Luminus SST-20-W 4000 K CRI95 color and output test
218 posts / 0 new
maukka
maukka's picture
I got this emitter from Kaidomain on a 20 mm MCPCB.
Mounted on a CPU heatsink with a nice splash of thermal paste and over the top 16 AWG wires.
Purchase link: http://kaidomain.com/Luminus-SST-20-J4-FB4-Neutral-White-4000K-LED-Emitter?search=Luminus%20SST-20
Data sheet.
Exact order and bin code: SST-20-W40H-A120-J4FB4 VH
Where
SST-20=self explanatory
W=white LED
40=4000 K
H=CRI 95
A=solder pad configuration (3.25 × 3.25 mm)
120=viewing angle, 120°
J4=flux bin, 107-114 lm at 350 mA at 85°C, >118 lm at 350 mA at 25°C
FB4=tint bin, 4000 K above BBL
VH=forward voltage bin, 2.5-2.7 V at 350 mA at 85°C
CRI data measured from the hotspot with a
Bare emitter
Yajiamei 10° beaded optics at 1000 mA
Small op reflector from the Reylight Pineapple
Medium sized smooth reflector from the Eagle Eye X7
CRI data with increasing drive current with the Yajiamei optics measured from the hotspot
Tint shift with Yajiamei 10° beaded optics with increasing drive current
Tint shift is quite linear all the way to the max output current.
Output measured in a 50 cm integrating sphere
At 350 mA I measured 121.6 lumens at 126.5 lm/W.
Emitter died shortly after being run at 7 A. I can’t see anything visibly wrong with the dead emitter.
Edited by: maukka on 08/24/2018 - 15:45
maukka
maukka's picture
Sadly I wasn’t able to do any real world testing inside a flashlight, since the emitter broke during the output test. What little I observed during testing seemed very good. The tint is at least as good as with most Nichia 219Cs I’ve tested. With a smooth reflector the shift is even a bit less severe in the corona.
djozz
djozz's picture
Last seen: 2 hours 38 min ago
Thanks for the test. The led performs nicely up to specifications. I’m sure that many people will complain that the tint is above the BBL but I care a bit less about that.
contactcr
Last seen: 11 hours 10 min ago
so what niche does this LED fulfill that others do not? maybe good on AA sized/keychain lights or high CRI triples? Not really sure
maukka
maukka's picture
1000 very high CRI lumens from a single small die emitter with small tint shift is pretty good in my book.
adam7027
Last seen: 12 hours 3 min ago
Thank you for this thorough measurement Thumbs Up
There seems to be a noticeable drop in the cyan and cobalt blue area of the spectrum – but the high R12 value is still very impressive – and R9 is nearly at Nichia E21A level.
How this LED compares to Nichia 219C and Samsung LH351D high CRI offerings with the same CCT in regards of tint shift, output, and Vf?
Do all of these Yajiamei optics consistently push CCT into warmer direction, and a bit above BBL (this latter is no problem for me)?
I was very happy for a brief moment, when I read your bare emitter CCT measurement (43..K), so I wonder, if there are TIR optics available, which don’t – or just marginally alter CCT.
BlueSwordM
BlueSwordM's picture
Last seen: 5 days 14 hours ago
Yep. It’s very efficient. About on par as other small die 4000k 90+CRI LEDs, with a lower forward voltage.
This would make a very nice LED array in a 6A LD-A4 Sofirn C8F build. It would be gorgeous.
adam7027
Back a few months, I ‘snapped’ two C8F hosts for a very good price, but I was hesitating to put Nichia 219C in those hosts because the rather low Vf – I guess, this LED will be a good choice for triplets or quads.
djozz
djozz's picture
The difference is not great but this SST-20 starts getting a slightly higher voltage than the 219C, when going over 3A, so yes it will draw a bit less current and heat in high current direct drive triples or quads.
The_Driver
The_Driver's picture
Last seen: 1 day 11 hours ago
Thanks for the test!
It’s certainly an interesting LED. The light quality is very high and the efficiency thus low. It’s advantages over other LEDs with high-light quality are the XP solder pad layout, the single-die design (compared to the Luxeon MZ) and that it tolerates high currents (compared to the Nichia E21A and 219B-V1).
Jerommel
Jerommel's picture
Last seen: 11 months 3 weeks ago
So…. where to get a 5k low cri version to dedome….?
