I took more pics tonight. On the left is a Fireflies ROT66 219b, and on the right is a triple LH351D 5000K 80CRI in a 10507 optic. The camera’s white balance is set to “daylight”, meaning 5000K.
I really like the beam on the ROT66. It has the nicest shade of white in any of my lights. But I don’t like this particular LH351D. It just looks so… green. In this pic I’ve under-exposed the shot to make the tints more visible.
In this, the left is an Emisar D4 219c 5000K with the old 80CRI emitters, and a frosted optic. Middle is ROT66 219b. Right is a Nichia 219b 4000K in a BLF A01 copper. White balance is again set at “daylight”:
I got the Emisar D4 with 219C 90CRI and also another Emisar D4 with XPL-Hi 5D.
I have been using the “shine flashlight thru a small portable fan blades” method to detect PWM (I don’t have optical sensors or oscilloscope to measure PWM), just to detect if it has PWM.
With the Emisar D4 (stock firmware) with Nichia 219C, the flashlight is cooled down (unused for a day) and put in new fresh battery, then double-click to Turbo, shine the flashlight thru portable fan blade, I immediately detect PWM. At first I thought the thermal stepdown was happening immediately.
But rght now you mentioned it is limited to 80% of FET, so perhaps that explains why the stock D4 (quad-Nichia) in Turbo (double-click) will have PWM even in max output mode.
I tested the same thing on the D4 XPL-Hi, and double-click to Turbo, shine light thru portable fan blade, and I didn’t detect PWM (but PWM will then detected when thermal stepdown starts happening).
So, does the above confirm that the D4 Nichia has (non-100% FET, ie. the 80% you programmed them with), while the D4 XPL-Hi receives 100% FET (No PWM on Turbo, at least before the thermal stepdown)?
I suppose the same thing will happen with the Emisar D4S quad-Nichia (which would also be limited to 80% FET for max turbo mode)? (I’m ordering the D4S Nichia from Intl-Outdoor.)
That makes sense d_t_a, because as far as I know there are only two positions in the ramp where there is no PWM in play, the 100% 7135 level and 100% FET level. With the Nichia 219C having such a low Vf and requiring a throttling to control heat the FET is not at 100% and so there is a slight PWM.
If you can check it immediately after installing the cell, it should come on at the 100% 7135 level, does it show PWM there?
I put 4 Nichia 219C in my Ti/Cu Reylight X6 with a FET+1 driver and it wanted to pull over 21A from a single 18650! It got hot so fast it was totally impractical, even if it did make over 4300 lumens. Ended up changing that. Not because of the heat, but because I’m at the point that 4000 lumens is simply insufficient. lol It now makes just over 10,000. And yes, heat is a big deal.
Cameras tend to exaggerate tint differences when multiple lights are shown at once, especially when underexposed (obviously TK did that on purpose).
Here is a shot I made with 4 lights, all varying CCTs and tints, but I post-processed it in lightroom so that I could show the tints as accurate to my eye. All lights in person are reasonably white, but there are subtle differences (white balance 5000k) Also keep in mind that they aren’t on their max outputs, so the ROT66 won’t be quite as rosy as it is when on its max output. On its lower outputs it’s very close to the BBL.
At 100% 7135 regulated level, no PWM detected for the D4 Nichia, so it seems to confirm that theory of the 80% (or not 100%) FET level while on Turbo mode.
Okay, I could not stand it and I ordered D4s in XP-L HI. I have one 26650 in stock, so I will used it.
ROT66 will have to wait. Maybe at this time, he will get rid of childhood defects.
I think it more likely that the stepdown time is very variable but completely random, depending on the very inaccurate internal temoerature sensor of the MCU.
Regarding the “boundary” between regulated and unregulated, what “level” is that at in terms of ramp? Ie if I wanted to set my ramp ceiling to the highest regulated, would it be 100 or 110 or whatever? Thanks!
Actually, is this meaningful at all? I just wanted to pick a max output (sub-turbo) that has a good balance of run time and brightness, or at least a more predictable run time. Imagine bringing this camping and having it on at 90% instead of 50% and the battery dies in less than an hour of use (of course I have many spares).
First, in smooth ramp, there is a little “hitch” when it transitions to or from the fully regulated modes.
Second, the “unregulated” zone blends is really a blend of regulated and unregulated, so being a bit over the fully regulated zone has a fairly minor hit on efficiency.
I knew I had seen this somewhere, I found it again in this post.
I believe the post is discussing ways to set up the variation of light intensity per step, but the info you were looking for is step 85 is the highest regulated output on the 7135 chips.
I set up the photo to make tint variations as visible as possible. Lights running at only ~50 lm, short exposure with low ISO, photo taken at an angle to avoid direct reflections, factory preset white balance, etc. Because, in general, none of our lights are truly pure white.
Well, except for a couple lights people made experimentally to see how close they could get to pure white. And, next to a ROT66-219b, pure white looks a bit green.
Personally, I like that. I think a rosy tint looks more white than a true pure white. That’s why I like the Nichia 219b so much.
Everything in the photos is white though. They’re just different shades of white, photographed carefully to make the different shades stand out.
I’ve had very few lights which I wouldn’t classify as white. Here’s one though. On the right is a D4-219c 5000K. And on the left is a D4 with dedomed XP-G2 emitters. It had good throw, but it made everything look gross. The tint was so far off white that I ended up un-modding it.
