Just wondering why my ROT66 could stabilize at ~700 lumens with a temperature of ~43Ā°C (at the head) after hours of testing. I tested it under a 25Ā°C room environment. One possible reason I can think of is, whether the runtime curves are measured directly with a integrating sphere or not. With the sphere attached, the light can heat up noticeably more quickly, so I used to measure this with simple ceiling bounce (and then apply an appropriate multiplier based on the integration result, of course). I may test again once my replacement ROT66 come back to me.
In the runtime test the head isnāt in a completely enclosed space, but Iāll check the temperature at 700 lumens with the light tail standing, thanks for the observation.
Canāt match your results even with a better environment for the convection to take place and without the initial turbo heat buildup.
At 26Ā°C room temp on the 7x7135 mode the head heats up to
45Ā°C at 15 min
46Ā°C at 20 min
49Ā°C at 25 min
50Ā°C at 30 min
52Ā°C at 35 min
53Ā°C at 40 min
It will probably still be handholdable indefinitely taking into account the heat sinking from the hand. Especially outside. So thatās a great choice for the number of 7135 regulators in the 219B model by Fireflies.
Interesting. Sorry that I forgot to mention: I measured the max temperature around the side switch, not the SS bezel. This is because the hottest part I may touch is simply around the switch. Iāll confirm that again once mine is back.
The wait for mine to come in is excruciating! Thanks for measuring the effect the lens has on the color output. The 700 lumen mode looks super ideal to me for its ruler flat regulated output and amount of pink to its tint.
This thing will be the perfect hiking light.
Are the optics used in the ROT66 the same or very similar as the MF01? How does the lux vs angle graph compare between the two?
I havenāt measured the beam profile for the MF01. It has more even beam, while on the ROT66 the lux fades more gradually towards the wider spill. Thereās more of a tunnel vision effect with the MF01, much like on an Olight with XM-L2 and optic.
Hereās a white balance and light level corrected comparison for the two.
This animated GIF is quite mesmerizingā¦if you concentrate and keep focused on the centre of the spot it looks like blast waves every time it switches between MF01 and ROT66. :nerd_face:
Thanks for the impressions! Is it as floody as an S41 when bout hare the same output? I found the S41 a little too floody for my tastes. Lower lumen outputs tend to lose some punch when thereās very little throw to them.