Could that be a XP-G2 killer?
djozz
djozz's picture
http://kaidomain.com/Flashlight-DIY-and-Tools/Luminus-SST-20-L3-DA-Neutral-White-5000K-LED-Emitter?sort=p.date_available&order=DESC
djozz
djozz's picture
The dedoming will be the challenge, no leds dedome so nicely as the old-school Cree’s
Jerommel
Jerommel's picture
Thanks Djozz.
I’ve been away from BLF for some months, so i have some catching up to do. Smile
Yeah, i bought 1 Liter of 99.5% Toluene for those SST’s, still a challenge though, but i’ll get some anyway.
I’ve still got a B158 waiting for a high intensity LED, for example.
I’ll try some of these high CRI ones too.
-X3-
-X3-'s picture
Last seen: 14 hours 24 min ago
Slicing is the way to go with SST
Now I’m impatient to get mines, they will go straight in the D4 Silly
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
MRsDNF
MRsDNF's picture
Last seen: 4 days 15 hours ago
Amazing testing maukka. Thanks.
Sirius9
Sirius9's picture
Last seen: 10 hours 34 min ago
Thanks for this test Thumbs Up
DavidEF
DavidEF's picture
Last seen: 4 days 8 hours ago
Does nobody else see the burned place under the top bond wire? Is that just a slightly darker connection area? Was it that dark before the test?
- The YKK Philosophy
maukka
maukka's picture
There’s the before image at the top of the OP.
SKV89
Last seen: 4 hours 45 min ago
Thanks Maukka, Im always interested to see your reviews. This one would have been the perfect 219b replacement if the tint bin was below tbe bbl.
Sirius9
Sirius9's picture
I tried dedoming (chemical way) two of this leds, it did not go well :/
eas
eas's picture
Last seen: 1 year 3 months ago
Any thoughts on how these would compare to the stock emitter options in a D4s? I have the Nicha version, but I’d like either more throw, more output, or some combination of both. It doesn’t seem like these would give me much, if any more output than the Nichia and the XP-G2, but are they more intense than the Nichia? They are certainly higher CRI than the XP-G2s.
djozz
djozz's picture
The difference in performance with a 219C R9050 will not be great. The CRI is better though, comparable to a N. R9080, which is not available in 219C, only in the lower performing 219B.
Jerommel
Jerommel's picture
What did you use?
Swib
Last seen: 3 weeks 9 hours ago
I intend to try when my 5000k come in from Kaidomain. I ordered 10 and I’m willing to waste some to see if it’s possible with Aerosolve II. If that doesn’t work I have some other solvents. I really want to see what this little guy can throw at 5 amps.
If you don’t like what it looks like on the wall, take it outside.
EasyB
Last seen: 18 hours 54 min ago
The problem with dedoming SST40s is the long/weak bond wires. The silicone separated nicely from the phosphor (using warm gas) but the silicone remains stiff and it pulls the bond wires out. I assume the SST20 has the same problem. Maybe a more effective solvent would improve the success rate.
SKV89
Here are some Skylumen numbers for comparison
https://www.candlepowerforums.com/vb/showthread.php?449829-Lumintop-GTvn...
eas
eas's picture
Thanks. By performance, do you mean overall output, or also intensity? I was just trying to compare two different S2+ I’ve modded with these emitters, and it looks to me like the area of the SST-20’s LES is somewhere between 25-50% that of the 219c. So, with similar outputs, the SST-20 should have higher intensity.
SKV89 wrote:
Here are some Skylumen numbers for comparison https://www.candlepowerforums.com/vb/showthread.php?449829-Lumintop-GTvn...
Thanks. That’s interesting. I’d guess the Samsung High CRI is the LH351D. These are with the stock driver? Which is a FET?
I wonder how 2× 5K SST-20 + 2× 3000K SST-20 High CRI would look…
djozz
djozz's picture
^ By performance I was referring to output, efficiency and current handling, but you have a valid point that I did not consider yet, the SST-20 indeed seems to have a bit smaller die than the 219 (and XP-G2), so a bit higher intensity and better behaviour in small Carclo optics.
eas
eas's picture
^ Thanks for clarifying.
I have some of the 4K coming. I’m still on the fence on whether to upgrade my D4s with LH351D for more output, or perhaps these for less flood.
Jerommel
Jerommel's picture
Awesome. Thumbs Up
Hope they will dedome well enough.
