Let’s not forget that the Klarus Mi02, which is a blatant E01 clone that survived many torture tests on CPF, was ceremoniously tossed off of a 3 story parking garage along with my E01 and DIED upon impact while the E01 giggled and continued to function like ain’t nuttin happened. It might be tougher than one thinks to equal the toughness of The Toughest.
I got notice that the “engineers dont’ think it will help with parabolic reflector. Would be better to keep the E01 reflector design”
That does not sound like they did much experimenting, but since here on the forum the opinions about the reflector shape varied anyway I will not stress them anymore about it.
(bypassing opinions, I will do some experimenting myself at some point so that at least afterwards I can tell the world that I was right about it )
Come to think of it, the reflector design in that first render of theirs would be an even bigger/deeper lint trap than the E01.
I think the tail should be simple, no magnet, as that doesn’t interact well with many other keychain items, trait slot is good but not necessary. Pocket clip for sure, even as an optional accessory.
In regards to the reflector… in a 5 mm light the reflector usually doesn’t do a whole lot. The led has a lens molded into it, this makes the most difference. The conical, brushed aluminum of the e01 is probably the easiest to machine and therefore cheapest.
Spend money on knuckling if anything.
Hey guys! Thanks to the 26 people who have already responded to the survey. If you haven’t taken it, here is the link: https://www.surveymonkey.com/r/SH8J7BS
That is a from a few minutes ago:
Thanks Docc, 29 responses already gives a picture. Let’s run the poll for one more day and end it together with TheShadowGuy’s poll for the complete picture.
Could you post the link once more so that people do not have search for it?
Edit:link is already below
Hi, I’m now in for 4x3200k instead of 2x3200k from post 565, thank you
I just found this I would be interested in 2*3200 and 1*5600.
Thank you.
As much as I enjoyed reading your torture test adventures, it should be noted that using a single light of each type isn’t statistically significant.
Interested
I am already on the list for the 6 above.
Please put me down for two (2) more. Please make them both 3200K.
Thank you….
AWESOME I WANT IN!
Lots of page here, but I just heard about it. I saw in the original post an unbelievably low price; can anybody clarify what the projected pricing is? Assuming something reasonable count me in for two- do I just sign up to the google doc?
The projected price is 6 dollars. If you are wanting 2, just post on here if you want 3200K or 5600K and how may of each.
At $6 I’m in for two of each 3200k and 5600k!!
2 3200k pls
please put me down for 4 more, so total of 6 Will do 4 at 3200k, 2 at 5600k
I am in for two of the 5600K
