The other way around.
Thanks Pete!! Do you know if they are reliable? I read lots of reviews on Amazon and lots of people were saying great and lots were saying fat/don’t fit. So I’m wanting the black cells for more cycles.
In my experience, the newer “Made in Japan” ones are great. I’ve been using them for a while and I keep buying more from time to time.
To put things in perspective, even the grey ones are rated for something like 500 cycles. If you recharge them once per week, on average, they will last you almost 10 years. Now, if you’re going to be recharging them every single day, then by all means, go for the black ones.
Never thought about it that way Pete. Thanks again for clearing that up for me. Looks like I’m going with them grey ones. Save me some money compared to them Eneloops. Slow charge them with my Maha Powerex charger? Or use the Panasonic BQCC55 (got the BQCC17 also). C4-12.
Oh I also have the Liitokala Engineer Lii-500 charger.
Shouldn’t matter which one of these chargers you use.
Any charge rate up to about 0.5C should be safe and not stress the cells at all.
Ok definitely soft or slow whatever for the Maha. Rapid charge finishes AAs crazy quick. Thanks. Should I do the whole break in thing first when I get them? Does it really matter. Break in with charger or just from normal use. Kinda same ish I’m thinking.
I would just start using them.
I usually run one test cycle on them—If you’re using them in pairs etc—you can kind of half match the sets—also if they don’t test out close Amazon will make it right
I’m going to mostly be using them in my 4 and 6 cell powered lights. So I’m going to have to buy 16. Maha powerex has a “condition” mode on it. Is that the same as test cycle?
Charge, discharge then charge again. Or on the Engineer it has that Nor test mode and shows all the mAh voltage and stuff. Maha just blinks. Bought Maha mainly for my C and D batteries
Huh? Apologies if I ruffled feathers. Not worth the contention.
I may have overreacted. Sorry Flyboy. Having a really rough week. I am using the AA to D adaptors I already have in them cheap Eveready flashlights. That way I will have more AA cells. My EBL cells are really old and don’t hold much charge anymore. I use rechargeables in everything. My TV remote don’t work with the EBL except a few of them.
So I guess I really didn’t need to include the party thing. I just don’t want the price of Eneloop if the Amazon are similar for less $.
My powerex charger has a refresh/analyze mode—you can set the charge discharge rates—with the rest periods in between cycles it takes forever— I usually charge up the cells on other chargers to speed it up a bit—- the opus and litokala are lots faster
Do you have the MH-C808M? I can’t adjust anything on mine other than doing a soft charge or condition mode.
I have the Engineer Lii-500. Is that the one you use?
Powerex MH—C9000 and the Lii 500 —- do the noir test on the 500 —you can set the charge rate —it has preset discharge rates 500ma and below uses a 250ma discharge —- 700ma and above uses a 500ma discharge —I use the higher ma on AA cells
Do you think 1000mah is Overkill on AAs? I got my EBL C doing noir test now just out of curiosity 1000
I use to do 700 ma but I read some post I think from HJK that said if too low a charge current is used it affects the cut off —I don’t know for sure—in most all my cells Ni-Mh Lithium etc —I usually stay some where around half the capacity for my charge rate
So if I’m understanding this right, for a 5,000 mAh C I would use 250? If that’s even possible on the engineer li500
Alright so I officially confused myself lol.
So my 26650 Keeppower 5200 mAh on the Lii500 what would be half capacity?
You would use 2500 mA, but Lii500 only goes up to 1000.
