Diffuse the light. That will take some balancing to get it right but it will be easier and more reliable than tinkering with your meter.
Thank you, that was my second idea, but my favorite was to change something in my meter.
Now I added a DN25 electric installation tube with 6cm length, to put the sensor to the outside of the sphere. It lowers the readings by factor 10.
No 30.000 Lumen eqals around 50.000 Lux. This means my sphere can read around 100-120 kLumen. That may rest around 2 years to get such a flashlight, I think.
Measure a lower mode in the sphere and calculate the relative difference between that and higher modes in some other way (ceiling bounce for example). Or put a diffuser/neutral density filter in front of the lux meter. Or what you just did
I have alread a Lumen-Box, but I noticed that the readings for over 10-15 k Lumen are too low. So Now I make further readings in the Toilette. But I wanted to get better readings for all output levels of a flashlight. For my Imalent DX80 and others like Olight X9R, Acebeam X80 and upcoming flashlights. Thats why I build the new integrated sphere.
And with diffusing the light before it hits the luxmeter, I will get good readings, I hope.
If you want a very neat way to diffuse the light you can use a satellite sphere (which is indeed called a diffuser in the literature) where the luxmeter sensor used to be, and put the sensor in there (you even gain some integration). The sensitivity decrease can be set by the size of the connection hole: the inner surface area of the satellite sphere divided by the surface area of the connection hole gives you the decrease of the sensitivity.
(I made one sphere with diffusing satellite sphere: Integrating sphere #3 (portable and overly stuffed with features))
Last night I built up this old SK68 driver board from warhawk-AVG and then stacked it on the stripped driver board from a SolarStorm SC02 then flashed it with single mode (100% + hidden strobe) eswitch-13 FW from Tom_E then installed a Chinese no-name-brand XP size 365nm UV emitter that, other than a high vF performs very well and actually outputs a good amount of 365mn light (25mm ZWB2 filters on order from AE, does have a bit of visible light too).
This is one of the lights for my next GAW.
Power and GND connections between boards so only LED wires and the one switch wire are on top.
Looks good. How is the output relative to a FET triple?
I didn’t have a chance to compare, but the light is quite bright. I spec’ed the driver to 4.2a output and 10.5a input, and ran the light on a Sony VTC6. I think that puts the light at around 2000 lumens, so I don’t think it puts out as much lumens as you can from a high output FET triple if you’re only concerned about the lumens. However, there’s nice things you get from so many lumens from a single led. I will say that the light gets hot pretty fast. One word of warning, just make sure you work out the length of your battery in relation to your switch spring and battery tube since the driver comes with a brass button for contact. I crushed one of my batteries a little while testing.
Crushed because it was a longer button top or crushed because you had a long/stiff bypassed tail spring?
Crushed because there is a solid button which can’t deform under load.
That either meant having a longer cell like contactcr said, or perhaps he dropped the light, and that can easily result in a damaged positive electrode.
Finally upgraded the old beaten up TK35 clone with a Luxeon V (4000K) running at 6A and a LM3409 buck driver with Anduril. Should be around 2000lm on turbo with a comfortable 2.6A battery draw.
Very nice beam with the smooth stock reflector. Good tint.
Not exactly a looker, I know. Neither on the inside nor on the outside. :laughing: And you haven’t even seen the ugly bits.
Works like a charm though. Better than new.
what did you use for your centering ring?
A piece of acrylic, turned on the lathe. It’s mostly for visual guidance during centering though, I only had a 16mm star where a 20mm would be the right size, so that was a bit tedious.
It doesn’t have to bear any load since the LED pill rests against the reflector flange.
It also helps keeping any dirt from getting inside.
My switch spring was a bit stiff and a bit long. Plus when I was testing out the light, I put the battery in through the head side and screwed in the head. I found that my flat top of my battery was crushed a little bit. I don’t think it’s something to be alarmed about but nevertheless it’s deformed a little bit, fortunately it’s only cosmetic. However, I can see if you have a long stiff spring on the tail side that it would be easy to crush the battery a little bit if you’re not careful.
I modded my Emisar D1S into a single-mode light! :person_facepalming:
Since I was reflashing Andúril onto the GT mini that arrived today, I opened the D1S to update it, too.
I tested it before reinstalling the reflector, and all was well. After reassembling the front end, it wouldn’t power on.
It turns out my emitter board solder joints were slightly too large and positioned too far toward center. Both shorted against the reflector.
With the reflector removed, the light comes on when power is applied. I got it to ramp up and down slightly a couple of times, but it’s now a single-mode driver.
I hooked it back up to the PC and the ATtiny85 is still responsive. I reflashed Andúril in case it was corrupted but that hasn’t helped.
It seems to be stuck at a moderate output level, not turbo.
I’ve already emailed Hank asking how to order a replacement driver, but does anyone knows what component(s) I’ve damaged?
Replace the FET. It’s an Infineon Mosfet. BSC009NE2LS5IATMA1 Infineon Technologies | Discrete Semiconductor Products | DigiKey
Thanks, KB! :+1:
Looks like I’ll be putting together a Digi-Key order…
EDIT: Or, maybe not. They’re on backorder at DK. Mouser too.
Thanks, KB! :+1:
Do you live in the U.S? I have plenty of them!
You can use these too, just as good, and cheaper…https://www.arrow.com/en/products/psmn1r7-25yldx/nexperia I have plenty of them too… yeah I roast a few now and again…
It’s up to you….
That’s very nice of you, especially since I still owe you for the 70.2 MCPCB you sent me!
I see that the FET you linked from Arrow is a ‘4-pin and tab’ layout.
Is that a suitable replacement for the 8-pin one on the Emisar driver? What orientation would I mount it in?
I’m a bit in over my head as far as driver design and theory is concerned.
Yes it works, solder across the back, Tab is ground. Same with the 4 pins in the rear of the Infineon, (underneath the FET) the large base is ground. It will all become clear when you remove the old FET.
