Newlumen has the 4” TA lumen tube which is the same as mine. Our numbers used to match reasonably well until I received the Maukka calibration light, which is when I realized my TA lumen tube was reading 16% too high. Newlumen has a set of the Maukka lights on order and we will find out soon.
Steel_1024 measured 4,880 lumens with his TA Lumen Tube but not sure if he has a set of the Maukka calibration lights to confirm with. The TA Lumen tubes that weren’t calibrated with the Maukka lights were reading too high.
Charles Lin measured 4,740 turn on lumens and 4,300 at 30s with the TA Lumen Tube. But it might be his TA Tube also does not have correct calibration and reading too high.
I’m not saying your measured 5,700 lumens with the ROT66 219B is certainly incorrect. Just saying there’s a good chance and the only way to confirm the accuracy is to get a set of the calibration lights. It’s very affordable anyways.
My Nichia Rot66 just came in yesterday so I can add some numbers to this:
Turn-on: 4520 lumens
30 seconds: 4050 lumens
That’s taken in a TA tube that’s been calibrated using a set of Maukka’s lights, and generally jives with the other numbers given here which seem to range from ~4300-4800. Except for your reading of 5700 lumens, which would mean that yours is ~26% brighter than mine. Almost two entire flux bins higher. I hate to use the word “impossible” but….
Got my ROT66 with Nichia’s, really nice!
Output at switch-on (it takes 3 seconds before the first read-out): 4300 lm, at 30 seconds 4000 lm. This was on freshly charged 30Q’s.
I do not have a stock D4 left (I do have a pretty :sunglasses:
one with LuxeonV’s though ), but I trust my ROT66 measurements to be correct within the 5% that I stated above.
My TA Tube, ceiling bounce and my Lightbox all have the ROT66 way ahead of my D4’s and D4S. Just visually outside you can tell too. I hope my youtube review gets it across.
I’m not going to your youtube despite the shameless plug but it’s not surprising that the more floody the light the more impressive and bright it looks.
You no longer have a TA tube. You have a box of your own making, calibrated as far as I can tell to some arbitrary factor to make you high lumen lights read what you “feel” is the right number
It has been nice to read the posts till here, even for a guy that doesn’t have money to buy this flashlight!… Let’s keep it that way!
Please, let’s keep the thread clean about the TA tube or KG lightbox or whatsoever!!! That issue is beyond contagious and exhausting for those that just want to read some things and see some beamshots…
Create a proper thread to discuss that, compare measurements, improve readings, whatever…
But please, let’s keep the other threads rolling about the issues they were made to present/discuss! In this case, the above mentioned flashlight…
Instead, give us some beam shot comparisons, tint comparison of the different leds, something the make us get and :laughing: and even :heart_eyes: , instead of :weary: or :person_facepalming: and eventually
That is a WOW
I believe the tree further away will be like 40-50 meters and still being quite illuminated !
This beam is one of the reasons why I like flooders over throwers!
