So hard but it would have to be
1) GT Mini
2) astrolux MF01
1) GT Mini
2) astrolux MF01
my Maratacs, Tools, and Olight Minis have hat compatible clips. as does my aspheric lensed Utorch
Klarus makes a more reliable version than the Utorch, still with aspheric lens, like the McGizmo Sundrop. Aspherics have really useful beams, to see my hands and what Im doing at arms length, with an indoor headlamp. It is the most amazing alternative to a hot spot and spill, for close use.
here is another pairing… stock 6000k Cool White (Cool Green) magnetic rotary with infinite adjustment of super low lows… very efficient and still able to reach out with 600 lumens… plus the modded Warm White 2000k Utorch Aspheric S1 Mini, as a battery backup, and headlamp… I recommend the Klarus version instead since its medium is 45 lumens instead of 100, so 6 hour battery life around camp with a headlamp
The upcoming ArmyTek Wizard Pro Nichia 144A and a Solarforce L2.
At what point does that stop being white and start being amber?
1800K.
I reject the limitation of only two, so I’d select:
RJ02 headlamp.
Q8.
UT20.
SP32Av2.
old/original SP10A.
1….Headlight…… Jetbeam Jet1 MK with cap clip.
2….Torch carry……Imalent DN35. (Shhhh, or Astrolux S41)
This IS from a choice of what WE own, ain’t it.
I’m discounting the throwers as such.
Olight H2R
Rofis MR70
I don’t consider a 2000k flashlight in my “only two” and I also don’t consider a mega thrower in my “only two”. So I will have to pick just good all around lights that just plain work. Out of the ones I own would be either a Lumintop Tool AA or Ultratac A1 and a BLF A6 or a Sofirn C8F. If I am in desperate need of a headlamp I will duct tape one of them to my head.
Souped up 4-6 D cell Maglite( for lighting and protection)
Sofirn c8 souped up
Oh yeah, I’ll be looking for that armytek
1) My Nichia 90CRI 4000K Skillhunt H03
2) Q8
Call 911, I’ve suffered a major brain aneurysm. :confounded:
“You can only have 200 lights. Which ones do you pick?” :disappointed:
One light for each head? You have two heads?
Perfect ..... and about 80$ total
but two lights is just wrong on many levels
Sunwayman V10Rti variable brightness modded with LH351D 4000k 90CRI for ease of use with just the right amount of light for the task at hand.
Second one would be a hard choice between Zebralight SC600W III or DQG triple with A6 driver running Narsil or Emisar D4 running Anduril. I just can’t say which one I would pick, thats a hard choice for me, Can I pick 4 lights instead?
Opps, forgot price.
$100 for the V10Rti
All but the zebra under 50 unless you count the mods, zebra $65.
Skilhunt H03 $30
Emisar D1S $35
Nitecore HC60
Then…… one (1) of these…
I paid $39 for the HC60 on sale.
$36 for the EA45S on SUPER SALE!!
M1 is around $22 if self built.
Paid about $18 for the Sofirn on sale.
1. Zebralight SC600w Mark IV 18650 XHP35 Neutral White High Intensity
2. Zebralight H604c XHP50.2 Flood 4000K High CRI Headlamp
I actually have them just for this reason - if I should take only 2 lights for longer time. They do almost everything well in a compact package with good reliability and efficiency, batteries are interchangeable also. Not the cheapest solution, but if only 2 lights are with me, I would hope for higher reliability for longer time.
