Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1518 posts / 0 new
kiriba-ru
kiriba-ru's picture
Last seen: 13 hours 37 min ago
DavidEF wrote:
Just for curiosity, what is the complex machining that would be required? I just realized that a 7x MCPCB would be great for RGBW, with 2x each red, green and blue, and the white in the center.
I think this was discussed hundred times about X6 triple and have same reasons here.
If you have central hole in pcb you dont care about rotating pcb to the spacer or spacer to the head.
If you have hole not in center, you need to fix both (to avoid wire cutting) so you need threaded holes in spacer (from both sides), holes for wires (remember that sometimes you need more than 2 wires).
DavidEF
DavidEF's picture
Last seen: 2 hours 58 min ago
Thanks kiriba-ru. I often miss those conversations because I don’t mod much. Plus, my memory isn’t very reliable. So it’s probably true that it has been “discussed hundred times” and I missed it or forgot it.
- The YKK Philosophy
led4power
led4power's picture
Last seen: 15 hours 13 min ago
Example of fully populated 3XV-C mosX board:
Parts needed(for LD-B4):
First two "components" on the left are two small 0.6mm FR4 boards which are actual "LED" wire pads.
mosX boards are very thermally conductive everywhere which makes soldering wires directly to board very challenging, it's possible (but not easy) on 20mm size boards, but these boards are >30mm - soldering wires directly would be a nightmare. So these thin FR4 plates serve as very good thermal insulator - soldering wires should be easier than on standard copper DTP boards because those usually have 0.2mm FR4 thick laminate on surface.
For same reason there is small JST smd connector on board for signal wires (gate,NTC,moon) - in theory I could make 3rd FR4 plate for those, but I think connectors are simpler to use for end user, especially if wires with male connector are already soldered on LD-B4, in that case build is as easy as with any other normal 2-wire driver.
All parts placed:
Soldered, everything fits nicely:
Just tried it outside of flashlight with bench power supply, tint is absolutely fantastic (still can't believe it's only 70CRI,looks better than some 90CRI LEDs) complete uniformity across the whole beam, and brightness looks already impressive at just 9Amps. I think I will put this board in Kiriba-ru C8 head and drive it at 15-18Amps.
The_Driver
The_Driver's picture
Last seen: 4 weeks 1 day ago
Seems very clever! Will the FR4 boards tolerate 25-35A? I want to use three parallel Luxeon MZs in direct drive (for short perdiods of time). I will also use the Kiriba-ru C8 head.
thijsco19
Last seen: 16 hours 32 min ago
Wow! that looks very nice and professional!
led4power
led4power's picture
There are many vias so electrical resistance is very low, that's really last part of whole flashlight circuit you should be worried about, springs will be the bottleneck for sure,even bypassed ones if not done properly.
The_Driver
led4power wrote:
There are many vias so electrical resistance is very low, that’s really last part of whole flashlight circuit you should be worried about, springs will be the bottleneck for sure,even bypassed ones if not done properly.
Ok, good! I’m worried about everything! Wink
Currently “working” on a suitable FET-switch with loneoceans, fady and lexel. Will I be able to route leads suitable for 30A through the hole in the middle of your new pcbs?
Springs are an important point. I want high spring pressure and low resistance. Maybe a multiple leads will be used for the bypass and the top of the spring might be covered with a copper or brass disc (gold plated).
led4power
led4power's picture
LD-B4 driver has holes for up to 18AWG wires max., this is good enough for 30+Amps, there is plenty of space for wires in spacers. You don’t have to worry about switch Wink
led4power
led4power's picture
Soldered all variations(Luxeon V 4000K, LH351D 4000K 90CRI) just to check how everything fits, also tested them with bench power supply.
6x variants definitely put a lot of light at just ~10A, beam looks good with all optics, clear optics have some tint separation like usual, frosted cute versions bled light completely.
contactcr
Last seen: 6 hours 47 min ago
now we just need those spacers. Innocent I plan to mix one of the frosted Cute4’s with 4000K and 5000K 90CRI LEDs if they blend well like you mention.
led4power
led4power's picture
Demo build1 -C8 6xLH351D 4000K 90CRI  (still not 100% finished):
This is how spacer will look like,a little unconventional and more complicated, but it has several advantages - build is easier once spacer is fixed and can't move, spacer is compressed with high pressure, and all wires can be soldered on driver first which is usually much easier. Hole in C8 should be ~8-8.5mm.
Driver LD-B4 18Amp for this build:
Those FR4 0.6mm thermal insulating boards are working as expected, soldering thick wires on them is very easy.
Moon mode:
I used common 1288 Omten switch and 30Q cell,so I didn't test light under full potential yet, but it's damn bright for 90CRI and it's size. Brightest 90CRI C8? Hm maybe even brightest single cell 90CRI light?
