I still have itchy spots which crust over then thicken and split open on my arm from a cat bite 5 years ago. Sounds worse than it is, but the point is don’t underestimate animal bites, some of the bacteria they can carry are nasty.
What sort of people does Barry have working for him if they need to be spoon fed everything? Are they simply a build to print contract manufacturer that makes flashlights?
Well, he has already been making a lot of driver designs, so he has plenty of starters to make this from. Changing a few things here and there doesn’t take very long. But, the point remains, and I agree - he’s awesome! Thanks from me too, Lexel!
Wow awesome work on this!
I like the idea of having solderable bridges for the 7135s, ( as in comes from the factory with 4-7135s in stock output level, but modders could easily bridge a trace to increast the output to 6 or 8 AMCs or less)
It is much more important to have rosy tint, and CRI over 90, and R9 over 90, on either 3000-4000-4500-5000-5700k. It really does not make that much of a difference in real life. 3000-4000k with that high of a CRI is basically the same.
They’re building this thing to a DBSAR / BLF spec, including some very detailed and specific requirements. The simplest way to make sure everything is included and the spec is actually met is to get as much detailed design from DBSAR and BLF as possible.
Basically, Barry and his people are trying to make sure that they understand the needs of the project and stop any mistakes or misunderstandings creeping in right from the start.
I applaud them for that, because it’s an article of faith in any engineering project that correcting mistakes gets drastically harder and more expensive as you reach later stages of the project.
I understand that the desire to keep it simple is based on the assumption that things will move faster and cheaper, or that the process even gets stuck if the design becomes complex. But you do don’t know that at all, that may be not true. A design with more features as this project is turning into may be easily achievable by Sofirn and may result in a more complete product that will be more useful and sell to a wider audiance that may have slightly different demands than you.
