The very warm to neutral customizable high CRI tint and promise of the complex software features are what drew me to this light. If I wanted something relatively simple I’d just buy Zanflare T1 lanterns and never bother with a more premium lantern at all. I am buying a Zanflare T1 anyway, but that’s just because I’m a flashaholic and can’t stop myself…
Quite a few people (myself included) would use that feature and it is a big selling point. Without that “silly” feature and a great UI (what ToyKeeper has mentioned of the UI sounded quite enticing), I don’t think there would be enough to compel me to buy it over other cheaper lanterns or a diffuser.
The bigger the spread the better, in my opinion. The Samsung LH351Ds from what I’ve seen are an excellent choice.
Someone has to design it. Designing parts of this lantern has been slow sofar, only now even the driver takes final form and I believe it is nice that it is being done at all and that it will have nice options and firmware. And an even more efficient driver without PWM like you suggest (I agree that for a relatively low-powered light like the lantern a FET-based lineair driver would be a suitable application) would require lots of extra expertise and time. Apart from that, I wonder if you could get output and tint ramping done without old-school PWM?
I will suggest to the manufacturer to try to source the 351Ds in 2700K for the warm side and 5000K for the cool side of the two channels for tint ramping, that will give a good range of tints.
I think it is too much to ask for Sofirn, but if you never ask for it you will certainly not get it:
Could you ask for the 2700K led for one of the colour-bins W1 to W8, and for the 5000K leds for colour-bins R1 or R2? These Samsung tint bins are on or below the black body line, if Sofirn was able to source them (in 90 CRI of course) that would be awesome for the tint of the Lantern.
I am in search of a bit of education in regards to efficiency and driving LEDs. In the area where I am familiar, power supply design, PWM kicks the doors off efficiency vs linear every day of the week. What is it about the LEDs that this is not so? Is it that the voltage drop across the linear regulator is small, due to the close LED Vf and the prime voltage source (rechargable lithium battery)? Or PWM plus the linear current regulators is double loss? I would be interested to read more about this if someone can point to some reference material.
It’s the LED itself. Lower current = more lumens/W. Some of it is due to less heat (which I think does not change significantly with or without PWM) but I believe some of it is intrinsic to the conversion of electricity to light. And that part means more efficiency by running at say 1 mA than at 100 mA with 1% duty cycle.
And the PWM we talk about here is not the PWM of power supplies. It’s a duty cycle for a linear regulator… nothing efficient about it. Some drivers do have more efficient design of course, much like modern power supplies.
One last thing: I don’t know about the LEDs being discussed here but some change tint and probably CRI too depending on current. So a linear driver might not be desirable at all because of that.
And I learned most of that around here. Couldn’t dig up the exact threads but djozz’s LED test threads are usually a good place to start to read technical discussions. So are the driver design threads. Unfortunately some of it may be lost in other places. Stick around and the information will eventually percolate lol
@DBSAR, I have already spoken to Sofirn about the bin tints and LED tints to use with the right order code. That was a WHILE back though, so they may not remember about it.
However, if Barry can confirm which LEDs they’re using, they should be these, if I’m not wrong:
@sbslider, this is in regards to the type of linear regulator used. It can either be a single purpose linear regulator, like a 7135, or a FET used as a linear regulator
FET as a linear regulator, will always be better, but let me explain.
- A single purpose linear regulator will run at a constant current set by its specs at 350mA.
If ran at 100% duty cycle, the linear regulator will output 350mA to the LED.
If ran at 50% duty cycle, the linear regulator will output AN AVERAGE OF 175mA, meaning the LED will still see 350mA, but at half the time. This is what we usually do in linear drivers. However, they don’t behave well at thousands of hz, and the efficiency of the LED stays constant, even though the average current will be lower. While in fact, it should be more efficient.
This is where the FET as a linear regulator is very useful, rated at say 350mA.
- If ran at 50% duty cycle, it will output a constant 175mA, meaning the LED will now see 175mA, and its efficiency will be increased at lower current, along with the FET easily handling 100s of kHz of frequency, removing parasitic inefficiencies.
The major downside to the 2700K is the significant drop in efficiency compared to the 3000K. I’d prefer 2700K of they were the same or close, but would prefer efficiency since they are not.
@ BlueSwordM and fixed it, thanks for the explanations. I definitely have noticed that LEDs get way less lumens/mA (or lumens/W) when they are driven very hard. But I was under the belief (perhaps, or likely wrong) that at lower drive currents, the lumens/mA curve was pretty constant. So with 4 LEDs each drawing 350mA (fairly low current) the efficiency of the 4 7135s can be no worse than the efficiency of a single FET. But at lower currents, if the switching performance of the 7135 is lousy (sounds like a great BLF improvement project!!) then I can see where the efficiency of the single FET would be better.
I don’t know what Lumintop did to offend you, but it would be great if you could stop spamming every single thread. If you have something to say, make your own thread and say it.
