Fortunately most of that power is converted to light instead of heat. My 80+ platinum power supply can run fanless on my overclocked i7 7700k with overclocked GTX 1080 and three harddrives, which produces a couple hundred watts.
You can’t say “most of that power is converted to light instead of heat”. I think only 25% to 30% gets turned into light. The other 70% to 75% is heat.
I think you’re confusing driver efficiency with LED efficiency. A good buck driver might be 92% efficient. So your computer power supply might be pretty efficient, but it’s not the main source of heat.
This light will probably set the bar for a very long time if knowing acebeam and their quality. Now its only wait and see what the actual runtimes will be and how long it can last with 600wats, but damn that much lumens is just insane…
OK that is pretty awesome right there, these light manufacturers are really pushing the limits big time.
Now I see something a little different, is the flashlight itself actually fan cooled WITHOUT the handle or does the handle add a secondary fan to help with cooling orrrrrrrrr is it just the handle that is the fan cooling?
That is def a new idea you don’t see done much. I wish they would add more mass to the head of these giants to help with heat a little more.
I do wonder tho how much the human eye can tell a difference between 30k and 60k, maybe some of you could have some information on how the human eye handles that levels of brightness
As for “how much brighter”. I think it kinda depends on the reflector design. With flood lights, 30k vs 100k lumen flood lights, there isn’t a MASSIVE difference. Where it gets interesting is the lights with larger, deeper, reflectors with a range of 800-1000+ meters. While a light like the WS10 might be 250 lumens and 1000m, it’s a pencil thin beam. So with massive numbers like this, instead of illuminating a door 1000 meters away, you can brightly illuminate the side of a warehouse from 1000 meters away.
The reflector where XHP70.2 sit in seems to be much shallower than MS12. I think it will be much more floodier than MS12. The middle XHP35 HI will be in charged of the throwing mostly. Wonder can it hit 200kcd.
From picture it seems to be about same size with Utorch UT02, that is why I think it might hit 110kcd for the middle XHP35 HI, and the rest XHP70.2 can make up the 90kcd. Just a wild guess. :sunglasses:
That is true UT02 is weak as stock. But I think it is quite tough to reach 1800lm for Acebeam. We shall see how it perform in Q4 2018 when it is released. So excited with all these giant flashlights. Too bad not enough fund to purchase them at this price.
why no steel bezel? would look alot better imo, but curious how it will perform tho still not certain if it was a good idea ditch the internal fans? that “thing” looks sure odd haha it will be noisy as hell probably.
I should have bought DX80 when it was at $179, but i have never seen it at this price, i think i saw Jason mentioned it in some thread. This MS12 and R90C design are really not convenient to do topup charging, and i use turbo only for big lights.
