The upcoming ArmyTek Wizard Pro Nichia 144A and a Solarforce L2.
At what point does that stop being white and start being amber?
1800K.
I reject the limitation of only two, so I’d select:
RJ02 headlamp.
Q8.
UT20.
SP32Av2.
old/original SP10A.
1….Headlight…… Jetbeam Jet1 MK with cap clip.
2….Torch carry……Imalent DN35. (Shhhh, or Astrolux S41)
This IS from a choice of what WE own, ain’t it.
I’m discounting the throwers as such.
Olight H2R
Rofis MR70
I don’t consider a 2000k flashlight in my “only two” and I also don’t consider a mega thrower in my “only two”. So I will have to pick just good all around lights that just plain work. Out of the ones I own would be either a Lumintop Tool AA or Ultratac A1 and a BLF A6 or a Sofirn C8F. If I am in desperate need of a headlamp I will duct tape one of them to my head.
Souped up 4-6 D cell Maglite( for lighting and protection)
Sofirn c8 souped up
Oh yeah, I’ll be looking for that armytek
1) My Nichia 90CRI 4000K Skillhunt H03
2) Q8
Call 911, I’ve suffered a major brain aneurysm. :confounded:
“You can only have 200 lights. Which ones do you pick?” :disappointed:
One light for each head? You have two heads?
Perfect ..... and about 80$ total
but two lights is just wrong on many levels
Sunwayman V10Rti variable brightness modded with LH351D 4000k 90CRI for ease of use with just the right amount of light for the task at hand.
Second one would be a hard choice between Zebralight SC600W III or DQG triple with A6 driver running Narsil or Emisar D4 running Anduril. I just can’t say which one I would pick, thats a hard choice for me, Can I pick 4 lights instead?
Opps, forgot price.
$100 for the V10Rti
All but the zebra under 50 unless you count the mods, zebra $65.
Skilhunt H03 $30
Emisar D1S $35
Nitecore HC60
Then…… one (1) of these…
- Nitecore EA45S
- Convoy M1
- Sofirn SP32A V2.0
I paid $39 for the HC60 on sale.
$36 for the EA45S on SUPER SALE!!
M1 is around $22 if self built.
Paid about $18 for the Sofirn on sale.
1. Zebralight SC600w Mark IV 18650 XHP35 Neutral White High Intensity
2. Zebralight H604c XHP50.2 Flood 4000K High CRI Headlamp
I actually have them just for this reason - if I should take only 2 lights for longer time. They do almost everything well in a compact package with good reliability and efficiency, batteries are interchangeable also. Not the cheapest solution, but if only 2 lights are with me, I would hope for higher reliability for longer time.
Armytek wizard v2 CRI90
KDIY k5s 3000k
1. Zebralight H600Fc.
2. This one is a bit more tricky… if it was a thrower, I’d say the Emisar D1S. If I was to cheat a bit, I’d say a P60 host+modules including a Nichia 219C, XPL HI, UV, etc. Overall, I’d probably go with the BLF A6 in 5A tint, or ideally modified with a warm XPL HI.
