Thrunite Catapult V6 (mini thrower) // Full reveiw
104 posts / 0 new
toobadorz
toobadorz's picture
Last seen: 1 day 20 hours ago
gehrmo wrote:
toobadorz wrote:
wolfdog1226 wrote:
Maybe I used the wrong word[regulated] I love MAX output on the trail. The Cat V6 steps down like I said after ~ 2, 2.5 minutes. I just step it back and continue to do it. It is a pain in the ass! It is never too hot too hold for my leather hands.These manufacturers are over cautious,,,I guess it is in the best interest of the average Joe!
Yeah, I think you are right, Catapult V6 will step down from the MAX output, when either the temperature is too high or an internal timer like that is expired. However when the battery voltage is not high enough, the output of Turbo will then be reduced to a lower value (the MAX is no longer available). At this time the internal timed step-down seems disabled, and you can have V6 stay in Turbo as long as the temperature is not too hot.
And BTW, the included ThruNite battery is not powerful enough, you may get a Shockli 5500mAh or Keeppower IMR 6000mAh instead (both with PLB 55A inside).
!https://i.imgur.com/5pngbEp.png!
But will the Keeppower 6000 fit.
Yes it can fit, I have tried it.
toobadorz
toobadorz's picture
Newlumen wrote:
Unprotected vs protected 26650
Thrunite tc20 with shockli imr 26650
Turn on.. 3820 lumen
@30 seconds.. 3740 lumen
Thrunite tc20 with thrunite oem 26650
Turn on. 3860 lumen
@30 seconds.. 3210 lumen
Maybe your ThruNite battery is slightly weaker than mine, or it is not fully charged, or perhaps my TC20 NW is slightly under driven. My fully charged ThruNite battery performed exactly the same as the PLB 55A for the first Turbo shot, for the first two minutes. However it heated up more quickly and was unable to sustain the 2nd shot for more than half a minute. And the PLB 55A can sustain ~9 minutes (accumulated).
gehrmo
Last seen: 6 months 22 hours ago
Thanks toobadorz,have just ordered some.
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 5 months ago
Turn on. 3860 lumen
!https://i.imgur.com/HDCnziI.png!
Hi toobadorz.
Thanks for your testing.
When you say accumulated, do you mean that is the TOTAL time of turbo the battery can supply regardless of how many times you step back up to turbo?
How long of ACCUMULATED Turbo time can the PLB 55A with the CAT V6? I see you got 9 minutes for the TC20.
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
toobadorz
toobadorz's picture
wolfdog1226 wrote:
Hi toobadorz.
Hi Wolfdog,
Yes, the word “accumulated” means the runtime curves were measured by repeatedly cooling and then re-activating Turbo. I already posted my measurements for V6 Wink
~16.5 minutes. But since your V6 is driven harder than the stock version, this should be noticeably shorter.
wolfdog1226
Yes, I see the chart. So would that be 13 Minutes? Not quite 16 minutes.
Looks like 16:36 it dives and does not make it back to turbo.
One question. That is NOT totally dependant on the battery is it?
If a different driver was put in could the PLB-55A possibly sustain more turbo? I would think there would be enough voltage after 13 minutes to do this.
Just my guess as the guy who modded it is working on another driver.
,Thanks
        WOLFDOG
Swib
Last seen: 3 weeks 4 days ago
Just received mine from joker145 in pristine condition. Thank you joker. Beer With the stock battery the throw lives up to spec according to my meter (calibrated to known lights). The switch feels good and solid.
It does get a bit uncomfortable before the turbo/temp control kicks in but not so hot that you want to drop it. All in all a nice handheld shooter with great neutral white beam. It will be used primarily onboard the ship I currently work on by others so the usb charging makes it mostly idiot proof.
Kudos to Thrunite for making a nice compact 26650 thrower.
If you don’t like what it looks like on the wall, take it outside.
malocchio
malocchio's picture
Last seen: 1 week 4 days ago
I have one as well, really love it , and it’s very compact for the power…Does anyone know if a protected Orbtronic 26650 will fit ??
Malocchio
Swib
The supplied Thrunite battery is 68.78 mm long if that helps. The Orbtronic site says 68.8 so I don’t see why not.
wolfdog1226
It might fit. It is ~2.8mm More than the 5750mAh Orbtronic cell that I am using. I would certainly go with that one. It has more capacity/More amps/Definitely fits and a few $‘s cheaper.
The 5750mAh cell is 5mm from the top of the tube [see pic. below]
That would tell you that the protected Orbtronic 26650 [68.8mm] should fit but you have to take the compressed Negative “Tail cap” spring into account.
        WOLFDOG
malocchio
malocchio's picture
Swib and Wolfdog… thank you both !
Malocchio
wolfdog1226
Here is the supplied Thrunite battery. If Orbtronics measurement for the protected battery is correct, then it should indeed fit with some room to spare as you can see in the photo of the Thrunite battery which is basically the same size and obviously works in the light.
