So, you’re thinking that if I bought 12 of those and left them attached and flowed 48 Samsung’s for a 48 emitter mule that I might see some serious great wall of lumens output? Probably pushed by a 4 parallel set of 21700 30T’s?
Edit: I have multiple 15 count sheets of SinkPAD’s that the SST-40 will fit on. Wonder what 45 of those would produce with a bank of, say, 8 parallel 30T’s?
1. Hmmm. With nice high efficient optics from say UCL, you could perhaps reach 50k lumens with 48 of these emitters
And yes, you could push 500W out of these 4 cell of Samsung 30Ts. I just wonder how you could actually reach that amount of power without melting copper on your way to the emitters if you take the 3V variant :smiling_imp:
Seriously though, it could be done. I would just recommend to take the 12V MCPCBs to lower current as much as possible.
2. Yes it could be done. However, you would need say… over 130A of total current. How would you do this?
Multiple FET drivers to drive banks of parallel emitters from the same power source. I mean, if I was going to… it’d effectively be like combining multiple lights into a single host. Like 4 Noctigon M43’s into one unit.
But of course, they are doing this here in a single large head with a cooling fan and nice charging set-up, so perhaps Imalent is onto something. I personally find the 9x XHP-35 very intriguing. If I were to buy one of these 3 it would be this one.
But i dont get it, both olight and acebeam use xhp70.2 in their lights? and the x70 will use as many emitters as the ms12 so imalent couldnt get it right and chose the older emitters ??
cool video u can def see alot brighter flood then dx80.
I tried Google translator with the Chinese buyer-tester and found the following.
DX80 vs MS12: After one year, the DX80’s 32000LM’s first monster status has finally been replaced. The 53000LM’s MS12 is more than DX80, whether it is from parameters or measured performance. The MS12’s light cup has a larger diameter and a slightly larger depth than the DX80. The effect change is that the center spot is slightly smaller than the DX80, and the whole is more concentrated and the long-range is stronger. At the same time, the flood angle is basically the same as the DX80, but the brightness is higher. However, from the perspective of my personal scene, in fact, the visual difference between these two lights is not so obvious. When I open the brightest moment, my heart is silently saying “I X, I am going” and so on. It is the same shock, because the sensitivity of the human eye to high-brightness light sources is gradually reduced. I don’t have an integrating sphere. I can’t test whether the MS12 is virtual, but from the video shooting results, the MS12 is indeed brighter and more powerful than the DX80.
