Lexel, DEL describes the driver board a little bit in post 736. After the images, at the bottom of the post, it tells what U3 is among other things. Here’s the relevant text:
U3 is a precision DC opamp and does the closed-loop current control for the LED driver (driving a meaty FET in linear mode). A sense resistor creates the feedback signal. The MCU (a venerable tiny85) generates the reference signal. Driver dropout should be < 150 mV, giving regulated control down to about 3.2 V.
U4 is an all-in-one power-bank chip from TI’s BQ24 or BQ25 series (currently looking at the BQ25895, it is also used in the higher end Xiaomi power banks).
I still have itchy spots which crust over then thicken and split open on my arm from a cat bite 5 years ago. Sounds worse than it is, but the point is don’t underestimate animal bites, some of the bacteria they can carry are nasty.
What sort of people does Barry have working for him if they need to be spoon fed everything? Are they simply a build to print contract manufacturer that makes flashlights?
Well, he has already been making a lot of driver designs, so he has plenty of starters to make this from. Changing a few things here and there doesn’t take very long. But, the point remains, and I agree - he’s awesome! Thanks from me too, Lexel!
Wow awesome work on this!
I like the idea of having solderable bridges for the 7135s, ( as in comes from the factory with 4-7135s in stock output level, but modders could easily bridge a trace to increast the output to 6 or 8 AMCs or less)
