I think it’s the best stock Hot Rod light I ever purchased for the money. I can’t seem to stop playing with it or having it out of reach for some reason, Crazy huh?
Fits in one of my holsters well, but I don’t want to take a chance on scratching it. Heck I’m not even going to mess with it and bypass the springs, it’s that remarkable to me!
TK/Hank you hit this one is out of the park, outstanding job! :+1: Thank you!
I’m glad to hear people like most of the new stuff. I haven’t gotten much feedback about the stepped ramp yet.
This is the first negative feedback I’ve heard about the instant moon feature. If you’d like to disable that, comment out this part of the code:
// hold (initially): go to lowest level, but allow abort for regular click
else if (event == EV_click1_press) {
set_level(nearest_level(1));
return MISCHIEF_MANAGED;
So, everyone, what do you prefer?
A. Activate the lowest level immediately when the button is pressed. Provides a hint that “click” and “hold” do different things, but requires the user to time the button release without direct feedback. (RampingIOS V3, Anduril)
B. Don’t respond when the button is pressed. Takes longer to get any light, but makes moon timing easier. (RampingIOS V2, NarsilM)
Basically, what do you prefer for step 1 here?
At button press…
A. … turn on at the lowest level.
B. … do nothing. Stay off.
If user releases button quickly, go to memorized level.
If user holds the button for 0.4s, lock in the lowest level. User can release the button at this point to stay at the lowest level, or keep holding to ramp up.
Happily, just pulled the trigger on 2 D4S, grey 219C and Green XPL HI 5000K NW from MTN.
I was considering the XPG2 5700K version, but budgetary limits kick in. Would anyone help describe the differences between the XPL HI NW and the XPG2 S4 2B: tint artifacts, throw and output differences, runtime?
Any and all opinions and recommendations are welcome, as I am a long time CW bias recently converted to NW and high CRI, seeking the knowledge of others with experience.
Also, decided on the Shockli 5500 mAh cells, any other recommendations?
Is there a way to calculate lumen for the stepped ramp?
With the known max output, no. of steps, steps for top and bottom ceiling?
I think of a spreadsheet, you type the values in and get the lumens for each step.
It’s hard to do because of how different LEDs have different lumen levels, and in the FET modes, it also depends a lot on battery type and voltage.
Aside from that though, basically you’d have to look up the PWM values from the firmware’s ramp table, calculate the power level, then look up that power level on an emitter test graph.
Or try the bin/level_calc.py tool, which produces a relatively naive estimate of how many lumens it expects. These numbers may not match actual measurements though, because it doesn’t know the emitter’s response curve and may have been given intentionally wrong values in order to force the graph into a particular shape. Like, for the D4S, I told the calculator the lowest level was 11.2 lm and the highest was 4000 lm, and that it should use a ninth-root curve shape, because this got the values to line up how I wanted. But in reality it’s more like 0.3 lm to 5000 lm.
I have an authentic basen 5000mah with 50/60a pulse. there’s also the basen 4500mah with 40/60a pulse. have you checked those? I don’t have your set up to check the specs in the light itself. I almost bought the 4500 but it doesn’t have Basen written 4 times on the top of the battery like my other one does
At first I blinded myself a few times with this feature as well. And I couldn’t figure out what I was doing, or doing wrong anyway.
But after figuring it out, I’m happy with the way it functions. I do have to click and hold longer than expected, but there’s sufficient delaying before ramping up off moon to land in that I’m no longer bothered by it.
I’m still not ever sure what I’m going to get for a double click from off - last used mode, some random mode, or turbo. I’m aiming for turbo, but I’m not sure I always get it. And speaking of double click, the thermal reduction is so smooth you don’t notice it, so if you double click to turbo, and the light backs off a smidgen due to throttling, and you double click again, basically nothing happens cause you go back to turbo.
Since I just ordered my green D4S from Richard yesterday and I don’t actually have one yet, I built another one. This time in solid copper.
I made a Te/Cu head surrounding the Noctigon 33mm Quad MCPCB with Angie optic and mated it to the full copper body of an 18650 Sinner light. Not having my springs yet from Blue, I’m making do with the “measely” 5685 lumens out the front provided by an Sony VTC5A 18650. (output courtesy of 4 Samsung LH351D 5000K 80 CRI emitters)
