put their opinions of it. (Obligatory link to the survey: https://www.surveymonkey.com/r/DGQ8LL3)
I could also set up a new survey where we decide between the frontrunners from the current survey and the Noir/Djozz tail, plus some questions for detail and opinions.
I have asked Barry and the engineers how they like the new designed Noir/djozz tailcap themselves (because earlier Barry was in favor of a Sofirn SP10-like tail). If they like it too, or if they say that they will make what we want regardless of their opinion, perhaps we can already decide on going for this design (I think that I hear a majority liking it or being ok with it). Then maybe a new poll would be good (keeps us nice and busy :party: ) deciding on no holes, trit hole, magnet hole, both holes.
I honestly like the rendering of this light - especially the tail. On paper, it didn’t really strike me as something I would like, but seeing it with the light has changed my thinking. In my mind, I’m ready for Sofirn to start producing them as they’ve been rendered!
Also, I’d like to up my interest to 4 x 3200 instead of just 2. :+1:
I like the rendered tailcap a lot (though I don’t care about the trit slot), but I am curious how would be best to install a magnet in the hole with other’s comments that most glues dont work too well on anno since it sounds like we would not have a factory installed magnet.
A quick scan of the www came up with superglue and Araldite. But I have no experience with glueing to ano myself.
Something considering if you want to do a thorough and careful job is applying a drop of concentrated caustic soda in the hole and wait for the surface to be deanodised. Could be a way to make the trit slot a bit more reflective too (some sanding afterwards to finish the surface, then glue in the trit)
I did glue some neodymium magnets on the tail of some lights (Sofirn SF32 and Manker E11). Both have similar shapes on the tailcaps, so putting a bit of super glue and the magnet above did the job!
Of course, strong impacts or falls may endanger that as the glue (dry) can crack.
One thing I have a concern with in the proposed design (BTW, thanks djozz and Barry for the work on that, and to other members giving support on this thread!!!) is that the magnet is not in the middle. So, I don’t know if there is the possibility of that putting at “risk” the way it will stick “evenly” on a metal surface without falling due to a lack of equilibrium (toward the central “axis”).
But I believe you have thought about this too
Thanks again for all the efforts!!
In the proposed design with the off-center magnet, you can increase the holding power of the magnet based on how you place the light on the metal surface. If you rotate the flashlight so the magnet is positioned higher on the axis (closer to the 12 o’clock position) before placing it on the metal surface, it will have a better hold than if the magnet is lower on the axis (closer to the 6 o’clock position).
Yup, sure, I know that I was just wondering if due to that wouldn’t it be better to put in the center! But I won’t bother much with that! Actually, due to the type of light, I’d prefer not to have a magnet or to have the option to put/not to put it !
+1 here!
I also asked about the diffuser before. Here’s my suggestion and djozz’s reply! Maybe having the diffuser as a extra can be doable, so that the “normal” pack keeps the lower price :money_mouth_face:
