Interesting, I have ordered them.
Products
Browse our full range of products from dressing tables to complete modern kitchens. Click here to find the right IKEA product for you. Browse online and in-store today!
Thanks Henrik! Will wait for your reviews to see if those chargers are any good.
@nquinn, I am currently using this charger.
I have the QC 3.0 24W+12W USB-A 36W iClever charger.
Other than getting hot at full power, it does exceed its specifications by a bit.
[quote=nquinn]
I’ve been looking for the lightest weight travel charger that (a) is high current so it can charge my phone+power bank at the same time and (b) is lightweight since I am an ultralight hiker.
This one looks to be only 2.5oz and would love for you to test it:
iClever BoostCube 4.8A/24W]
It does weight about 70g.
HKJ did test USB power supplies with less than 60g.
https://lygte-info.dk/info/ChargerIndex%20UK.html
40g - Test/review of LDNIO Dual usb charger A2202
43g - Test/review of 2USB easyCharge Plugin 12W
49g - Test/review of E-Strong ES-10 Dual usb charger
50g - Test/Review of LDNIO DL-AC52 Dual usb 2.4A
58g - Test/review of Ansmann 2.4A High Speed USB charger ANB0114
60g - Test/review of USAMS Led display travel charger
https://www.aliexpress.com/item/12V-400mA-AC-DC-Isolated-Power-Buck-Converter-220V-to-12V-Step-Down-Module/32689144361.html?spm=2114.search0104.3.92.a4bf3e8fPacbu6&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_10547_10342_10343_10340_10548_10341_10696_5013115_10084_10083_10618_10307_10059_5013415_100031_5013215_10103_5013315_10624_10623_10622_10621_10620,searchweb201603_2,ppcSwitch_7&algo_expid=8b2ca8ea-b926-4a84-911a-9c40b94d6d44-13&algo_pvid=8b2ca8ea-b926-4a84-911a-9c40b94d6d44&transAbTest=ae803_1&priceBeautifyAB=0
This is a power supply, not a charger, but if you can, i want to know about how safe and good it is
this PS would be very convenient for small project
A $1 power supply, I have ordered on.
I do generally not like AA based power banks. 4xAA is about the same energy as one 18650 cell.
http://mgb.maxell.eu/de/products/aa-battery-powerbank-936.aspx
https://www.ebay.co.uk/dsc/i.html?\_from=R40&\_sacat=0&LH_TitleDesc=1&\_nkw=790415+maxell&LH_PrefLoc=2
HKJ will do you a roundup of chargers for 2018? Or do you think this page is good enough: https://lygte-info.dk/info/roundCellChargerIndex%20UK.html ?
thanks for all the hard work!!
I have never done a roundup of chargers, in late December I do a status where I list some noteworthy products from my testing during the year.
That's what I probably meant.. I thought you sometimes showed a list of recommended chargers...
I’m not looking for a power-bank but a portable/small form factor LSD Rechargeable battery charger, able to use it as a power-bank will be useful/bonus but not a criteria.
Question is….has anyone come across a USB portable AAA AA charger which also acts as a power-bank and charges individual cells. Something like a Xtar PB2 but for MiNh
Charger & Powerbank:
https://www.amazon.de/reVolt-Powerbank-Batterie-USB-Powerbank-Batteriebetrieb-Weiß/dp/B00ENG4GXE
https://www.amazon.de/equinux-tizi-PowerSnack-universelles-konventionellen/dp/B00QWZ02L4
https://www.amazon.com/Verbatim-Power-Bank-Charger-97928/dp/B007MLHS2S
https://www.amazon.com/SANYO-eneloop-charger-output-KBC-E1AS/dp/B002S0N8X6
https://www.ebay.com/itm/MOBILE-BOOSTER-AA-ENELOOP-CHARGER-CON-PRESA-USB-SANYO-KBC-E1S-NUOVO-lrx/302799612441
Charger only:
https://lygte-info.dk/review/Review%20Charger%20Ikea%20Vinninge%20403.036.32%20UK.html
How do you think about XTAR VC2S?
https://www.gearbest.com/chargers/pp_009649709878.html?lkid=15540141
I do not have anything to say about it yet, but Xtar has promised me a review copy.
Nitecore UMS4
UMS4 is a QC input available intelligent USB four-slot superb charger with a total max output of 4,000 mA and a single slot max output of 3,000 mA.
With LCD display for real-time charging information, it is equipped with a USB charging port for outdoor charging
UMS4 is a QC input available intelligent USB four-slot superb charger with a total max output of 4,000 mA and a single slot max output of 3,000 mA. With LCD display for real-time charging information, it is equipped with a USB charging port for...
I definitely want to review that charger, but it will first be next year, I have a lot of chargers in queue.
Nitecore UMS4
That looks a bit similar to the Nitecore SC4 (SC for “Superb Charger”), except it uses USB Quick Charge voltage to power that charger.
If it’s sort of a modification from the SC4 to adapt for USB QC input voltage, hopefully it won’t have the bugs/”features/annoyances” that are present in the SC4 (the SC4 time-sharing of charging certain slots seems to be also present in other Nitecore chargers; but also in some SC4, the capacity charged display can display grossly incorrect charged capacity results, as mentioned by several user reports when the SC4 is charging all 4 slots, maybe related to the “charging time-sharing”?)
Hi HKJ, hopefully you can fit the Zanflare C2 into your queue.
https://www.amazon.com/Display-Universal-Zanflare-Rechargeable-Batteries/dp/B07F3KMVTM
Probably not this year, I have a lot of chargers in queue at the moment.
How about flashlights with built-in chargers?
Here’s a comment on the charging behavior of the Sofirn SP32A V2.0
that’s currently being offered at a discount (read the first post, email them for a code):
Thank you for the hint with AliExpress. Concerning the voltage: I’m not saying the charger is dangerous nor safety would be at risk for the battery. Instead, the battery will be worn down quickly for pushing it to/beyond its specifications. It’s not only the 4.21V but also the extreme long CV phase that is applied to the battery. Usually, voltage drops from 4.20V to 4.14-4.16V when charging is finished as the termination phase is rather short.
