I’ve never done it, but I’m guessing it would involve just mixing GITD powder into a two-part epoxy mixture. I think I remember reading before that the ‘right’ way to mix in pigments of any kind is to mix them thoroughly into the base resin, or “Part A”, then mix the hardener, “Part B” into it.
Here’s a really impressive GITD powder that even responds to heat.
word to the wise, from your friendly hijack monitor
I invite USAll to remember to stay on topic, so Sofirn does not think were just a bunch of random talkers
ON topic: new Sofirn AAA twisty
Off topic: glow powder
I know, it was about the holes in the AAA twisty, but really it has zero to do with what Sofirn needs to know to start printing Light Bodies!
Lets not do what the FW3B thread did… just random talk to fill time while nothing gets done
I think its time for a prototype Sofirn RoachLight… they got the tube right, the clip right, the tail right, and the LED right… Now pot it and shoot it… I bet it stays lit…
and Im glad gurdygurds is here to help drop, drag and throw one around… I bet it stays lit during that too
how hard can it be to pot an LED into a tube with a battery inside… lets GitErDone
Let’s not forget that the Klarus Mi02, which is a blatant E01 clone that survived many torture tests on CPF, was ceremoniously tossed off of a 3 story parking garage along with my E01 and DIED upon impact while the E01 giggled and continued to function like ain’t nuttin happened. It might be tougher than one thinks to equal the toughness of The Toughest.
I got notice that the “engineers dont’ think it will help with parabolic reflector. Would be better to keep the E01 reflector design”
That does not sound like they did much experimenting, but since here on the forum the opinions about the reflector shape varied anyway I will not stress them anymore about it.
(bypassing opinions, I will do some experimenting myself at some point so that at least afterwards I can tell the world that I was right about it )
Come to think of it, the reflector design in that first render of theirs would be an even bigger/deeper lint trap than the E01.
I think the tail should be simple, no magnet, as that doesn’t interact well with many other keychain items, trait slot is good but not necessary. Pocket clip for sure, even as an optional accessory.
In regards to the reflector… in a 5 mm light the reflector usually doesn’t do a whole lot. The led has a lens molded into it, this makes the most difference. The conical, brushed aluminum of the e01 is probably the easiest to machine and therefore cheapest.
Spend money on knuckling if anything.
Hey guys! Thanks to the 26 people who have already responded to the survey. If you haven’t taken it, here is the link: https://www.surveymonkey.com/r/SH8J7BS
That is a from a few minutes ago:
Thanks Docc, 29 responses already gives a picture. Let’s run the poll for one more day and end it together with TheShadowGuy’s poll for the complete picture.
Could you post the link once more so that people do not have search for it?
Edit:link is already below
Hi, I’m in for 2×3200k.
Hi, I’m now in for 4x3200k instead of 2x3200k from post 565, thank you
While the Noir/Djozz tailcap seems popular, I know there were a number of people against the idea of having magnet hole/trit hole, so I want to make sure they can be heard and counted.
This survey will be open for the weekend and I will present final results on Monday. If you are interested in buying one of these lights, please take this survey as soon as possible or forever hold your peace.
I hope it is ok that i setup a new servey. I hope most people are ok with the Noir/djozz Tailcap Design.
The servey is only about the trit and magnet hole.
I just found this I would be interested in 2*3200 and 1*5600.
Thank you.
As much as I enjoyed reading your torture test adventures, it should be noted that using a single light of each type isn’t statistically significant.
Interested
Interested in six (6) neutral white. Thank you.
I am already on the list for the 6 above.
Please put me down for two (2) more. Please make them both 3200K.
Thank you….
AWESOME I WANT IN!
Lots of page here, but I just heard about it. I saw in the original post an unbelievably low price; can anybody clarify what the projected pricing is? Assuming something reasonable count me in for two- do I just sign up to the google doc?
The projected price is 6 dollars. If you are wanting 2, just post on here if you want 3200K or 5600K and how may of each.
At $6 I’m in for two of each 3200k and 5600k!!
AWESOME I WANT IN!
2 3200k pls