Swib gets credit for pointing out the supplied Thrunite battery.
I did measure the Thrunite battery [with a ruler!] and even though I was not using a micrometer, it indeed seems like it is ~68.9 mm.
I would still go w/ the Orbtronic 5750 20A[PLB-55A]. Wink
        WOLFDOG
Swib
I agree about the Orbtronic 5750 20 PLB-55A. From toobadorz’s graph it seems to be a better choice. However it appears to be a non protected cell. Not sure if that is really important to you.
wolfdog1226
Yes,,,that would be a personal choice for him. When I started this hobby 90% or more of my cells were Protected. Now it is the opposite.
Unprotected cells, especially IMR and similar ones, are unprotected for a reason. they are safer and do not need protection. As long as we have common sense, do not drain them too far, have a DMM and know our run times w/ each torch, then the Unprotected high drains are certainly a better choice. I have not had one safety issue with them.
        WOLFDOG
Swib
Nor have I had any issues with unprotected cells. In the lights that I make for others I just make sure to use a driver with LVP so they can’t over discharge the battery. I’m just about to push the button on flat top Orbtronics. Is that what you are using?
wolfdog1226
Yes.Will they ship to Canada at a reasonable price or are you getting them elsewhere? Shockli 5500 is also the same cell and so is the KP 6000mAh.
        WOLFDOG
Swib
Thank you wolfdog1226. I will have them sent to my US shipping point. Less hassle, cheaper, and I’ll get them quicker.
wolfdog1226
Here is a beam shot of the Catvn V6************ 1988L/194Kcd
        WOLFDOG
raccoon city
raccoon city's picture
Last seen: 2 min 6 sec ago
I cannot see it.
EDIT:  I get a 404 error.
deleted-200707
Last seen: 1 year 4 months ago
asks me to sign in to my Google account then shows an error
wolfdog1226
Ok,,Thanks.
I do not seem to be able to get a video on here from my Google account. All my pics and videos from my phone go to Google photos.Then I copy/paste on here and I am the Only one able to view it.
        WOLFDOG
Newlumen
Newlumen's picture
Last seen: 1 year 8 months ago
wolfdog1226 wrote:
Ok,,Thanks.
Next time, upload to YouTube..
wolfdog1226
Thanks NL. I knew I needed to do that but kept trying w/ google photos!
I hope this works,,,,,,,CATvn V6 NW 5000K 1988L/194Kcd w/ average video on my camera!
https://www.youtube.com/watch?v=6JVAS1xXju0&feature=youtu.be
        WOLFDOG
Newlumen
Newlumen's picture
Thanks for the video.. why do you have to double click again at 1:05 ? Was there a stepdown?
Newlumen
Newlumen's picture
I did the thrunite catapult v6 lumen test using Texas ace tube. Enjoy.
086_D6_E0_C-195_A-45_D6-_A854-97_D510_C43_BCE
F205_B0_F0-_C65_A-4819-96_AF-_E5_C8_D38_C7_C18
upload pic
E859657_C-_CC78-4600-_A25_C-606_C59_AD3770
wolfdog1226
I want to make sure it was on turbo. It steps down at first ~ 2 minutes,,,then about every 75 seconds after that. That is with the Orbtronic 5750 battery,,,same as shockli 5500 cell.[PLB 55A]
Thanks for the testing,,,that is almost the exact numbers on mine,,turn on and 30 seconds. But V54 used the Thrunite battery for my specs. Shockli/Orb. probably a bit higher.
        WOLFDOG
wolfdog1226
New V6 video w. special guest coming up. Probably tomorrow because it still is not on my Google photos yet.only on my phone.
Time to go to bed here in the suburbs of Philly,,,,SUPER BOWL CHAMPS! Time will tell,,they may do it again! Cool
        WOLFDOG
wolfdog1226
General thought here first. We all have to make best with what we have. In this case our video equipment and locations. I have some of the best locations with ZERO light pollution on these dark and isolated hiking trails.No city or Suburban lights. I just wish my video equipment[my phone!] was better!
Here is my V6 video w/ a special guest.My video recording was not the most stable as I was focusing more on my special guest!
https://youtu.be/8pEqjqQZdg8
        WOLFDOG
klrman
klrman's picture
Last seen: 2 weeks 9 hours ago
I just noticed in the OP review, turbo to LVP shutdown was 90 minutes.  Thrunite says 150 minutes but reality is 90 minutes which is -40% from specs.  Doesn't make any sense for manufactures to make such exaggerated claims on run times.  I was making a spreadsheet of run times for all my lights and was looking at reviews and came upon this one.
Pavlo
Last seen: 3 hours 2 min ago
Can anybody please measure the diameter of the catapult v6 mcpcb shelf or provide dimensions of the square mcpcb? Thanks
