Not dedomed, I sliced a few. After slicing close to the phosfor I sanded the surface with very sand paper. The result is 20% light loSs, 3400K end colour temp, 93CRI and a very very good tint. The 20% loss is more than average, I wonder if it would be less if I did an even better polishing job.
Awesome, tnx… how was the beam pattern? was this on a single or multi chip light?
Single emitter lights, the beam is very good. The only big disadvantage is the light loss, the lh351d is found to be a realtively efficient high CRI led, you loose that advantage.
hmmm, ok…. well i bought enough to do a few mods so maybe i’ll exp with a couple. maybe a whitegas dedome.
tnx again
Anybody measured cd with xpl HI and spring bypass??
What is the recommended method for Q8 spring bypass when the light is used reasonably often? I just added some solder blobs at the top and bottom and ran short 22AWG leads between them.
That’s all you really need. Some wire bypassing the spring nothing special.
My Samsungs came in so here’s the pix….
Fence is 100 FT away. Camera settings are locked all around.
Here you go:
GT stock
Q8 Stock
Q8 Samsung LH351D 4000K 90CRI
tnx jason!
Samsung LH351D looks very nice!
They really are! in person, even better, might be the best LEDs i’ve seen thus far.
And I bought only 8 of the Samsungs
Thats exactly what i said after i installed these on my Q8! “Damnit, i on;ly bought 8???”
GT stock
BLF GT @ 100Ft - ImgurQ8 Stock
BLF Q8 Stock Fence @ 100Ft - ImgurQ8 Samsungs
BLF Q8 Samsung +90 CRI Fence @ 100Ft - Imgur
Did you bridge the feathers on your Q8 with Samsung Led?
beg pardon?
beg pardon?
I think ‘deus1ex’ is asking if you’ve “bypassed the springs” on your Q8 with the Samsung emitters.
deus1ex:Did you bridge the feathers on your Q8 with Samsung Led?
FritzHID:beg pardon?
Ah! TYVM!
& yes, both lights are bypassed.
Yes that’s what I meant. Thank you
Speaking of Samsungs, since I happen to have both stock and LH351D (4000K high CRI) right now, here’s a side-by-side shot with daylight white balance.
