Nicolaas
(Nicolaas)
August 10, 2018, 12:34pm
672
Nicolaas:
Well, the bezel isn’t glued in my light, maybe just luck?
Anyhow, I did some tests today, using a 3 year old Efest purple INR2500 (I think the 2500 LG cell is in there).
So, not the latest and greatest cell there is but still!
Measured at 10m for easy calculations using my cheap LX1330B luxmeter I got:
At start @ turbo (double click) 135Kcd
After approx. 30 seconds 130Kcd
After 30 seconds at maximum ramping 78Kcd.
Mind you, using what is certainly not the best cell and my light is “NW”, but I would rather say it’s WW (same as with my GT).
It could very well be that using a truly CW led it does better.
The light gets quite hot very quickly so it looks like the heat transfer is good as well.
Cheers
Nico
As predicted I measured the light again, this time with a fresh and fully charged Sony VTC6.
I got 140Kcd at turbo and 81Kcd at max ramping.
And yes, this time I did deduct 64Lux ambient light in my basement………
Which means that my previous measurement date should read ad follows:
I got 129Kcd at turbo and 72Kcd at max ramping (with the Efest INR2500)
Cheers,
Nico
teacher
(teacher)
August 10, 2018, 11:16am
673
No big deal… it is what it is.
mortuus
(mortuus)
August 10, 2018, 11:37am
674
I can see if lights shipped with a battery that can cause a delay or even wont be allowed but yea i hope all get their lights soon.
joechina
(joechina)
August 10, 2018, 2:18pm
675
JasonWW:
It depends on which mode set number you are using.
Modes 1-6 use the top of the ramp as 100%.
Modes 7-12 use full turbo as 100%.
You can download the manual here .
This is the manual that still says it uses a buck driver, just ignore that part.
Sorry Jason,
The GTmini has other modes settings than the big GT.
GTmini has also 50% as top of the ramp whereas a GT has 80%.
The linked manual from Madmax has errors in Modetable, 50% ramp, driver type and some different wording.
@timbuchanan
Yes, 100% in modes equal to TURBO
(was involved in the manual for the GTmini)
Just placed an order for 1 GT Mini CW and 1 VTC6 via Neal’s Deals.
Joechina is there an accurate manual? I was having problems with the mode table last night
JasonWW
(JasonWW)
August 11, 2018, 2:17am
678
joechina:
JasonWW:
Sorry Jason,
@timbuchanan
I think your confused. I did not mention anything about the big GT or its manual.
I also don’t see any errors in my response as it’s straight from the GT manual.
UPDATE TO MANUAL
After trying mode 4 and mode 10 it appears that the groups are reversed.
Modes 1-6 use full turbo as 100% (5A)
Modes 7-12 use the top of the ramp as 100% (2.5A)
We definitely need an updated manual to reflect this.
Edit: And here it is.
GT Mini User Manaual
JasonWW
(JasonWW)
August 11, 2018, 12:08am
679
What problem did you have?
Newlumen
(Newlumen)
August 11, 2018, 4:19am
680
JasonWW:
joechina:
JasonWW:
Sorry Jason,
@timbuchanan
UPDATE TO MANUAL
I am lost… you said mode 7-12 use full turbo… you also said mode 1-6 use full turbo… whats that??
JasonWW
(JasonWW)
August 11, 2018, 5:00am
681
I’m not saying either. I’ll edit my older post.
At first I went by the online manual for the GT Mini, but it was incorrect. Then I tried out both modes 4 and 10 on my light and found mode 4 used 5A and mode 10 used 2.5A. So something was fishy.
Then TA pointed me to the latest updated manual (v5) and it shows a whole new unique set of mode sets not seen in previous versions of NarsilM v1.2
You can use the link I posted to see the levels.
Agro
(Agro)
August 11, 2018, 8:16am
682
Is the Aspire cell new? Is that result repeatable?
So far I haven’t seen any evidence of the existence of another cell that would compete with Yong Deli (used by Aspire) when it comes to both capacity and internal resistance.
Now that Shockli actually seems to be something different…but I’m not yet convinced.
Also, the Shockli stated capacity is about what would I expect them to state if they used the YongDeli.
JasonWW
(JasonWW)
August 12, 2018, 10:09pm
684
Where did this come from?
M4D_M4X
(M4D M4X)
August 12, 2018, 10:18pm
685
was posted to Neals facebook
JasonWW
(JasonWW)
August 13, 2018, 9:11am
686
I guess you would need to have a ROT66 to confirm its accuracy.
Some things I notice is that it says you can press and hold to get into the menu. They might have used 16 seconds in ramping, but it’s always best to ramp down to get into the menu. If your in mode sets it only takes about 3 seconds.
Of course, if you are in mode sets the menu is different. So maybe the diagram should be labeled (only in ramping mode) under the “16 seconds”.
There’s no mention of the mode sets menu or all the mode sets brightness level options (1-12). I guess this was on purpose to keep things simple.
nkresho:
I got tracking 8/2 and a scan at “GUANGZHOU EMS” on the same day, just hasn’t moved in 7 days.
Looking forward to getting mine too.
Im in the US. Mine says the same…but shipped on the 3rd.
teacher
(teacher)
August 13, 2018, 3:37am
688
Yep… mine says 3rd too. . Looks like they are all just sitting around waiting to leave.
Note to self….Maybe I won’t use EMS ePacket China again, given a choice that is. .
Delta_V
(Delta_V)
August 13, 2018, 3:41am
689
Mine just got updated from ‘processed through facility’ to ‘shipped’.
US order w/out batteries.
teacher:
That blows…im sure we will get this or next week…i HOPE this week.
teacher
(teacher)
August 13, 2018, 4:00am
691
Yep…. it does. I agree, end of this week or more likely next.
Look closely at the day & time of the last two 17Track entries for my order. :person_facepalming:
It appears someone is confused……
2018-08-03 22:46
Guangzhou, leave Guangzhou send to Guangzhou courier company
2018-08-03 22:46
Guangzhou, leave Guangzhou and send to JFK Airport in New York.