Of course big die dome led and relatively small TIR size (but much bigger than carlco optics) makes this light flooder, but it still can burn paper:)
And relatively big ALU spacer definitely works well as thermal storage because light didn't get crazy hot very fast, but it also took more time to cool down. If you are going to use this kind of light in <1min pulses with >1min pause,it is beneficial.
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 5 hours 40 min ago
Only aluminium? Will it be also available in copper?
djozz
djozz's picture
Last seen: 6 hours 4 min ago
You don’t want that chunk in copper
And it will not help a lot for the heat path either.
DavidEF
DavidEF's picture
Great work! You’re really churning stuff out lately! I’d like to see what the maximum potential for this build is. djozz? Crazy
led4power
led4power's picture
6x Luxeon V or 5700K 90CRI MZ will be more potent,351D is not best LED for max. output.
vinte77
Last seen: 2 weeks 1 day ago
I wonder if this spacer will fit on the manta ray c8.2? Or in the future do you plan on making one if doesn’t?
PS. Btw, I forgot to add great looking spacer.
led4power
led4power's picture
I got manta ray and it doesn't fit, it's too wide, don't know about height.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 2 weeks 6 days ago
led4power wrote:
I got manta ray and it doesn’t fit, it’s too wide, don’t know about height.
The driver have to be 22mm, isn’t it?
Is only the driver hole too wide or what is too wide?
Is the spacer too wide for the head?
The_Driver
Please explain the switch part ;). I don’t want to needlessy spend money on this if you are already developing a more suitable solution compared to what I have in mind.
I just want a FET-clicky switch with a coin cell battery or a capacitor.
Chatika vas Paus
I do not care about the weight. My point is that copper can be soldered. Then the led board does not move and it’s perfectly centered. And that’s always very important for me when I make multi-led.
Below is an example of what I mean:
Wieselflinkpro
I would think the switch could be a simple momentary FET Driver with only one mode to place in every Flashlight instead of the clicky-board.
Perhaps it has LEDs for iluminated tailcap and a bleeder resistor on the main Driver is needed. And this switch can be used as upgrade in each clicky Flashlight.
Perhaps short klick for mode Change, as reverse clickies behaves and Long click for power off.
Thats what I would think.
led4power
led4power's picture
Wieselflinkpro wrote:
The driver have to be 22mm, isn't it? Is only the driver hole too wide or what is too wide? Is the spacer too wide for the head?
Spacer is too wide.
led4power
led4power's picture
The_Driver wrote:
led4power wrote:
LD-B4 driver has holes for up to 18AWG wires max., this is good enough for 30+Amps, there is plenty of space for wires in spacers. You don't have to worry about switch Wink
Please explain the switch part ;). I don't want to needlessy spend money on this if you are already developing a more suitable solution compared to what I have in mind. I just want a FET-clicky switch with a coin cell battery or a capacitor.
My switch is FET, no clicky and no coin battery, compatible with Convoy S and M lights, and EE X6(other light if there is enough interest).
led4power
led4power's picture
I do not care about the weight. My point is that copper can be soldered. Then the led board does not move and it's perfectly centered. And that's always very important for me when I make multi-led. Below is an example of what I mean:
1.mosX board are aluminum with ceramic insulation, so you can't solder them.
2.Soldering copper MCPCB on such big spacer would be very difficult and there would be great risk of frying/damaging LEDs from excessive heat.
3.It's not good if pcb doesn't move in this case, all parts have their tolerances, so it's better if pcb can move a little bit, optics have 3-4 legs, so centering is always perfect. For example ANNA optics fits very tightly into C8, if you solder hypothetical copper pcb on copper spacer and make just 0.5mm error, optics wouldn't fit into head.
Chatika vas Paus
I would buy it anyway. However, thanks for explaining.
The_Driver
led4power wrote:
The_Driver wrote:
Please explain the switch part ;). I don’t want to needlessy spend money on this if you are already developing a more suitable solution compared to what I have in mind. I just want a FET-clicky switch with a coin cell battery or a capacitor.
So with a cap? That’s great!
I would like to use it in a convoy C8 tailcap (together with the Ciriba-ru C8TT head).
led4power
led4power's picture
You can ask Kiriba-ru for custom copper spacers.
vinte77
Can you check if the height is right? If so, I’m willing to mod the spacer to fit if it’s only the width. If it’s both width and height then it’s better for me to make my own spacer again.
kiriba-ru
kiriba-ru's picture
I think measuring manta rays reflector is more easy. If it has regular C8 size reflector, then required spacer height is same to convoy.
vinte77
You’re right, that would be easier, lol. I believe they both use the same sized reflector. I also noticed on led4power.com that a future listing for 30amp switch is up already.
