I think the tail should be simple, no magnet, as that doesn’t interact well with many other keychain items, trait slot is good but not necessary. Pocket clip for sure, even as an optional accessory.
In regards to the reflector… in a 5 mm light the reflector usually doesn’t do a whole lot. The led has a lens molded into it, this makes the most difference. The conical, brushed aluminum of the e01 is probably the easiest to machine and therefore cheapest.
Spend money on knuckling if anything.
Hey guys! Thanks to the 26 people who have already responded to the survey. If you haven’t taken it, here is the link: https://www.surveymonkey.com/r/SH8J7BS
That is a from a few minutes ago:
Thanks Docc, 29 responses already gives a picture. Let’s run the poll for one more day and end it together with TheShadowGuy’s poll for the complete picture.
Could you post the link once more so that people do not have search for it?
Edit:link is already below
Hi, I’m now in for 4x3200k instead of 2x3200k from post 565, thank you
I just found this I would be interested in 2*3200 and 1*5600.
Thank you.
As much as I enjoyed reading your torture test adventures, it should be noted that using a single light of each type isn’t statistically significant.
Interested
I am already on the list for the 6 above.
Please put me down for two (2) more. Please make them both 3200K.
Thank you….
AWESOME I WANT IN!
Lots of page here, but I just heard about it. I saw in the original post an unbelievably low price; can anybody clarify what the projected pricing is? Assuming something reasonable count me in for two- do I just sign up to the google doc?
The projected price is 6 dollars. If you are wanting 2, just post on here if you want 3200K or 5600K and how may of each.
At $6 I’m in for two of each 3200k and 5600k!!
2 3200k pls
please put me down for 4 more, so total of 6 Will do 4 at 3200k, 2 at 5600k
I am in for two of the 5600K
Interested in one 5600K. Thanks.
The list is updated through post 685 (GreenLights). Total is now up to 496 lights.
Shortcut to the Interest List.
Just noting that I have recorded these updates. Thanks.
FYI, I’m counting quantities by the minimum interest stated, so I have you updated for 4+1 at the moment.
Based on your follow up post, I have you for 2 of each. We’ll find out actual purchase details from Sofirn once they’re ready.
Hopefully slowtechstef has time to update the first page soon, but in the meantime, I will try to keep crucial details in the post with the current list on page 10.
Clarifying
2 5600
2 3200
