Mine is shipped without refund from battery. Maybe there are problems with sending batteries to Australia
It says on his website, under shipping, that he can’t ship them to Canada and Australia and will refund them instead.
I just got a confirmation email saying my D4S has shipped from Intl-outdoors to the UK.
Same here with tracking
OK!! Mine’s on the way!
Better remind them to put a few tie straps on it or one big wave and your D4S might end up testing the limits of the IPX rating.
KuoH
Which cells do you use in that?
gonna need bigger pockets…
I think flashing pads with a pogo pin adapter is a better solution, only viases for the alignment pogo pins
I have started to put those slowly to my new driver designs
Oshpark 2Oz are 0.8mm thin, this should be enough
on chineese fab on panel I would go to 0.6mm
also made a programming adapter for my future drivers
same order in 2 Oz!
Fits those pogo pins from banggood
Ordered D4S Green with Nichia.
Nichia leds will be pretty nice throwy in this flashlight, similar as XP-L Hi in D4, which is optimal for EDC light from my point of view.
@lexcel
Wouldn’t it be better to have left an right traces on the side for the pogo pins?
trace ———
————- pin
trace ———
So they self center?
And how much are pogo pins with gold tips?
I now from ICT they are more reliable
toykeeper (I am sure there was a post from here)
lexcel
found the pcb I remembered
https://easyeda.com/feather/ispogo-oA5nFXR93
and more
http://blog.spitzenpfeil.org/wordpress/2013/11/12/the-pogo-key-1-27mm-avr-isp-adapter-take-ii/
But instaed of 3x2
xxx
xxx
I would use a keyed 4x2
xxxo
xxox
to ensure always right connection
Mine shipped on the 11th. No tracking code, yet. Grumble.
Same. Ordered mine (INT) the day it was released. Sounds like people that ordered through MTN will get there’s first.
Can anyone confirm whether this 26650 will be any good with this light then? It’s the only spare I have unfortunately.
Where are other Aussies getting their suitable 26650 from?
Those are good cells, maybe not quite top anymore but still very good cells…
Mine says pulse current, why does yours say pluse? Where did you get it from?
Prison cells.
