this is why someone wrote me to use 2 traces so the pins self center themselfes while reflowing
with this method no worrying about it, just put solder paste and pins on the board and reflow it, perfectly aligned
on most of my smaller driver designs going with a 6 viases programming footprint wont work, because its literally packed by tons of traces on top, and also the spring pad and other stuff will limit it a lot where you can place the programming port
Problem with this is often below the MCU is something that blocks it like spring pad or so
here a driver example with 24mm size, not as small as a 17mm for example, I had no idea if its even possible to get the 6 viases on my 17mm or not
I thought about it why not make a 7 pin pattern which works for pads and viases, and modified it a bit
I have no experience with this so I can’t comment on the design, but being able to program the driver without having to remove anything is just awesome Lexel. :+1: :+1: :+1:
It might be possible to make the connector even smaller though, by moving that ground via into the old ground pad’s location. Or maybe it could be useful to re-add the ground pad, so the driver layout can use either the via or the pad (or both) depending on what fits easiest. Sometimes a really small board could end up using only one orientation pin, but that’s not necessarily a problem. Small boards would even have the option of omitting both guide vias if space or layout restraints are tight.
I found aligning it on 0.8mm pads with only one via would be hard, but yes generally you could say make at least 2 of the pads as viases so the key aligns to the other pads
I think some people are underestimating how small this thing is with only 1.3mm pitch
likely best would wotk get 2 of the outer connections as viases, which ones they are is less important, but I designed 2 pogo pins to be sticking out further on the key (- and 2. centering via)
the further their disteance is the less gets twisting an issue just notice if used only 6 connection pins the max distance is 2.6mm
also thinking about a key with a header for USBasp
I say again, no need for extra alignment pins, just the six required for functionality. Make two of the pads (preferably spaced as far apart as possible) also vias, and it will self-align under pressure, all pins the same length.
Your key is far too wide at the bottom, no reason for this.
Yes it should have a header to accept the standard USBasp.
clunky?
if we use the standard idiot proof USBASP header with 10 pin and the plastic casing there is no means how small the front of the adapter is really noone wants to make a 10 to 6 adapter cable just to make the programming key 8mm thinner
lower end is 12mm and upper end 22mm right now, this is a lot smaller than my house door security key, no need to make it smaller than this
to give you an idea how small we already are look at the v1.1 size compared to my house key
as you self said the micro Key you can buy is too small for really safe flashing if you dont want to check if it sits right with maginification glass
there is really no need to make it smaller than an average Attiny MCU is just because it is possible with 0.33mm pogo pins heads on 0.5mm tube going to 0.7mm pin distance
we are not going to challenge how small it can be done, who cares if the pin distance is 1.27 or 1,3mm in real life on just 2x3 pin you wont see any difference with pogo pins anyways,
if you really want to buy the “standard 1.27mm” key you can fit it on my programming port with no problems
the additional Pogo pins are totally optional making placement and aligning of the key easier for people who can not solder 0402 or 0603 anymore because of age (Eyes or hands not allowing it anymore)
but you got to have some error margin in placing it on a driver
you ever destroyed a MCU because the SOIC clip or in this case a pogo pin key went off during flashing? No I dont want it as small as possible exactly to avoid this
and on complicated driver designs you are really happy if you can route a trace between things
so if you want to pay 10$ with shipping for a 1$ parts and 2$ labor costs adapter go for it noone is going to stop you bringing your drivers with this port on market
any chance you have a 0.8mm through hole model for Eagle? I would like to add this programming feature to the BLF ultimate lantern. The smallest through hole available is 1.6mm. Guessing the through holes are 0.4mm? I might be able to figure out how to mod the existing symbol but my CAD skills are weak at best.
Well if you find the key to wide you can always grind it down.
Or you buy at tindy. 50mil ist 1.27mm vs. Lexcels 1.3mm pin pitch.
Difference is 0.06mm with a row of 3 pins.
@lexcel
I would flip the silcscreen upside down on the right side in the picture.
To read the pin names when you use the key.
Also on the driver, you cant read the pins when the text is between the two pad rows
For the “manual” for the key I would advise people to clean the driver with isopropanol.
Maybe use a good contact spray?
Lexel has said that as he moves forward with new driver designs, they will be made to work with this programming key. Also, anyone who wants to may create compatible drivers.
Mostly, I just want this to be a thing… like, yesterday. And I hope we can get someone to manufacture keys and sell a flashing kit. It looks like a huge upgrade to how we’ve been doing things, and it could enable the use of smaller and fancier MCUs.
Lexel, I must apologise. Somehow I had got the wrong impression that you were duplicating the 0.1 inch pitch connection that has been around for ages.
I now realise that you have chosen the 0.05” (1.27mm) pitch micro key, which is the correct decision.
The “standard” pad layout is the same, just 1/4 the area.
The tindie micro key (others may be available) shows a reasonable looking pad layout, with a square pad to indicate correct alignment. I’m not sure how more “foolproof” it needs to be.
My suggestion would be to include the USBasp circuit on the key, make it an integrated solution, micro USB connector.
See e.g. USBasp - USB programmer for Atmel AVR controllers - fischl.de for some ideas. Perhaps there are more recent developments ? I just have the FastTech USBasps which seem to still do the job, but connecting them up is a pain. An integrated pogopin key that you just have to press against the back of the driver would be marvellous.
I just found this thread, and I really like the idea.
I have one suggestion, redo the layout so it is skinny, especially the tip with the pins. That way it’s as maneuverable as possible. It should feel like a probe when handled, not like a car key That fat handle was designed for twisting an ignition switch.
