well thats not fair is it? we all payed the same price ….
Well, the bezel isn’t glued in my light, maybe just luck?
Anyhow, I did some tests today, using a 3 year old Efest purple INR2500 (I think the 2500 LG cell is in there).
So, not the latest and greatest cell there is but still!Measured at 10m for easy calculations using my cheap LX1330B luxmeter I got:
At start @ turbo (double click) 135Kcd
After approx. 30 seconds 130Kcd
After 30 seconds at maximum ramping 78Kcd.Mind you, using what is certainly not the best cell and my light is “NW”, but I would rather say it’s WW (same as with my GT).
It could very well be that using a truly CW led it does better.
The light gets quite hot very quickly so it looks like the heat transfer is good as well.Cheers
Nico
As predicted I measured the light again, this time with a fresh and fully charged Sony VTC6.
I got 140Kcd at turbo and 81Kcd at max ramping.
And yes, this time I did deduct 64Lux ambient light in my basement………
Which means that my previous measurement date should read ad follows:
I got 129Kcd at turbo and 72Kcd at max ramping (with the Efest INR2500)
Cheers,
Nico
JasonWW: mortuus:It’s weird JasonWW is in the US and got his light so others should get them also more or less this week…
I think Neal sent mine through a slightly faster shipping service, like 7 day express. The bulk of the US lights are probably using a cheaper, 14 day service like normal.
No big deal… it is what it is.
I can see if lights shipped with a battery that can cause a delay or even wont be allowed but yea i hope all get their lights soon.
timbuchanan:Using mode select (ie. not ramping) is 100% equivalent to turbo?
It depends on which mode set number you are using.
Modes 1-6 use the top of the ramp as 100%.
Modes 7-12 use full turbo as 100%.
You can download the manual here.
This is the manual that still says it uses a buck driver, just ignore that part.
Sorry Jason,
The GTmini has other modes settings than the big GT.
GTmini has also 50% as top of the ramp whereas a GT has 80%.
The linked manual from Madmax has errors in Modetable, 50% ramp, driver type and some different wording.
@timbuchanan
Yes, 100% in modes equal to TURBO
(was involved in the manual for the GTmini)
Just placed an order for 1 GT Mini CW and 1 VTC6 via Neal’s Deals.
Joechina is there an accurate manual? I was having problems with the mode table last night
JasonWW: timbuchanan:Using mode select (ie. not ramping) is 100% equivalent to turbo?
Sorry Jason,
The linked manual from Madmax has errors in Modetable, 50% ramp, driver type and some different wording.@timbuchanan
Yes, 100% in modes equal to TURBO(was involved in the manual for the GTmini)
I think your confused. I did not mention anything about the big GT or its manual.
I also don’t see any errors in my response as it’s straight from the GT manual.
UPDATE TO MANUAL
After trying mode 4 and mode 10 it appears that the groups are reversed.
Modes 1-6 use full turbo as 100% (5A)
Modes 7-12 use the top of the ramp as 100% (2.5A)
We definitely need an updated manual to reflect this.
Edit: And here it is.
GT Mini User Manaual
What problem did you have?
joechina: JasonWW: timbuchanan:Using mode select (ie. not ramping) is 100% equivalent to turbo?
Sorry Jason,
I also don’t see any errors in my response as it’s straight from the GT manual.UPDATE TO MANUAL
Modes 7-12 use the top of the ramp as 100% (2.5A)We definitely need an updated manual to reflect this.
I am lost… you said mode 7-12 use full turbo… you also said mode 1-6 use full turbo… whats that??
JasonWW: joechina: JasonWW: timbuchanan:Using mode select (ie. not ramping) is 100% equivalent to turbo?
Modes 7-12 use full turbo as 100%.-You can download the manual here
Sorry Jason,
.I am lost… you said mode 7-12 use full turbo… you also said mode 1-6 use full turbo… whats that??
I’m not saying either. I’ll edit my older post.
At first I went by the online manual for the GT Mini, but it was incorrect. Then I tried out both modes 4 and 10 on my light and found mode 4 used 5A and mode 10 used 2.5A. So something was fishy.
Then TA pointed me to the latest updated manual (v5) and it shows a whole new unique set of mode sets not seen in previous versions of NarsilM v1.2
You can use the link I posted to see the levels.
om my production NW i got:
4.70A
nitecore NI18350A toomAh<br />4.95A
Aspire 1300mAh
5.25Akeeppower IMR18350 (black) 750 mAh<br />5.60A
shockli IMR 1150mAh
Is the Aspire cell new? Is that result repeatable?
So far I haven’t seen any evidence of the existence of another cell that would compete with Yong Deli (used by Aspire) when it comes to both capacity and internal resistance.
Now that Shockli actually seems to be something different…but I’m not yet convinced.
Also, the Shockli stated capacity is about what would I expect them to state if they used the YongDeli.
is that correct?
Where did this come from?
was posted to Neals facebook
I guess you would need to have a ROT66 to confirm its accuracy.
Some things I notice is that it says you can press and hold to get into the menu. They might have used 16 seconds in ramping, but it’s always best to ramp down to get into the menu. If your in mode sets it only takes about 3 seconds.
Of course, if you are in mode sets the menu is different. So maybe the diagram should be labeled (only in ramping mode) under the “16 seconds”.
There’s no mention of the mode sets menu or all the mode sets brightness level options (1-12). I guess this was on purpose to keep things simple.
I got tracking 8/2 and a scan at “GUANGZHOU EMS” on the same day, just hasn’t moved in 7 days.
Looking forward to getting mine too.
Im in the US. Mine says the same…but shipped on the 3rd.
nkresho:I got tracking 8/2 and a scan at “GUANGZHOU EMS” on the same day, just hasn’t moved in 7 days.
Yep… mine says 3rd too. . Looks like they are all just sitting around waiting to leave.
Note to self….Maybe I won’t use EMS ePacket China again, given a choice that is. .
Mine just got updated from ‘processed through facility’ to ‘shipped’.
US order w/out batteries.
Brainsick67: nkresho:I got tracking 8/2 and a scan at “GUANGZHOU EMS” on the same day, just hasn’t moved in 7 days.
That blows…im sure we will get this or next week…i HOPE this week.
