Regarding the “boundary” between regulated and unregulated, what “level” is that at in terms of ramp? Ie if I wanted to set my ramp ceiling to the highest regulated, would it be 100 or 110 or whatever? Thanks!
Actually, is this meaningful at all? I just wanted to pick a max output (sub-turbo) that has a good balance of run time and brightness, or at least a more predictable run time. Imagine bringing this camping and having it on at 90% instead of 50% and the battery dies in less than an hour of use (of course I have many spares).
First, in smooth ramp, there is a little “hitch” when it transitions to or from the fully regulated modes.
Second, the “unregulated” zone blends is really a blend of regulated and unregulated, so being a bit over the fully regulated zone has a fairly minor hit on efficiency.
I knew I had seen this somewhere, I found it again in this post.
I believe the post is discussing ways to set up the variation of light intensity per step, but the info you were looking for is step 85 is the highest regulated output on the 7135 chips.
I set up the photo to make tint variations as visible as possible. Lights running at only ~50 lm, short exposure with low ISO, photo taken at an angle to avoid direct reflections, factory preset white balance, etc. Because, in general, none of our lights are truly pure white.
Well, except for a couple lights people made experimentally to see how close they could get to pure white. And, next to a ROT66-219b, pure white looks a bit green.
Personally, I like that. I think a rosy tint looks more white than a true pure white. That’s why I like the Nichia 219b so much.
Everything in the photos is white though. They’re just different shades of white, photographed carefully to make the different shades stand out.
I’ve had very few lights which I wouldn’t classify as white. Here’s one though. On the right is a D4-219c 5000K. And on the left is a D4 with dedomed XP-G2 emitters. It had good throw, but it made everything look gross. The tint was so far off white that I ended up un-modding it.
Ramp level 85/150 is the highest level with fully-regulated power on the 7135 chips. Above that, the FET activates.
Thermal regulation is completely independent of that. It depends on the temperature the user configured. However, thermal regulation does a hardcoded floor, below which it will not attempt to reduce power for heat reasons. On the D4S, that floor is level 60/150.
These values are set in cfg-emisar-d4s.h , along with other hardware-specific parameters.
Yes. The anodizing color is not related to the thermal step-down behavior. That’s just random, based on factory variation in the attiny85 chip.
I have FSM / Anduril working on it though, and it includes a way to calibrate the sensor for more consistent behavior. It works on all Emisar lights and all Fireflies lights so far, plus a few others. And the D4S includes the calibration code too, because it’s built into RampingIOS V3.
Is there a place that breaks down exactly how to use every feature this light has? Like a step by step walkthrough of how to program the thermal config and how to program the ramps/floor/ceiling?
It’d be easier to say what’s the same. They both run on the same hardware, more or less. They both have smooth ramping with a very similar ramp interface, and they both have discrete levels… though the method for discrete levels is different. Otherwise, almost everything is different.
Same basic idea, when painted with broad strokes. But the details are all pretty different.
Want one of these just can’t manage to pull the trigger and spend more money. Just a bit more than I can justify. Damn this site and it’s temptations! :rage:
i though id give it a try and order one but the colour of the aux leds look the same as the torch from Int-outdoors. i’ll try and get a photo later when im home
Just to put it out there, white is only white when there are no shades. In my line of work, when a bride spends over $2000 for a white wedding dress it DANG SURE BETTER look white in the pictures! Never mind she stood in front of blue, green yellow and red stained glass with the sun shining through, she paid for white and it’s white she wants! No shades!
