Yep! Set up exactly as T/A’s instructions for the diffuser’s, I check calibration before each use… And I keep it covered with the BLF GT Hoodie.
It’s helped me find the weakness in a few of my mods, that I have gone back thru them and made them a bit better. :+1:
ZozzV6
(ZozzV6)
August 28, 2018, 10:08am
776
Newlumen
(Newlumen)
August 28, 2018, 7:55pm
777
So here is the comment made by skylumen ( pro modder ). He doesn’t go to blf. Here is what he wrote, “ D4S just came in. WOW, this is the best Emisar.”
Thanks TK, Hank, and everyone who succeeded this project.
Did my first UI flash! Woot!
Received a bunch of errors…hex file was in wrong location…(noob)
A little tricky, but had great instructions and am fairly computer savvy…was able to power through it…
Put in correct location…Anduril flashed!
Thanks for help Fate0n3 and ToyKeeper!!
SKV89
(SKV89)
August 29, 2018, 1:38am
779
Kawi, that is freaking incredible that you got 5000+ lumens. Which emitter did you get? I only got 3,800 lumens with my D4s XP-L HI 5D using my TA tube calibrated with Maukka lights. I’m kind of disappointed. I was expecting 4.5k lumens
Newlumen
(Newlumen)
August 29, 2018, 1:41am
780
SKV89:
Hey skv, I told you. I got 5000 lumen @ turn on for my xpl 5000k… Kwai tube has been calibrated with maukka lights.
My Emisar family
ZozzV6 - Those are the same four lights in the same color combination as I have. The only difference is I usually have the short tube on the D1 to make it more pocket-friendly.
ZozzV6
(ZozzV6)
August 29, 2018, 3:41am
782
And the little orange led in the D4. I also have a short tube but in blue for the D4.
nhozbaod
(nhozbaod)
August 29, 2018, 3:54am
783
ZozzV6
(ZozzV6)
784
Yes but use decent high drain unprotected cells.
My early D4S prototype can’t even fit most 26650 cells, so I used an 18650 with some packing foam around it during the initial development.
Yes, a cell size converter should work… as long as it’s a good cell.
SKV89:
Both D4S’s are XP-L HI V3 1A.
ZozzV6
(ZozzV6)
August 29, 2018, 10:38am
787
Mine is an XP-L HI 3A and I got 4800 lumens with Liitokala black 26650.
Apples to Apples Kawi, Washington Reds to Granny Smith maybe but…
6216.9 lumens (start value)
Samsung 30T powering the 4 Samsung LH351D emitters.
mikeyx
(mikeyx)
August 29, 2018, 4:33pm
789
I just tried to flash my D4S and it seems that the vias are too small for the pins on the Dupont cable. Has anyone else hit this problem ?
Thanks,
Mike
ya…I used some old solid core telephone wire
blueb8llz
(blueb8llz)
August 29, 2018, 7:09pm
791
I wonder why the blue was not an option. That was a beautiful color.
Newlumen
(Newlumen)
August 29, 2018, 7:48pm
792
Where did u buy Samsung 30t ?
Newlumen
(Newlumen)
August 29, 2018, 7:57pm
793
Thanks zozzv6 and kiwi. I am getting 4900 to 5000 lumen at turn on for the xpl hi 3A. I will report back with new number when i get my calibrated lights from maukka.
mustig
(mustig)
August 29, 2018, 8:14pm
794
Mine has quite loud PWM when the mosfet is active. I usually don’t hear it from other lights. Anyone got the same? Defect driver in mine?
Love the light otherwise.
