Not sure why you think we’re arguing. Just pointing things. The Maukka calibration light set includes a 5000k and 6500k light and the difference I measured with the lux meter TA included with his lumen sphere is only 0.2% even if we go down to 4000k, I doubt the CCT difference will cause the lux meter in the TA lumen sphere to deviate more than 1%. To me, it just seems unlikely but not impossible that using 219B emitters in the M43 will result in more lumens than with the LH351D 4000k 90CRI, which I read is similar in performance to the 219C or better.
There is really no reason to argue. The 219B is a good looking LED but not something we should be using much going forward when we have better LED’s available.
About “my lumen”, I try my best to keep it consistent but it is not correct and I never claimed it to be correct. In fact, as I have mentioned here and there, comparisons with reliable sources (of which maukka’s calibration is one) suggest that it is somewhere between 7% and 11% high, probably depending on spectrum as well.
I’m not happy with that but it is not way off and I stick to my calibration to keep my measurements comparable over time.
But sadly, there’s no replacement for the 219B 9080 or 9050 in terms of light quality. The LH351D is no comparison. Hoping there will be 9080 219C with less green in the future.
The high CRI Luminus SST-20 series is very promising, the performance is in between 219B and 219C and at least the 3000K version (the only type currently available) has close to perfect tint and CRI. The only downside is that the tint does not go over 4000K.
The 9080 219B has been discontinued so that is no longer an option sadly (I have been trying to track down an option to get some for a light that is in the works and they are not to be found) , thus the best option that I can think of is now the 219C “E bin” 9050. Which is what I am looking into now.
It should be the 219B tint with the 219C performance. Just in the 9050 flavor instead of 9080 (although when tested I think it got quite a bit over spec in this particular bin)
I saw that test and it does look interesting but the limit to 4000k and warmer is a real bummer. 4500k is about the warmest the general public seems to like.
I would consider a 4000k version though. 3000k is too warm for me.
Yea I saw your review and got excited and bought a triple SST-20 and a P60 pill from Kaidomain. The triple mcpcb fits carclo optics so I might swap it in my Wuben TO40R to test it out. We need some 4000k and 4500k 90cri with good tint though for mass adoption in production lights.
The LH351D in this GB is T7 tint bin and the previous was a T6 tint bin. I’m thinking if there’s another GB, maybe we can try the T3 bin. That should eliminate any green or yellow.
How many of the 9080 219B do you need? What tint? I have a bunch on order from Clemence’s GB but haven’t received them yet. I might be able to send a few to you.
Thanks for the offer though, I don’t use the 9080 in my personal lights much for the simple reason that every other LED I own looks horrible after using the 9080’s lol.
Clemence had some E bin LED’s but they sold out, they appear to be what we have been wanting with 219B and 219C output except they lack the 9080 CRI. Although the only LED’s nichina offers with that CRI seem to be the E21A’s and similar LED’s that are hard to use in flashlights for various reasons. The 219C is much simpler to use which is why I am trying to use them.
Impossible is more like it, it seems they are out of production.
The SST-20 is a consideration but looks like they are only available in 3000k. Looking for something in the 4500-5000k range.
Right now the most likely candidate is the 219C E bin 9050. Should be like the 219B but with slightly lower cri. The best option available at the moment that I can find though all things considered. The E21A has so many design challenges it is the last resort.
But I thought you wanted to try 2000 to 3000k in your project.
I would prefer a 219C E bin 9050 than a 219B 9080 because that 5 CRI would be impossible to tell. The tint matters more and the 219C has so much better efficiency.
I have Clemence modded me a few Tiara headlamps with the 4xE21A. Seems like it is only good for head lamp applications with a frosted or diffused lens.
I also stumbled upon a Samsung LH351D 2700k 90CRI but I think unless you can select the tint bin, it’s probably going to be too yellowish/greenish like all of the other Samsung emitters that seem to sacrifice good tint for high efficiency.
I wondered that same thing and it seems they got the last of the 9080 219B’s that Nichia had laying around as they were not available when we got in contact with them.
Yeah, just looking for a whole lot of good tint LED’s. While I have a few novelty lights with warm LED’s I don’t find myself wanting to use them except in times where I am worried about my night vision for example.
