Thanks for your perspective on this lantern Den.
I bought a couple in the first group buy and have been very impressed with them. Long-term reliability remains to be seen…. The rubber USB port cover has already broken off mine. Actually, I think the cover is fixed too close to the port and does not easily fold out of the way, which is likely why it broke off after several uses.
I also have a Fenix CL25R which has been a great and durable performer - especially after I replaced the OEM cell for a 3400 Panny. Initially I got it for camping but I’ve found a multitude of uses for it ever since.
Like you guys, I find the UI on the Zanflare to be a bit of a pain. The brightness ramping is just a little too fast to get any kind of fine control (more so at the low end) and it may take repeated attempts to find a suitable level if you want something other than full high or minimum settings.
Regarding the lack of lockout - I’ve seen comments about putting a plastic “disc” under the battery cap to prevent accidental activation but I don’t know how the tailcap would stand up to repeated use. Frankly there isn’t much thread there and without anodizing, I fear they would wear quickly if the lantern was locked out this way on a regular basis.
As a lantern to throw in a camping kit for a backpacking or canoeing trip, I’d turn first to my Fenix. It too can be charged from a small solar panel. Having said that, I’ll probably take both on any vehicle-based trip.
Unlike the Fenix, which can only be run at the 2 lowest settings while charging, the Zanflare seems to support all output levels, at least while the cell is physically installed. Mine actually gets a little brighter if I plug it into a power source while on High. If you ever have need to pull the cell for another light, it will run with no cell fitted but output seems to “jump” a bit while ramping and is possibly not as bright.
As an occasional room light or table light, it looks less “industrial” than the Fenix (if that kind of thing matters to you). For an under-bonnet or under-vehicle work light, kids night light, off-grid cabin light, detachable porch light and a multitude of other possible scenarios, I think the Zanflare T1 is a fantastic unit for the price.
Of course, like many of us here, I eagerly await the upcoming BLF lantern under whatever naming convention is finally chosen.
