Emisar D4S review
2439 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 3 months 4 weeks ago
species8472 wrote:
ZozzV6 – Those are the same four lights in the same color combination as I have. The only difference is I usually have the short tube on the D1 to make it more pocket-friendly.
And the little orange led in the D4. I also have a short tube but in blue for the D4.
nhozbaod
Last seen: 11 months 1 week ago
can i use the 18650 to 26650 converter with D4S ? i dont have any 26650 cells
https://www.google.com.vn/search?q=18650+to+26650+adapter&tbm=isch&tbo=u...
ZozzV6
ZozzV6's picture
Yes but use decent high drain unprotected cells.
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 5 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
My early D4S prototype can’t even fit most 26650 cells, so I used an 18650 with some packing foam around it during the initial development.
Yes, a cell size converter should work… as long as it’s a good cell.
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 days 3 hours ago
SKV89 wrote:
Kawi, that is freaking incredible that you got 5000+ lumens. Which emitter did you get? I only got 3,800 lumens with my D4s XP-L HI 5D using my TA tube calibrated with Maukka lights. I’m kind of disappointed. I was expecting 4.5k lumens
Both D4S’s are XP-L HI V3 1A.
KB1428 “Live Life WOT
ZozzV6
ZozzV6's picture
Mine is an XP-L HI 3A and I got 4800 lumens with Liitokala black 26650.
DB Custom
DB Custom's picture
Last seen: 2 weeks 6 days ago
Apples to Apples Kawi, Washington Reds to Granny Smith maybe but…
6216.9 lumens (start value)
Samsung 30T powering the 4 Samsung LH351D emitters. Big Smile
mikeyx
Last seen: 1 year 4 months ago
I just tried to flash my D4S and it seems that the vias are too small for the pins on the Dupont cable. Has anyone else hit this problem ?
Thanks,
Mike
Man Without Shadow
Man Without Shadow's picture
Last seen: 36 min 19 sec ago
ya…I used some old solid core telephone wire
When I'm spending on¥ foolishly, I like to do it i$el¥...
I have all the flashlights I need, but not as many as I want...
blueb8llz
Last seen: 52 min 44 sec ago
I wonder why the blue was not an option. That was a beautiful color.
Newlumen
Newlumen's picture
Last seen: 1 year 9 months ago
Where did u buy Samsung 30t ?
Newlumen
Newlumen's picture
Thanks zozzv6 and kiwi. I am getting 4900 to 5000 lumen at turn on for the xpl hi 3A. I will report back with new number when i get my calibrated lights from maukka.
mustig
mustig's picture
Last seen: 1 week 2 days ago
Mine has quite loud PWM when the mosfet is active. I usually don’t hear it from other lights. Anyone got the same? Defect driver in mine?
Love the light otherwise.
DB Custom
DB Custom's picture
Tighten the ground connections, loose ground can cause them to sing….
I got my 30T’s from IMRBatteries in Houston I think. Might have been LiIonWholesale… can’t remember for sure, one of those.
species8472
Last seen: 19 hours 46 min ago
ZozzV6 wrote:
species8472 wrote:
ZozzV6 - Those are the same four lights in the same color combination as I have. The only difference is I usually have the short tube on the D1 to make it more pocket-friendly.
Nope, no nice nifty little orange LED - good job. I didn't look close enough and just thought it was a reflection. When looking at the LEDs I was wondering if mine were orientated the same compared to the switch and yes they are.
ToyKeeper
ToyKeeper's picture
It shouldn’t make any audible noise during use. If it does, there might be a loose connection or it could have possibly been flashed with the wrong fuse values. The latter is easy to test though. Go into beacon mode and measure the amount of time between flashes. If it is close to 2 seconds (with default settings), the processor is running at the correct speed. But if it’s a lot longer than 2 seconds, the processor is underclocked (which would make PWM audible).
flucero28
Last seen: 11 months 1 day ago
Does anyone know how to adjust secondary LED brightness in Anduril?
ZozzV6
ZozzV6's picture
Lockout the light with four clicks. In lockout triple click to change secondary led mode for lockout. Or click-click-hold to change for unlocked OFF state. Thet will cycle through the options.
The_Flashaholic
The_Flashaholic's picture
Last seen: 1 month 1 week ago
I have the D4S 3A too, on my Integrating-box I got 4650 with a 5200mah AWT 26650 and 4400 with 2 x Shockli 5500mah 26650 though both the Shockli cells gave me 4600 after the voltage dropped to around 4.17v for some reason.
All my D4 XP-L measure 4000-4300 depending on tint/optic. All my Emisars measured around 1000 lumens lower on my TA tube.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
flucero28
Thank you toykeeper. So this only sets the secondary led brightness level for lockout mode? I notice once I take the light out of lockout mode the secondary leds go back to lowest setting.
Newlumen
Newlumen's picture
Ok. Great number. Thanks for the input..
ZozzV6
ZozzV6's picture
Youre welcome but I’m not Toykeeper Big Smile
I told both lockout and unlocked setting method.
Set for lockout: triple click
set for unlocked: click-click-hold
flucero28
Ha ha ha thank you Zozz! I apologize. I am using my phone and the screen is small!
KawiBoy1428
Today I removed the brass driver contact, and made a thinner and larger diameter copper contact out of some copper rod I had laying around from a past project and drove it down to the pcb during the melt. Bypassed the rear spring with pure copper braid, soldered directly to the spring and board in a crossed overlapped fashion, it looks like Crap, I kept fighting that damn strong ass Magnet, kept attaching itself to my Iron!
A 30T @ 4.21v off the charger, I got 6,230lm at turn on….and the head is still stock XP-L HI V3 1A. I’ll run it for a few days… see if it lasts…. I have a third D4$ coming that I’m keeping stock… Wink I mean it!
OH I SLIGHTLY Dented my 30T in the process, Facepalm forgot to put the copper tail cap spacer in Angry
BlueSwordM
BlueSwordM's picture
Last seen: 8 hours 14 min ago
Damn, you guys want overkill.
6000 lumens at turn on… that is BLF Q8 levels of brightness.
I do wonder if it is possible to reach 7000 lumens, although that would be at the absolute max of these emitters and would probably the highest flux density light in the world.
bansuri
Last seen: 1 day 8 hours ago
Man Without Shadow wrote:
Did my first UI flash! Woot!
Received a bunch of errors…hex file was in wrong location…(noob)
A little tricky, but had great instructions and am fairly computer savvy…was able to power through it…
Put in correct location…Anduril flashed!
Thanks for help Fate0n3 and ToyKeeper!!
Congratulations! You’re having fun now!!
I too forgot to CD before flashing.
ZozzV6
ZozzV6's picture
replace leds with XP-L2 and there you go 7-8000 lumens
DB Custom
DB Custom's picture
Working on 7000+ Blue, should be there sometime Friday… Wink
Haven’t even bypassed springs yet… lol
Edit: Up to 6503.25 lumens at start now. Big Smile
Same 80 CRI 5000K Samsung LH351D’s, I pulled the driver spring and make a shallow solder blob on the driver and then put one of my large Blue springs in the tail cap with a 20ga bypass. This is with the LG HG6 20650 cell, rested and partially used. Wink
DB Custom
DB Custom's picture
I have 25 of the LH351D coming Friday in a W power bin, 2 bins up from what I have in it now. Wink
ZozzV6
ZozzV6's picture
What is the part number and parameters of that LH351D? CRI, color temp ? I haven’t tried Samsung leds yet.
